Stern Node Board 12
PN 520-6976-72A
#CN1 - MOLEX 22232061
6 pin/circuits
2.54mm pitch
5v on pin 6
RCK OUT pin 5
SCK OUT pin 4
MOSI OUT pin 3
MISO IN pin 2
GROUND pin 1
compatible crimp housing:
-MOLEX 22012061
-MOLEX 22012067 (friction ramp)
-MOLEX 22013067 (friction ramp with polarizing ribs)
#CN14 - MOLEX 26604050
5 pin/circuits
3.96mm pitch
48v on pin 5
N/C pin 4
DOOR pin 3
KEY pin 2
GROUND pin 1
compatible terminal housing:
-MOLEX 09503051 (friction ramp)
-MOLEX 26033051 (trifurcon terminals)
-MOLEX 26034050 (trifurcon terminals, friction ramp)
KEY for pin #2 MOLEX 26634051
Power distribution board
PN 520-8096-00
#CN7
0.084 2-Position
Plug 50-84-1020 (2.13mm Diameter MLX Power Crimp Housing Plug, 2 Circuits, Natural)
Pin: 02-08-1001
for those not in the know, there is an ability to accidentally plug these connectors on backwards, thus the safest (idiot proof) option of these terminal housings would be those with friction ramp AND polarizing ribs. I'd also recommend the trifurcon connectors... pinrepair.com said it best "The Trifurcon design provides three distinct points of contact from the terminal pin to the header pin. This is the ideal choice where high shock or vibration exists. For low current/voltage, Gold is recommended. Phosphor Bronze recommended for higher rated current circuits. Trifurcon only available for .156" and larger pitch. Because Trifurcon connectors resist vibration, they maintain their current (power) ratings much better than single wiper connectors. For this reason Trifurcon crimped connectors are ideal for pinball applications."
For the all the CN connectors above (except for CN14), you may use:
-KK Crimp Terminals 2759, 6459, 41572, 4809, 8088
-0KK 254 Pre-Crimped Leads 797580007, 797580015.
For CN14, you may use:
-MarKK Crimp Terminals 45570
-KK Trifurcon Crimp Terminals 6838, 7258
-L1NK 396 Pre-Crimped Lead 797582145, 797582146.
