(Topic ID: 166262)
Hesitating between 2 staplers, suggestion?
By Plumonium
  • 27 posts
  • 13 Pinsiders participating
  • Latest reply 3 years ago by 85Txaggie
    #1 3 years ago
    I'm hesitating between 2 staplers.
    One is upholstery stapler using 22gauge staples. The other is similar but uses regular Arrow T50 staples. I thought the second could work well and I could used it for other more heavy duty task I might have around the house. As the first one if more light duty but better suited for ground braid.
    What you guys think?
    Surebonder-9615 ( 3/8" narrow crown - 22 gauge staples from 5/16" to 5/8" in length)
    amazon.com link »
    Surebonder-9600 (T50, 1/4" through 9/16" lengths)
    amazon.com link »
    #2 3 years ago
    Here's the one I have:
    amazon.com link »
    Has a longer nose to get into harder to reach cabinet and playfield areas.
    #4 3 years ago
    Yeah but it's 90$ more in Canada ($129). 40$ is what I want to spend for a stapler I feel.
    #5 3 years ago
    Buy the long nose, you will really like it!
    #6 3 years ago
    Quoted from Redketchup:
    My wallet won't
    #7 3 years ago
    You will get what you pay for with those cheap staplers (or any tool for that matter).
    12
    #8 3 years ago
    Had to be done, you all know it.
    #9 3 years ago
    Yep. What these guys are saying is true. You want the Unicatch long-nosed upholstery stapler, also found on pinrestore.com:
    http://www.pinrestore.com/Tools.html
    The long nose will help you get into tight spots, it fires the factory staples when you're doing repairs or restorations, and gets you in between wires on the playfield when you need to staple down ground braid or pop bumper leads.
    The first time you can't get into a tight spot with the other stapler, you'll wonder why you didn't pay the extra money.
    And don't get me started on cheap riveters...
    #10 3 years ago
    Maybe... But if it's for playfeild purposed, you have to put the socket before the ground braid, be able to do the job with the long nose it's a real advantage. if it's only for cabinet, both will work fine.
    #11 3 years ago
    So far it's only for cabinet ground braid. And I'd like to do other things than pinball restoration with it (not upholstery...) The reviews seem to say it's doing its job.
    #12 3 years ago
    Who knows if it's the only 1 time I'll have to install new ground braid in a cabinet...
    #13 3 years ago
    Quoted from aztarac:
    I have done amazing things with cheap tools.
    #14 3 years ago
    I don't use mine often, but it's handy when I do need it. Just like any other tool.
    I've since learned it's better to spend a few extra bucks on a better tool that has some good feedback, than to struggle with a cheaper tool that might not work quite right and has no feedback. But, sometimes I've done ok with cheaper tools, sometimes not. It's hit or miss.
    #15 3 years ago
    Now, to go back to my original question, would you get the 22 gauge stapler or the all-around T50 staples one?
    #16 3 years ago
    It's either those or the hand stapler. I already made my mind to get a pneumatic stapler, come on you guys!
    90$ is not a few extra bucks for a single ground braid job. As an example, I can get new speakers and bunch of goodies for that money. Sometimes, it's one or the other. We got to compromise...
    #17 3 years ago
    "I'm looking for suggestions." "I have a suggestion." "I don't like your suggestion."
    Cheaping out on tools never pays in the long run, when the cheap tool breaks.
    #18 3 years ago
    Quoted from Plumonium:
    Get the cheapest one.
    Me, I got the long nose one and concur with pretty much everyone else on this thread.
    #19 3 years ago
    This is what I got off of eBay:
    UNICATCH US2238LN LONG NOSE AIR STAPLER TOOL W/ " C TYPE STAPLES
    ( 361347820283 )
    I got it from Staplemania off their eBay store. The stock staples that they ship with were not the right size, so I asked them to sub which they did for me. I have used it for two playfield transfers since I got it and it has worked perfectly. The box of staples will likely last longer than I will.
    I think it was $76, including shipping.
    I am told that it is the same typed as used in manufacturing.
    ebay.com link » Long Nose Air Stapler Tool W Senco C Type Staples Unicatch Us2238ln Us71 1
    #20 3 years ago
    What about this long nose stapler for $50.00? Any good? Or junk?
    amazon.com link »
    #21 3 years ago
    The all-purpose staples will not look right. If you don't care about that, get it. Otherwise get the upholstery stapler.
    #22 3 years ago
    Go with the 3/8" narrow crown - 22 gauge staples.
    #23 3 years ago
    I went with the narrow 22 gauge stapler and it works very well. So much easier to drive staples than a hand stapler I'm never going back. It's very small and very light. Best 40$ spent ever.
    Surebonder-9615
    -1
    #24 3 years ago
    Wait until you have to pull a pop bumper body off a WPC game with the 555 socket and the flat wire stapled. The wires will be buried under the other mechanisms and wires. Good luck using your short nosed stapler.
    #25 3 years ago
    Quoted from cottonm4:
    I would think that one would work great.
    #26 3 years ago
    Quoted from 85Txaggie:
    No one would re-staple these as it would be nearly impossible on most machines to remove the original staples and flat wires without a major playfield disassembly. Everyone would simply cut off the old socket, and solder the new light socket leads to the the existing flat wires.
    #27 3 years ago
    Quoted from Pin_Guy:
    I guess I am no one.
    $ 9.99
    $ 334.95
    $ 16.00
    Tools
    PinballSolutions.eu
    $ 149.00
    $ 12.00
    $ 7,899.00
    Operation Pinball
    Various Novelties
    GC Pinball
    Professor Pinball
    $ 99.99
    $ 24.25
    The MOD Couple
    $ 999.00
    $ 249.00
    PinballBulbs
    $ 235.00
    RS Technologies
    $ 48.00
    $ 49.99
    Comet Pinball
    $ 999.00
    $ 24.95
    The MOD Couple
    $ 1.95
    Various Novelties
    Pinball Wheezer
    $ 9.95
