So, I have a game missing the ground prong. The cable in this game is awesome - super long.
Instead of replacing the entire cable - can I cut off the plug and splice a new plug on the existing cable?
So replacing the plug can be done, but doing so is sometimes against local electrical code (so can't use it in places like businesses). If it is for a home machine, then that is no real concern.
Yes, you can do this - even in a commercial environment as long as the color codes are matched to terminals and you do a good job (e.g. tight screws, no cut or loose hanging strands).
Also note that on some of the newer power cords, the colors can be the new IEC colors:
Black wire (older cords) = brown wire (newer cords)
White wire (older cords) = blue wire (newer cords)
Green wire (older cords) = green wire with yellow stripe (newer cords).
Yes, though I generally prefer to replace the whole cord with a fresh 14' cord, since original cords typically have minor age or wear issues present.
I have a couple of these plugs on-hand: https://www.amazon.com/gp/product/B0015P708Y
Also, make sure to use the multimeter to test continuity of the grounding prong all the way into the game.
This page was printed from https://pinside.com/pinball/forum/topic/heres-an-ignorant-plug-replacement-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
