(Topic ID: 351251)
HerculEASE JJP Flipper Power/Consistency Kit
By altan
8 months ago
  • 315 posts
  • 104 Pinsiders participating
  • Latest reply 3 days ago by altan
  • Topic is favorited by 89 Pinsiders
    There are 315 posts in this topic. You are on page 1 of 7.
    23
    #1 8 months ago
    *** Ordering and Manual
    To order, please use my Pinside store linked below.
    https://pinside.com/pinball/market/shops/1579-skillshot-combo/10267-herculease-flipper-strength-diy-kit-jjp
    You can view the installation manual here:
    https://www.skillshotcombo.com/products/manuals/HerculEASE-Installation.pdf
    *** Introducing HerculEASE Hero Edition!
    Announcing HerculEASE Hero Edition.
    The Hero Edition offers all the HerculEASE functionality that people love while offering improvements to the original design.
    Most noticeable is the new HerculEASE Podium. The podium is a custom designed holder for the HerculEASE capacitors, potentially replacing the zip tie and adhesive. When used in the backbox, the podium easily and securely mounts to a readily accessible bolt for stability. Since the back of the podium is flat, it can alternately mount with adhesive (when used within a cabinet).
    With the Hero Edition, the HerculEASE fuses have been updated with a custom designed holder providing stability and allowing even easier installation. The holder allows the installer to easily grab and snap the fuse in place.
    Finally, HerculEASE Hero Edition is designed to discharge the capacitors in the unlikely (and strongly warned against) situation where the HerculEASE fuse is removed from the game before the capacitors fully discharge. Discharge takes around 45 seconds.
    Hero Edition is pictured below.
    The front and back of the HerculEASE Podium are pictured below.
    Here's a picture of the HerculEASE Podium securely mounted inside the backbox.
    *** Some Pinsider Comments
    Here are some quotes from pinsiders in this thread:
    • "I was picked to try this on my POTC. It is amazing"
    • "... instructions are spot on"
    • "Just installed on GnR. Huge difference!!"
    • "Received it today and had it installed 15 minutes later. Piece of cake install."
    • "... much better than stock!" (Wonka)
    • "From the first flip you could tell the flippers were snappier" (WOZ)
    • "... it makes a very noticeable difference. Less wet noodle feeling flippers. Well done!"
    • "Another satisfied customer. The kickback on Wonka is defiantly stronger"
    • "... the install was easy and it made the flippers better" (WOZ)
    • "Hooray for this mod!!" (Hobbit)
    • "... it makes a huge difference, and I just doubled my GC on my first play so that’s something"
    • "Kit definitely makes a difference on Wonka"
    • "Installation is very easy and took 5 to 10 minutes"
    • "I did notice a marked difference in the strength of the flippers. Could backhand the left ramp from the left flipper with much greater frequency than before the installation..." (Dialed In)
    • "Added this to my GNR and really happy with it. So much easier to make the ramps..."
    • "Just installed in Dialed In LE, Hobbit LE and GNR CE, what a difference! ... HUUUUUUUUUUGE !"
    • "Install was super easy, took 10 min"
    • "Much more fun now to play GNR"
    • "Just installed this on my GNR and wow does it shoot so much better. Total game changer. A must buy if you own the game. Easy install."
    • "Another happy customer. Could feel the difference in flipper power."
    • "Thanks again, easy install and worth it for sure."
    • "Super clean and easy install, took me 10 mins... overall really happy with the kit."
    • "I own GNR this is a GAMECHANGER!"
    • "Just installed in my Wonka… Wow what a difference… Worth every dollar.."
    • "first game, GNR, total difference... second game, WONKA, all better, ... third game WOZ YBR, sooo much better.. would recommend to all on the fence.. game changer"
    • "Easy to install, zero problems, great flipper action"
    • "Installed this kit on my GNR LE, Wonka LE, and WOZ ECLE. It feels like new life has been given to all 3 games"
    *** HerculEASE Info
    Some people are just fine with the existing JJP flipper feel. If that’s you, then great! You don’t need to change a thing. But if you are interested in experimenting with potentially stronger and more consistent flippers, read on.
    Introducing HerculEASE, the easy to install, no solder, reversible solution to increasing flipper power and consistency in just a few minutes.
    Replace 2 fuses with the HerculEASE fuses
    Connect two HerculEASE terminals to a screw on the existing IO board
    Attach the HerculEASE capacitors to the backbox for stability
    No need to remove the large IO board or remove the almost 20 cables.
    You’ve probably seen all the buzz surrounding JJP’s “Fully Populated Updated I/O Board” and the energy it adds to older games. It has received praise for delivering stronger and more consistent flippers. Yet it costs upwards of $400 with shipping.
    While JJP has not engaged in the conversation, the notable difference offered by the new board appears to be much larger capacitors on the circuits driving features such as flippers. Many have experimented and replaced their original board’s capacitors with higher value ones and experienced revitalized flippers. Because the higher value capacitors are wider than the originals, this experimental effort requires additional work beyond desoldering and soldering to make everything fit.
    HerculEASE is experimental and not approved by JJP. Just like other DIY efforts being done by Pinsiders. It’s a “use at your own risk” solution.
    Each HerculEASE is hand made. I’m currently running HerculEASE in my Guns’N’Roses pin as well as my Dialed In! And the results are amazing.
    *** Alternatives
    HerculEASE isn’t the only option so let’s look at alternatives.
    First option. You can purchase the updated $400 board, remove almost 20 cables, loosen the stands, finesse the large 19-inch wide board around an abundance of cables and remove it from the backbox. Then insert the new $400 board back though the cables, carefully align it on the stands, reattach the 20-some cables to the correct locations and check you haven’t missed a connector that’s hiding behind some wires or the new board itself. This is a valid approach, and you get the 100% official I/O board.
    Second option. You can go the DIY route for probably less than $20 and pull out your soldering iron. While approaches vary, you need to source the correct capacitors, lead extensions, stand and adhesive. Go through all the steps to remove the existing IO board, carefully desolder the existing capacitors without destroying the pads or through holes, solder lead extensions to the new capacitors, build or print capacitor stands, solder the new caps to the IO board and finish up with appropriate adhesive to hold everything in place. Then reinstall the modified IO board and connect the 20-some cables. This is a valid approach for people with the appropriate skills.
    Finally, you can go the HerculEASE approach and leave everything in the backbox and don’t touch the 20-some cables. Instead you replace 2 fuses with the HerculEASE fuses, connect two terminals to a screw, and use a zip tie to hold the HerculEASE capacitors in place. This is great for anyone who wants simplicity as well as the ability to easily back out the modification.
    #2 8 months ago
    Great news! I don’t own any JJPs, would love to have DI and Wonka, but those flippers feel atrocious no matter how hard some people kept defending them!
    Very glad to hear there is a fix and JJP themselves finally admitted their flippers were dogshit from the start. Following this thread!
    #3 8 months ago
    I’m in! Sounds fabulous
    #4 8 months ago
    Lovey idea and solution. Will be a real asset to those that want a simple plug-n-play with no soldering. Well done!
    #5 8 months ago
    Quoted from Isochronic_Frost:
    You might want to check out these threads.
    https://pinside.com/pinball/forum/topic/jjp-fully-populated-enhanced-i-o-board/page/10#post-8012777
    https://pinside.com/pinball/forum/topic/the-official-jjp-gnr-thread/page/551#post-8012769
    #6 8 months ago
    Quoted from altan:
    Some people are just fine with the existing JJP flipper feel. If that’s you, then great! You don’t need to change a thing. But if you are interested in stronger and more consistent flippers, read on.
    HerculEASE is in pre-production right now and is being tested by several Pinsiders.
    And I’m getting my Pinside store setup
    I'm curious what the new fuses are for?
    #7 8 months ago
    I’m interested.
    #8 8 months ago
    Video install please
    #9 8 months ago
    Nice, following and will likely order!
    #10 8 months ago
    i'm interested too
    #11 8 months ago
    Quoted from daveyvandy:
    You can assume he's using the fuse's location in the circuit to intercept the circuit without soldering. So replace a fuse with a assembly that has a fuse + wiring for the capacitor in line.
    #12 8 months ago
    Do you have an approximate cost on this yet?
    #13 8 months ago
    Quoted from usafstars:
    No good sales people build excitement to help people get over the hump the $$$$ hump that is.
    #14 8 months ago
    #15 8 months ago
    Thanks for making me laugh Chaka…that was a good one!
    #16 8 months ago
    I thought I read in another thread it was under $100.
    #17 8 months ago
    Quoted from mtp78:
    Your wish is granted
    flynnibus gave a solid answer. All designs require consideration of constrains, cost, time-to-market, complexity, etc. The fuse approach was optimal at this point.
    Well under $100 is what I can say at the moment.
    #18 8 months ago
    Put me down for one GNR
    #19 8 months ago
    Interested
    #21 8 months ago
    Nice!!! Looking forward to this.
    #22 8 months ago
    Pics or it didn't happen.
    #23 8 months ago
    Would love to see the install vid. Already have the new caps but if a solderless solution is out there im interested.
    #25 8 months ago
    All sounds good, no pics...price...or eta?
    763468a7-252d-48ba-9a20-14629796200a_text (resized).png763468a7-252d-48ba-9a20-14629796200a_text (resized).png
    #26 8 months ago
    I already have the caps (two sets- e-Bay and Mouser). I’d rather go solderless if possible so I don’t have to remove the board.
    Since the original 3300 caps stay in with this add-on version, does it use 6800 or a lower capacitance?
    Will there be a kit version for people who BYOC?
    #27 8 months ago
    Will it work on Hobbit? The board is not in the backbox.
    #28 8 months ago
    Quoted from marspinball:
    The technology / approach should work, it's the mounting that may change. I don't have a Hobbit under test. Look for a DM...
    #29 8 months ago
    Quoted from emsrph:
    It would be lower.
    Quoted from emsrph:
    That's not in the plans at the moment.
    #30 8 months ago
    Quoted from jamieflowers:
    All sounds good, no pics...price...or eta?[quoted image]
    I hear you! I believe I posted a target of well under $100 earlier -- losing track of what I wrote in DMs vs. posts. I'm using the pre-production units and investigating the Pinside shops to understand all the costs, such as: Pinside's overhead, strip's overhead, my time to build, time to package, shipping costs, etc. Plus the feedback from the early adaptors will confirm all's well.
    Spitball? I'd like to start selling in around 2 weeks. No promises.
    And pics? Shortly.
    I do appreciate the interest and questions.
    #31 8 months ago
    For that price and easy install, I'd be interested. My main concern would be burning out parts down the road, as a result of doing something that the machine isn't designed to do. Is that a potential pitfall here, or is this ostensibly 100% "safe"?
    #32 8 months ago
    So, after you finish this Herculean effort and make your "One - Million - Dollars!", could you please move on to
    making a ball go up the ramp on Black Knight with your magic power booster?
    #33 8 months ago
    Interested. Already bought the caps but interested in a solderless option.
    #34 8 months ago
    Interested in a kit for my Wonka LE and GNR LE.
    #35 8 months ago
    Quoted from Jaygee77:
    ... My main concern would be burning out parts down the road, as a result of doing something that the machine isn't designed to do. Is that a potential pitfall here, or is this ostensibly 100% "safe"?
    This is mentioned in my first post and it's important to be clear.
    This kit is based on experimental data and observations from the community. It's not supported or endorsed by JJP in any way. Only JJP knows the full end-to-end system, I cannot guarantee any behavior short term or long term. It's up to you to determine your comfort level and whether to install.
    One great aspect of HerculEASE is you can easily remove it.
    All that said, I've got it installed in GNR and DI. I believe many others have done similar with the cap swap approach which is functionally similar.
    #36 8 months ago
    Quoted from altan:
    I have a Hobbit if you need a beta tester.
    Here’s a picture of the I/O board. It lays horizontally inside the metal box of the cabinet.
    #37 8 months ago
    I'd be in for Wonka.
    #38 8 months ago
    interested in a GNR
    #39 8 months ago
    I would also be in for Wonka
    #40 7 months ago
    +1 for GnR
    #41 7 months ago
    I'd be interested in one for my Dialed In.
    #42 7 months ago
    I'm really interested in this. Keep the updates coming!
    #43 7 months ago
    Quoted from clg:
    Coming along well... The draft manual has been well received and I've been told installation is quite simple. Got parts to make a batch. Some people have received or are receiving their pre-production versions for early feedback...
    That's a little update
    #45 7 months ago
    Quoted from altan:
    Thanks I sure hope you ship overseas as I would really like to add this to my DI!
    #46 7 months ago
    Yes for GNR as per DM, above question relates to myself as well, OS shipping ?
    #47 7 months ago
    i might need three or four of these.
    #48 7 months ago
    Quoted from altan:
    How about a sneak pic?
    #49 7 months ago
    I'm in for one once they are available!
    #50 7 months ago
    Waiting for pics
