I’m sure I’m not alone in sharing the hatred of having to clean playfield glass every 15-30 days due to dust. It makes you wonder if that level of dust is making it onto the playfield glass, imagine what you’re inhaling into your respiratory system.
I searched for a total basement HEPA filtration solution and was not impressed at the quality of most consumer units. Of the very few good ones that existed, they either used too much electricity to achieve the needed number of air turns, or their filter replacement cost & lifespan ratio was not cost effective to own.
Commercial solutions such as “HEPA Air Scrubbers” were just too expensive and had their own set of drawbacks. This lead me down a path to build my own system completely from scratch, and to tailor it to fit my application.
I began researching Carrier’s Commerical Opticlean Negative Air Machine / Air Scrubber. It is a hospital grade HEPA filtration system used for creating a negative air space during treatment of COVID, and to scrub the infected air before discharging it. For applications where this was not possible, it would continue to recirculate the infected air, essentially “Scrubbing” it, and further reducing the contagious effect. Once again, way too expensive to acquire, and way too loud for a home arcade.
