Quoted from High_End_Pins:Woke up to this. It is only starting to build up.
Looks like that Santa's workshop needs a new wire harness. Hope you have enough red-white and green-red wire.
They do not perfectly align the replacement is slightly longer.
I see this occasionally and in these cases I make sure to fully align the most important features which are slings.
The holes that are a touch off will be easier to address if needed as they would be for lights
Or flippers.
Flippers are just a single hole as are lamps that is why it is better to gravitate towards the larger and more complex/muti hole features when alignment issues pop up.
So my EBD project is part of a bigger picture overall.
I have the special one headed towards the finish line and in the background I am staging up the second one.
This is a point where I need to set the stage for the second one so there are steps I will take with the first one(special) to advance or gather knowledge for the second one(stock style build ) so before I gut the playfield from the special build I will copy the lamp board layout and wiring onto the second build.
I have a full set of EBD lamp boards so that is the hardware needed less figuring out how to adapt it to a non lamp board version.
This is even still part of a bigger picture because I am going to use the teardown playfield from the second EBD to best and most accurately drill the topside of the Special EBD so you start getting into chicken or the egg situations. I am working the room at this point not just the projects
So what will it take besides the lamp boards themselves to add lamp boards to a traditional EBD playfield?
Not too much that I can see I mostly need to pick up this black/white wire somewhere on the traditional playfield wiring179F65DC-A97A-4661-8636-0EC50CBE753A (resized).jpeg
Then of course the connector building and verification that they used the same lamp wiring colors from the 81 when they built the 84
No guarantees there.
That black and white wire need changes to blue and green when we get to the other two lamp boards on the 84
This is really just the buss on the 84 they made it blue/green in place of straight blue so again not everything is identical so I have to be careful and investigate as I go.
Your lucky to have a spare for dimpling....My first playfield swap about 8-9 years ago was a IPB EBD no holes or dimples.
Luckily i only did one screw up with a drill and was covered.
Quoted from Stretch7:Your lucky to have a spare for dimpling....My first playfield swap about 8-9 years ago was a IPB EBD no holes or dimples.
Yes that drill template is left over from the last three or four IPB swaps I have done.
Despite the lack of holes and dimples they are nice playfields overall.
Well - just managed to read through all the thread and I am totally depressed by it all as it makes my restoration attemps look feable at best!
What great work.
Quoted from Bakerman:Well - just managed to read through all the thread and I am totally depressed by it all as it makes my restoration attemps look feable at best!
What great work.
It should be inspiring!
Starting on the EBD 2 lamp board adaptation.
This will be where I start as it looks to be the most populated with sockets
I make up the correct number and pin outs of IDC connectors.
Some wires will run a little short that is mostly because of the condition of them and need to trim them well back. In those cases new color correct wire is run and will be tapped in staggered patterns well downstream within the harness.
So what's the end state here Chris, you are adding the light boards to a non-LE game to simplify the PF? I thought you were taking an LE and moving it into a stock cabinet vs the LE-beast... and removing the light boards.
Confused
Quoted from flynnibus:So what's the end state here Chris, you are adding the light boards to a non-LE game to simplify the PF? I thought you were taking an LE and moving it into a stock cabinet vs the LE-beast... and removing the light boards.
Confused
I am building two EBD games so there is some cross over in the process but this thread is more about the day to day than a specific project so It might be confusing sometimes if you are zeroed in on specific project.
Here is the breakdown on the EBDs
I am building two different ones
The custom colored one
A stock looking one
I have three games here to do that with plus a lot of spare parts.
Games being used are
Traditional 81
LE
84 version
Add to that I have one full spare set of lamp boards.
End result will be the following
Two different HEP EBD games
Both in the traditional 81 style cabinet
Both with the playfield lamp boards
One custom colored
One stock colored.
Second EBD lamp board adaptation is done.
Replacing this lamp bank with this lamp board DEA3EC58-6B2F-4527-A1FD-6B79B41D28B2 (resized).jpeg
This is more involved than the first because the wires need to be rerouted entirely. They come out right now on the opposite side they will be needed. F27600AF-CEF5-4C41-A7E4-E8F56E4A40A6 (resized).jpeg
Wires are fished out
Then threaded through in a new direction.
Now with some additional work and wiring done.
image (resized).jpgimage (resized).jpgNow the playfield that will serve as the topside drilling template for the special EBD playfield is stripped complete 25EE706F-B8BD-4BCA-B673-CD522D9D68E0 (resized).jpeg
For those not quite as well versed the problem with this supplied playfield is that it is heavily cleared but missing the holes for almost all parts that need to be attached.
This presents a couple initial concerns.
1) will the clear crack when drilled?
2)how do I create all the missing holes accurately ?
Here is the original playfield in just a small section to compare to the new one in the same section to highlight the concern
Original with holes and dimples.
Here is the replacement with no holes
762EB2E1-42D6-4B42-B159-2332F553D495 (resized).jpegThe old playfield is clamped to the new and used as a template for the most accurate drilling possible.
After very carefully drilling the lack of holes issue has been resolved.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgQuick trip back to the warehouse and the TAF is gone.
That uncovers today’s new arrival.
There is something good though.
An NOS playfield. It needs a good bit of work too but that is to be expected on games and parts this old.
Quoted from chad:Probably nothing.
Yes I was just about to say that.
I do sand the underside of the old and make sure it won’t scratch the new.
Putting anything between could compromise the process.
Back out in my big building with no heat
Not too bad out here really.
I am going to start gutting DR Who
There are a couple parts I am waiting on for the EBD special playfield that will be here soon.
Last minute changes to the scheme as it builds so I have just a brief moment to start staging up one of the future projects.
I like to think of the various staging areas and games as being a bit like prisoners in the court system.
The warehouse is the penitentiary they are in there doing their time.
The large building is the local jail awaiting the appeal and acts as a temporary holding cell closer to the courtroom.
The garage is actual courtroom and time in front of the judge.
The judge is pretty fair. To date all prisoners have been rehabilitated,paid their fines and been released
We are in the holding cell.
Playfield is out of the Dr who and on the notisserie
Temperature is dropping. Now just a tick below 60 in here but much better than the 36 degrees outside. B6E213CE-8D02-4E16-9D0C-078A42F85892 (resized).jpeg
Keeping the evening beer at the perfect temperature though so there is an upside.
8B6B89F0-CAD5-4229-9846-99EBC5181C35 (resized).jpegDr who cabinet is gutted.
Need to decide whether ther to strip and reuse this original or have my local cabinet builder copy it.
I can probably strip it and restore it in a few days.
Have it built locally in about 2 weeks.
Tough choice sometimes.
60887AEA-6A43-497C-A512-1C70AE5281A7 (resized).jpeg9C5BDFC5-CE88-4F01-BBDE-9A98130812E2 (resized).jpegBC10828D-0AAB-409A-96B5-8179EFDF3D7C (resized).jpeg
I am going to just strip this one and reuse it.
The cabinet builders take longer than the entire restorations usually.
They will quote two weeks and it takes two months.
I could have the entire game done by then so it just isn’t worth it on this one but makes sense on others.
Have to weigh it all out on a game by game basis.
Dr Who cabinet neck top plate was screwed on at arrival
The plated is removed.
I am going to reattach it with glue and lower profile screws using the same holes. This means one of the screw locations will need a dowel instead of a screw since it could clash with the latch screws.
Dowel is placed and the neck prepped. A22D3BB5-13C9-4E46-88E6-A8A66C62B6AA (resized).jpeg
Top plate is reinstalled.
Then small dowels are glued over the countersunk screw heads.
Once they dry I will shave them flush and only need a small filler application.
Quoted from High_End_Pins:Then small dowels are glued over the countersunk screw heads.
I know you previously stated your skills of body filler / paint / clear were gleaned as an auto body guy, what about these wonderful wood working techniques?
I'm always picking up new things from watching you work!
The latest fresh salmon shipment has arrived.
I actually get a lot of inquiries about this
This is how it gets handled.
I buy an entire king at 12-15 pounds so I can take advantage of the free filleting and shipping which is a good savings since it has to be overnighted.
It arrives like this the next day.
Removed from the box/cooler.
Each fillet is dipped into a ice water light salt bath
Then they are placed in a vacuum bag.
Then vacuum sealed.
After the entire lot is done
It is bagged again individually in ziplock freezer bags and placed in the freezer.
I of course hold a small bit out for the short term use so I can enjoy at least a serving or two in its never frozen state.
First fish tutorial on Pinside. Making history here
Quoted from Atari_Daze:I know you previously stated your skills of body filler / paint / clear were gleaned as an auto body guy, what about these wonderful wood working techniques?
Thanks.
I started building stuff out of wood as an early teen.
I was really into skateboarding and gravitated toward mostly halfpipes
After tooling around a little bit building small jump ramps and stuff my dad and I built a really nice ramp in my backyard since there was nowhere to go and skate back then.
It was 9 ft tall and 16 feet wide. I learned a lot not only doing the actual build but keeping it up for the three years I enjoyed it before I got a license and got into cars.
This page was printed from https://pinside.com/pinball/forum/topic/hep-this-week-9-17-18/page/28 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
