(Topic ID: 225528)
HEP This Week
By High_End_Pins
5 years ago
  • 14,136 posts
  • 633 Pinsiders participating
  • Latest reply 11 hours ago by Stretch7
  • Topic is favorited by 630 Pinsiders
Topic poll
“EBD Trim legs will be black regardless ”
  • Stainless/Factory 35 votes
    31%
  • Blacked out 54 votes
    48%
  • Painted Gold matched to cabinet 24 votes
    21%
(113 votes)
This poll has been closed.
204 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 14,136 posts in this topic. You are on page 273 of 283.
#13601 3 months ago
Quoted from mmr61184:
What’s your source for the original looking pricing and rules cards they look exact
I actually made those. Did it for my TZ too. The rules card is actually a little off, because they didn’t use bolding for Addams, but they did for TZ and I wanted the machine styles to match (since they’ll be sitting right next to each other).
#13602 3 months ago
Quoted from High_End_Pins:
Finished with this one. Will try to get some good final pictures of it up. [quoted image][quoted image][quoted image]
Absolutely frickin’ gorgeous.
#13603 3 months ago
I can’t tell in the pics…is the topper light working there?
#13604 3 months ago
Quoted from Jargus:
I packed those topper lights up to return them. They were not worth using. Only two lights run short alligator clips etc.
I would recommend the ones from Lee’s Parts. Much better. I would also recommend the yellow version not blue for a TAFG.
#13605 3 months ago
Unfortunate, but works for me.
15
#13606 3 months ago
TAFG JH finished.
image.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpg
#13607 3 months ago
TAFG JH playfield
image.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpg
#13608 3 months ago
TAFG JH inside.
#13610 3 months ago
As always, I’m speechless. Your work is absolutely impeccable. I certainly appreciate all the time it takes for the detailed photos. I look at each in detail and learn something new every time. Thanks for all you do in a hobby.
#13611 3 months ago
Are the magnet protection fuses in that block under the pf?
#13612 3 months ago
Quoted from jrcmlc:
Yeah he mentions it a page or so ago. I think he said the board requires smaller sized fuses so to cut down stocking different fuse types he puts in the holder
#13613 3 months ago
I assumed.. Much cleaner. Very cool.
Quoted from mmr61184:Yeah he mentions it a page or so ago. I think he said the board requires smaller sized fuses so to cut down stocking different fuse types he puts in the holder
#13614 3 months ago
You, sir, are the gold medal winner of pinball restoration (see what I did there?).
#13615 3 months ago
It might be worth a shot to try this stuff on an old clear ramp to see how it'd work on tinting a new one:
https://www.amazon.com/Krylon-K09037007-Stained-Glass-Aerosol/dp/B07H438FWB
It's pretty impressive stuff. I've used a few of the other colors on clear plastic items before and as long as you evenly coat what you're painting, you'd never know the plastic was ever clear. This source is quite pricey, but it's more to show the product. I'm sure you can find them elsewhere much cheaper.
#13616 3 months ago
Gutting the Fish…..Turd
IMG_3686 (resized).jpegIMG_3686 (resized).jpegIMG_3690 (resized).jpegIMG_3690 (resized).jpegIMG_3691 (resized).jpegIMG_3691 (resized).jpegIMG_3692 (resized).jpegIMG_3692 (resized).jpegIMG_3693 (resized).jpegIMG_3693 (resized).jpegIMG_3694 (resized).jpegIMG_3694 (resized).jpegIMG_3695 (resized).jpegIMG_3695 (resized).jpegIMG_3696 (resized).jpegIMG_3696 (resized).jpegIMG_3697 (resized).jpegIMG_3697 (resized).jpegIMG_3698 (resized).jpegIMG_3698 (resized).jpeg
#13617 3 months ago
It’s definitely been operated on the pier.
IMG_3805 (resized).jpegIMG_3805 (resized).jpegIMG_3818 (resized).jpegIMG_3818 (resized).jpegIMG_3820 (resized).jpegIMG_3820 (resized).jpegIMG_3821 (resized).jpegIMG_3821 (resized).jpegIMG_3822 (resized).jpegIMG_3822 (resized).jpegIMG_3824 (resized).jpegIMG_3824 (resized).jpegIMG_3825 (resized).jpegIMG_3825 (resized).jpegIMG_3826 (resized).jpegIMG_3826 (resized).jpegIMG_3827 (resized).jpegIMG_3827 (resized).jpegIMG_3829 (resized).jpegIMG_3829 (resized).jpeg
#13618 3 months ago
Worked the new cabinet and topper base over. Almost made a new one of those but it’s sanded out flush with some effort.
IMG_3779 (resized).jpegIMG_3779 (resized).jpegIMG_3806 (resized).jpegIMG_3806 (resized).jpegIMG_3807 (resized).jpegIMG_3807 (resized).jpegIMG_3808 (resized).jpegIMG_3808 (resized).jpegIMG_3812 (resized).jpegIMG_3812 (resized).jpegIMG_3815 (resized).jpegIMG_3815 (resized).jpegIMG_3816 (resized).jpegIMG_3816 (resized).jpeg
#13619 3 months ago
Primed and guidecoated. Topper base given a burial at sea. A sea of primer!
IMG_3842 (resized).jpegIMG_3842 (resized).jpegIMG_3843 (resized).jpegIMG_3843 (resized).jpegIMG_3846 (resized).jpegIMG_3846 (resized).jpegIMG_3847 (resized).jpegIMG_3847 (resized).jpegIMG_3849 (resized).jpegIMG_3849 (resized).jpeg
#13620 3 months ago
Cleared the playfield set one last time.
IMG_3792 (resized).jpegIMG_3792 (resized).jpegIMG_3793 (resized).jpegIMG_3793 (resized).jpegIMG_3794 (resized).jpegIMG_3794 (resized).jpegIMG_3796 (resized).jpegIMG_3796 (resized).jpegIMG_3797 (resized).jpegIMG_3797 (resized).jpeg
#13621 3 months ago
Quoted from RickyBobby1:
Excellent - thanks! After Chris posted what he used, I poked around pinside and came across your video and ordered the kit from Rampomatic - showed up today! I went ahead and got the hand-held vice type from pintonka.com. I won't be heavy into riveting so don't have the rivet press on my wish list.
I've done a couple of pins where I needed to rivet and of course turned to the devil and used pop rivets. I've been shown the way and re-doing those pins is first on my list. LOL
I did the same. I had Pintonka's vice but got the Rampomatic
[quoted image][quoted image][quoted image][quoted image][quoted image]
Nothing finer than a freshly cleared and buffed playfield.
#13622 3 months ago
That Fish...Turd was filthy, dirty, corroded, rusted and stretched springs galore. You got some serious tumbling and plating to go. But we know you are up to the task.
#13623 3 months ago
…Topper base given a burial at sea. A sea of primer
This is what I come here for, haha
Playfield looks amazing. Also, never realized Fish Tales had that incline/raised section in the back. Very cool.
#13624 3 months ago
Finished gutting the FT cabinet. IMG_3882 (resized).jpegIMG_3882 (resized).jpeg
I had a hell of a time getting the playfield out.
The stings on the playfield slides and the slides themselves are f:::ed!
IMG_3880 (resized).jpegIMG_3880 (resized).jpegIMG_3883 (resized).jpegIMG_3883 (resized).jpeg
#13625 3 months ago
Sanded the new cabinet and prepped all the accessories.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#13626 3 months ago
Painted all that.
Will flatten out as it dries.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
11
#13627 3 months ago
Just a few comments. If anyone would like to finance the production of smoked Addams toppers and TZ ramps, I'll be glad to make them. Let's look at the TZ ramp. Total cost to produce it is about $80. With a 20% mark-up, we would sell for $96. We get 300 ramps from the minimum order of PETG. So. that's $24000. You would have to sell 250 ramps just to break even. When I had smoked ramps, I sold 8 per year. That would be less now but let's use 8. It would take 31 years to get your money back. I haven't even added in the cost to ship the ramps, the box, etc. Like I said, contact me if you would like to finance the project.
There are basically 3 people in the US making ramps. None of us are doing this to make a living. If we were, ramps would cost a lot more. We do it because we love pinball and enjoy being part of the restoration team.
Pinball Inc's toppers are not polycarbonate. They are PETG. I know that because I manufacture them. Planetary Pinball, Little Shop of Games, and Marco Spec all carry my topper. On both TZ and TAF, I have told people take the clear. If you don't like it, send it back for a full refund. No one has sent it back. Coin Taker sells the black version topper but not smoked .Most people do not realize that making ramps is not a simple process.
#13628 3 months ago
Quoted from lrosent345:
Is there another process that can be done to smoke it? Flame it, paint it, etc.? Just a new guy helping think outside the box
#13629 3 months ago
Good info. No one is going to know someone else’s business nor trials and tribulations without living it or at least being told.
It does suck that we can’t afford nor justify the proper option.
#13630 3 months ago
The answer probably lies with a cooperation with another company that does use a lot of the product for a different purpose.
Would take some searching out through your material rep and a soft approach to buy some excess from the other company you are not in competition with.
#13631 3 months ago
Quoted from punkin:
We've tried that. Thanks for the response.
#13632 3 months ago
What about doing the opposite and running some previously clear ramps in the tinted material
#13633 3 months ago
Quoted from MiniPinHead:
you can dye it, but the result is usually moderate to poor as it very difficult to control the dye absorption.
Jody was dying some small parts for awhile with some limited success and random color variation.
I think the cloud topper would be too big to get an acceptable result.
#13634 3 months ago
I know I wouldn't expect to be able to buy that ramp for under $100...I'd expect it to be double that probably?
Quoted from lrosent345:Just a few comments. If anyone would like to finance the production of smoked Addams toppers and TZ ramps, I'll be glad to make them. Let's look at the TZ ramp. Total cost to produce it is about $80. With a 20% mark-up, we would sell for $96. We get 300 ramps from the minimum order of PETG. So. that's $24000. You would have to sell 250 ramps just to break even. When I had smoked ramps, I sold 8 per year. That would be less now but let's use 8. It would take 31 years to get your money back. I haven't even added in the cost to ship the ramps, the box, etc. Like I said, contact me if you would like to finance the project.
#13635 3 months ago
If you only had smoked, no one would/could buy clear so they would just buy smoked. The smoked should be the one to sell by default being it matches the original game. I hear the people who say clear is better, brightens up the game etc, but clear looks just as shitty as smoked when it gets old. I also don't think it looks great seeing all the wires, but I get that everyone doesn't think like me, I'm more of a purist and like to leave things original.
#13636 3 months ago
Quoted from NYP:
If you only had smoked, no one would/could buy clear so they would just buy smoked. The smoked should be the one to sell by default being it matches the original game. But I'm assuming you wouldn't buy the smoked material just for TZ or AF, aren't there many games (and toppers) that used smoked? I hear the people who say clear is better, brightens up the game etc, but clear looks just as shitty as smoked when it gets old. I also don't think it looks great seeing all the wires, but I get that everyone doesn't think like me, I'm more of a purist and like to leave things original.
Another option sometimes in these situations (I know HEP has done so on occasion in the past) is to create a themed ramp decal to obscure wiring/mechanics below the clear ramp. This is not always the answer for those purist who prefer OEM accurate restorations but can be an effective way to address the issue.
#13637 3 months ago
Been pretty quiet around here. Hope all is well and see you back here soon Chris.
10
#13638 3 months ago
Quoted from Stretch7:
Best I can do on short notice.
#13639 3 months ago
Amazing!
#13640 3 months ago
FT glitter (RK) playfield
image.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpg
#13641 3 months ago
FT RK inside
#13642 3 months ago
Turd no more!
13
#13643 3 months ago
Today. Couldn’t talk Curtis into taking his shirt off. IMG_4262 (resized).jpegIMG_4262 (resized).jpeg
But he was willing to take a BCBS flight with me.
#13644 3 months ago
Ha Ha all good.
That looks great...actually it looks perfect!
#13645 3 months ago
It’s art! Makes me appreciate what Williams did for pinball. Maybe someday they’ll get back into pinball.
#13646 3 months ago
Cheers buddy! Cute pics.
#13647 3 months ago
There’s a couple of cool dudes. Fun photos
That Fish Tales looks stunning!
#13648 3 months ago
FT was my first DMD game. Still one of my favorites! Very well done, as always!
#13649 87 days ago
High_End_Pins Chris, you see lots of games shipped in and out. Your clients are probably going to demand a shipper that takes extra special care of the game when it goes out. I have to ship a game that Bryan Kelly just finished up for me some of these beltman horror stories are definitely leaving me spooked. What are your clients using?
#13650 86 days ago
I recently shipped a game to Chris (he arranged the shipping), and have one in transit now, coming home from Chris. He used Beltmann for both.
$ 69.00
Pinball Pimp
Decorations
$ 54.99
Shooter rods
This page was printed from https://pinside.com/pinball/forum/topic/hep-this-week-9-17-18/page/273 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
