(Topic ID: 225528)
HEP This Week 3-27-23
By High_End_Pins
  • 12,244 posts
  • 587 Pinsiders participating
  • Latest reply 3 hours ago by runofkings
  • Topic is favorited by 575 Pinsiders
Topic poll
“EBD Trim legs will be black regardless ”
  • Stainless/Factory 35 votes
    31%
  • Blacked out 54 votes
    48%
  • Painted Gold matched to cabinet 24 votes
    21%
(113 votes)
This poll has been closed.
181 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 12,244 posts in this topic. You are on page 203 of 245.
12
#10101 1 year ago
Process videos for the SOF cabinet paint job.
#10102 1 year ago
Had to edit the video in the first link above. Didn’t realize that I hadn’t cut 5 minutes of down time out of it.
Video is corrected and link is fixed.
#10103 1 year ago
Tearing down the base SOF
#10104 1 year ago
Probably about to head back into the paint shop for a couple hours and see if I want to get further involved in my SOF cabinet paint job.
#10105 1 year ago
Took a few hours but I managed to get one side of the SOF cabinet detailed.
It’s doubtful I can do a mirror image of it on the other side but I have patterns and techniques dialed in so it can be consistent.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#10106 1 year ago
Darkened it up a bit and did both sides. Was able to make templates to get it consistent side to side.
Still need to figure out the head.
#10107 1 year ago
Quoted from High_End_Pins:
[quoted image][quoted image][quoted image][quoted image][quoted image]
Really like the look of the cracking.....the only suggestion I would make is to make the "Swords of Fury" lettering to match the translite. The way it was the same color blue it kinda gets lost, in a red/orange fade it would REALLY pop!!
#10108 1 year ago
Quoted from AUKraut:
I actually have something like that planned for the second SOF cabinet. This first one will be as close to correct as I can make it. That’s usually how I do things the first time just to set the bar then alternatives from there.
The second one will be more complex but after working through this first one I am not so sure I will do the second one any time soon.
This is a tough paint job as is.
#10109 1 year ago
Heads done on the SOF.
Should be ready for the final clear.
Placed the head on there to check for consistency.
#10110 1 year ago
Just marvel at the detail and craftsmanship.
#10111 1 year ago
Final clear is done on the SOF cabinet. It’s 60/40 gloss/matte.
Will gloss down as it dries.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#10113 1 year ago
Really been enjoying the video updates Chris. Thanks for those!
#10114 1 year ago
Chris
Question. If you are clearing the entire cabinet a matte finish, are you worried about the top of the lower cabinet being in gloss? I noticed in the video that the top of the lower cabinet is still taped up. I understand that the head will be on it but am curious.
Mike
#10115 1 year ago
Quoted from packie1:
Chris
Mike
No concerns with that.
It’s mostly covered by the rails and completely shadowed by the head.
The main reason you wouldn’t want to open that up for the final clear is that you would get debris coming out of the neck.
0F8DC763-29CC-4E03-AE03-6060B2003815 (resized).jpegC6F98D3E-700A-4956-9D67-CF0F9CA79C1D (resized).jpegBB85E9C4-3C9E-44BA-BF7A-AAADDD70A0E1 (resized).jpeg
#10116 1 year ago
Making good progress tearing down the SOF playfields.
Need to get my hands on those as soon as possible to start that process. Mylar,glue,insert wear etc.
045BE81D-8210-4D5D-8BAD-7B862C6C2F8D (resized).jpeg1C82AF55-FDB0-4EF3-AF0B-E13A5563ADA6 (resized).jpeg
#10117 1 year ago
Pure science and art; a perfect combination.
#10118 1 year ago
LIONMAN!!!!
(sorry couldn't help myself)
#10119 1 year ago
SOF cabinet graduates the HEP Institute of Paint and No Technology .
Much more similar than I thought although I was never expecting a truly exact copy.
BF6152D2-B841-422F-9857-C57157153E4B (resized).jpeg7E112CCA-95AE-4264-8017-80818B8F710D (resized).jpegAB0DBE40-85BD-4331-8A09-31DDB8D6CC05 (resized).jpeg
#10120 1 year ago
SOF main playfield is stripped snd ready for Mylar removal.
#10121 1 year ago
I prefer the bolder crack version. Reads better from a distance and up close.
#10122 1 year ago
Quoted from PinMonk:
"Swords of FuN"
#10123 1 year ago
Mylar is pulled from the main and glue removed. Playfield is prepped for the first clear. This will be light to hopefully avoid insert bubbles but it’s a system 11 so no guarantees. image (resized).jpg
It will need lots of repaints. Nothing major but tons of little things all over.
#10124 1 year ago
Mylar is pulled from the main and glue removed. Playfield is prepped for the first clear. This will be light to hopefully avoid insert bubbles but it’s a system 11 so no guarantees. [quoted image]
Shooter lane sanded up pretty well. [quoted image]
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Are you freehanding the text that's wiped out on "RELEASE" or are you making a stencil with your Silhouette and spraying it?
#10125 1 year ago
Definitely not freehanding it. My handwriting is very sloppy.
#10126 1 year ago
First clear is on the SOF playfield set.
It is sprayed pretty light the first time around to glue everything down and see how the inserts take the clear. Not much more than a clear primer at this point but it will give the foundation needed for the work to follow.
EB557E41-57E6-486D-9330-694DF69CBE6D (resized).jpeg170287F5-4EDB-442C-B716-3CF6E141FBB6 (resized).jpeg3A8B1A0C-AA50-4AE3-A6AB-3FAFC51CE73A (resized).jpeg7A724095-CA55-4CAC-871E-1001FEF8EC7A (resized).jpeg
#10127 1 year ago
this is where the man earns his title
#10128 1 year ago
Crazy to see the grooved horseshoe
#10129 1 year ago
SOF cabinet is braided and up on four legs.
#10130 1 year ago
Screened the back of the SOF head. E9E20F59-907D-4022-831B-0554C00E5F15 (resized).jpeg
Tore the coin door down and prepped that along with some other cabinet parts. D232B5A2-321F-41C2-8508-1CB00ABB6048 (resized).jpeg
All parts refinished appropriately.
4AC85738-305B-4581-9A33-385EFC0BDD62 (resized).jpegF4CD7412-2F78-47B0-8004-B78E6AA7B057 (resized).jpeg
#10131 1 year ago
Received my new SOF ramps from Freeplay40
SOF owner wants them black.
Plastic etched and sprayed the backside. 8D854AEA-F398-4768-81C5-7C1104C3A4B3 (resized).jpeg
No problem.
ACD22595-4EF8-45AA-BFA1-09CC9B5EAF6A (resized).jpegF0CA12A3-D52A-4C58-A3E8-2D846A4449BD (resized).jpeg
#10132 1 year ago
Now for the playfields.
Sanded painted the white. F962FA04-3292-454D-A2B2-7D32107489C7 (resized).jpeg
#10133 1 year ago
Then painted all the black with the exception of the inserts.
I don’t want to paint those or get too far into the details around them until I know they are level.
Masking all that black was very tedious and time consuming. 8AE4CF08-1D81-4681-A4DC-34C9DDE09326 (resized).jpeg
Forgot to take a picture of the black sprayed. Unmasked here
9A2AA0FC-57F1-428C-A958-C3ACAB6E4BE5 (resized).jpegA89449B5-B4E6-42E4-84F5-6DDFF5374190 (resized).jpegF16FCE2F-6354-451E-AAC1-9DDEBD321E96 (resized).jpeg
#10134 1 year ago
Cleared them. Starting to level out.
677A3BED-9AE7-48F7-9598-90BCCE88C91C (resized).jpeg2DD582F1-B544-4801-842C-0E3616C27C87 (resized).jpeg4FC684A1-8E7A-4EBD-8A4F-955A8DE3A126 (resized).jpeg5E039670-ABE3-45E6-A62A-BE597424BF6A (resized).jpeg810F54B2-635F-4649-9F06-6D1BC515C708 (resized).jpegEF20B3F5-32B3-4FE6-824E-4C7EB1A3A5D8 (resized).jpeg9983CC8B-C174-4880-B88E-BDBDC17D0ADA (resized).jpeg5B36D0B5-0CB2-4CB4-842B-1FCADD10B5D4 (resized).jpeg
#10136 1 year ago
Mylar removal etc video.
I was wondering how you were dealing with the bitterant because I recognized those cans and KNOW that brand uses bitterant - then I saw you had a mask.
I go out of my way to buy the brands that DO NOT add bitterant. I just refuse to buy the ones that do. They're terrible for freeze spray, and they leave residue on electronics if you use them as compressed air.
#10137 1 year ago
There is no dispute about the quality of this work. What really impresses me is the speed in which it is done.
This thread just astounds me.
Chris
#10138 1 year ago
Head is placed on lower of SOF. Coin door built.
#10139 1 year ago
Oh that rack of wire...
#10140 1 year ago
Quoted from cosmokramer:
How about that rack of playfields?
#10141 1 year ago
Got the WW cabinet prepped and primed. BC536C78-A297-4C7A-876E-73B155E3F1F0 (resized).jpegA0D22822-FBEB-4352-99BE-7F892EE2FA62 (resized).jpeg
91E37932-AC0F-429B-90AA-CA6664C07996 (resized).jpegDA0F06A6-4962-42A4-A4AE-C4C87206FCAC (resized).jpeg45E11FA5-CF70-40E0-A9FB-78295AF101A7 (resized).jpeg00E3ECB5-ECDB-4F2F-BC48-5287EC3416E3 (resized).jpeg
#10142 1 year ago
Sc cabinet decaled
Started prepping the new playfield for assembly.
#10143 1 year ago
Worked through the SOF coil assemblies.
95B3B2E4-BDAE-42DC-90DA-C009CC48F854 (resized).jpeg31628F2D-291E-4D8E-80AD-92834639ED02 (resized).jpeg045A3A0F-67B5-4D64-B878-045619285224 (resized).jpeg0EE3764A-2690-4AE0-BF72-E22711153078 (resized).jpeg9177F121-B86F-42CF-B620-32E6D4E2DBF5 (resized).jpeg578DE5F0-5F4F-4423-A58A-392FE8AC3985 (resized).jpeg62B75FF4-43B2-4B18-84C3-DFE1BD0A7F00 (resized).jpegABBE8837-5BE8-4172-9D81-6922E445984E (resized).jpegB34F04AA-E344-4B3A-B226-17209DA9AEE7 (resized).jpeg6D1A0792-7D36-40C5-ADCE-5E0781C609F5 (resized).jpegFC774952-26D9-4903-A794-057EB7755383 (resized).jpeg
#10144 1 year ago
Back to the playfield.
Sanded
Needed a little filler here. 991E262A-3751-43EE-9062-C65673520C7D (resized).jpeg
Cleaned masked off to do all/most of the red as well as the fades. Fighting ball swirl in some spots wear in others.
AB4F1C53-A5D7-46A6-A2E2-9CE35D2FA3C6 (resized).jpegFFEA3101-29F1-4020-912F-7FC34999C559 (resized).jpegCAECA377-9AB7-4E03-A030-1D1C4AA10F50 (resized).jpeg23BE4BED-60C2-46F5-A767-4040EB3AC96D (resized).jpeg
#10145 1 year ago
Red is sprayed then over masked to do the fades and transition into orange. 254C499C-A975-46FA-9BBD-1B24F4361CE1 (resized).jpeg3DE859C0-B423-4550-9F1A-827034826BA2 (resized).jpeg
Then unmasked. Will work on a few more colors in the coming days before the next clear application.
BCDBEB18-588D-4E3A-A616-AD36DAEC989E (resized).jpegF53B9AF2-2F12-47F2-9D7B-75684A670B97 (resized).jpegFBFF5AAC-9578-4AE2-A440-467BED0A7FBF (resized).jpeg7D9A0C32-C1EA-46C7-BDC9-547ED0D43567 (resized).jpeg85A8D92A-088F-40B0-9CCB-4E7E62E8D3DD (resized).jpeg
#10146 1 year ago
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Never seen an SOF before, that mech with the five coils is wild. Some weird drop target arrangement I guess?
#10147 1 year ago
I was thinking the same thing. I have had my hands or eyes on a lot of pins, but never seen or played a SOF in the wild. Definitely have to pop in to see the finished product.
#10148 1 year ago
Quoted from radium:
Alien Poker and Laser Cue have a similar 5 coil reset setup (and even wilder, in that there's a bar that knocks them all down, then pops them up for memory.) Jungle Lord probably has similar.
It's like this is SoF because as you are playing, each drop you hit down has an individual timer to pop back up. It makes it harder to keep the ball up on that mini playfield because if you hit them all down too quickly, you can't prevent the ball from exiting via a trough (often cracked and broken) behind the target bank.
A lot of people re-wire the right 2 targets onto the left 3 on the power feed because they think it's "wrong" that the drops have 2 different power feeds. Bad things happen when you do this as the right 2 are A/C controlled coils and the other 3 are normal coils.... the game just never works right after that.
One of mine way back when I owned it had this issue from a major pintailer so even the supposed pros make mistakes. It took forever to find without schematics (that retailer is infamous for never giving the manuals with their sales).
#10149 1 year ago
Painting away on the SOF playfield.
Definitely don’t miss dealing with these original non diamond plated System 11 playfields.
Had to use insert decals. Was trying to avoid that but as predicted the original insert art was just too fragile and quickly started pulling up far too easily during the masking process.
Hopefully it cooperates from here forward but they are pretty unpredictable.
DCA89175-0836-44A9-AACB-6AE76969CC21 (resized).jpeg59A6904B-000E-4B35-9343-25DCCB443B16 (resized).jpeg9EC7D592-D5D1-455D-B00D-CB4ADEFFE3B2 (resized).jpeg5A689912-99D5-4F93-A7EC-7D12D088EB6D (resized).jpeg3B3ACA5F-963D-441A-9026-DD95CA956BB6 (resized).jpegC2AB5884-50EA-4D83-8205-8DE2E5E99D6C (resized).jpegAA0DFA9C-680C-47D7-A02F-6F48B7219875 (resized).jpeg
#10150 1 year ago
Just wanted to say thank you for the videos you posted recently of your painting and sanding process. I find it super helpful to see someone do something like that, especially someone like yourself who really knows their stuff.
8,250
Bellevue, WA
$ 5.00
Metal-Mods
Decals
Professor Pinball
Interactive
This page was printed from https://pinside.com/pinball/forum/topic/hep-this-week-9-17-18/page/203 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
