(Topic ID: 225528)
HEP This Week 11-6-23
By High_End_Pins
5 years ago
  • 13,649 posts
  • 621 Pinsiders participating
  • Latest reply 35 minutes ago by mmr61184
  • Topic is favorited by 614 Pinsiders
Topic poll
“EBD Trim legs will be black regardless ”
  • Stainless/Factory 35 votes
    31%
  • Blacked out 54 votes
    48%
  • Painted Gold matched to cabinet 24 votes
    21%
(113 votes)
This poll has been closed.
194 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 13,649 posts in this topic. You are on page 200 of 273.
#9951 2 years ago
Quoted from Pin_Fandango:
I want to do this to my IJ and been practicing to crimp two cables in 1 cable and I failed miserably... wondering what the technic is... I am considering running a 3rd cable from the switch and use a 3 pin connector instead... but it is more work...
Twist the wires together then crimp.
Use a proper ratchet crimper and it makes a positive connection.
#9952 2 years ago
I know this is old and that Chris is not updating this thread, however, can someone provide first hand details on how to accurately measure the location of these holes? It seems obvious but then it is not really, for example, how do you find the absolute center of that hole to finish your measurement off.
thanks
This is what i use. Its incredibly handy, i use it all the time.
https://www.harborfreight.com/28-piece-transfer-punch-set-3577.html
#9953 2 years ago
Quoted from pinballinreno:
I do have the proper crimper, but The cables is too thick as you have now 2 insulations at the back. The terminals break.
I have also tried removing the insulation of one cable far back enough but the resulting crimp is very poor. I test my crimps with weights, if they can’t take 5-10 lbs of pull they are a fail.
These double crimps fail miserably for me on this test, so cant see how my crimps would fair after connecting disconnecting a few times.
#9954 2 years ago
I was referring actually to the action of measuring the center of an existing hole. How do you measure this when there is already a hole there, therefore, the void getting in the way of getting a proper and repeatable measurement?
Does he fill the holes and then measures?
Lol what is the technique.
#9955 2 years ago
Push the transfer punch into the hole from the bottom. The pointed end tells you the center.
And vice versa.
There are lots of sizes in the set.
I have never not found one to fit.
Its simple enough.
#9956 2 years ago
On a double insertion the insulation just goes up to the end but not inside.
Its works well, i convert many 3 wire to 2 wire.
#9958 2 years ago
I crimp two wires, solder to terminal. Makes a bulletproof connection. Minimalist solder obviously so pin can fit connector.
30
#9959 2 years ago
9840723B-02D9-4218-AED1-08FAC99788C9 (resized).jpeg9840723B-02D9-4218-AED1-08FAC99788C9 (resized).jpeg3B70B7C2-00B4-4AB8-9217-39793C5873AA (resized).jpeg3B70B7C2-00B4-4AB8-9217-39793C5873AA (resized).jpeg4697D2AA-AAF5-487A-8796-B1EF944926A8 (resized).jpeg4697D2AA-AAF5-487A-8796-B1EF944926A8 (resized).jpeg6F3BD525-D7F6-44F4-A046-58B359094A96 (resized).jpeg6F3BD525-D7F6-44F4-A046-58B359094A96 (resized).jpeg4C49DB15-533A-4E28-AF35-BA178320103D (resized).jpeg4C49DB15-533A-4E28-AF35-BA178320103D (resized).jpegF729BCBB-90EF-4605-AD28-4362A7C4EAFD (resized).jpegF729BCBB-90EF-4605-AD28-4362A7C4EAFD (resized).jpegC84A55AF-760A-4BF0-A405-D4548BB5F5F7 (resized).jpegC84A55AF-760A-4BF0-A405-D4548BB5F5F7 (resized).jpeg78DDF251-8BF3-45EF-B8C5-84A366164542 (resized).jpeg78DDF251-8BF3-45EF-B8C5-84A366164542 (resized).jpeg0746F64D-08F9-417F-AC24-4A0F2DC40C33 (resized).jpeg0746F64D-08F9-417F-AC24-4A0F2DC40C33 (resized).jpeg3114C7AC-67B1-4133-B800-618B46280B4F (resized).jpeg3114C7AC-67B1-4133-B800-618B46280B4F (resized).jpeg4F0EE987-836C-487E-B998-4B2AE5CAAA32 (resized).jpeg4F0EE987-836C-487E-B998-4B2AE5CAAA32 (resized).jpegA2F799B1-E1BC-41EB-8942-36A8C11B4069 (resized).jpegA2F799B1-E1BC-41EB-8942-36A8C11B4069 (resized).jpegD2107F98-CFCD-4734-B427-55857D6DAD1B (resized).jpegD2107F98-CFCD-4734-B427-55857D6DAD1B (resized).jpeg21E74A7A-6E22-4C4B-9A52-89CB3FB95DCA (resized).jpeg21E74A7A-6E22-4C4B-9A52-89CB3FB95DCA (resized).jpeg7C1F1647-DA0E-4A5E-B5E5-E97755865D5B (resized).jpeg7C1F1647-DA0E-4A5E-B5E5-E97755865D5B (resized).jpeg52028F00-C328-4E19-A0EA-6F8EE04DA93E (resized).jpeg52028F00-C328-4E19-A0EA-6F8EE04DA93E (resized).jpeg0944B0FB-DEB6-4E6C-A3C0-6E9A47775C22 (resized).jpeg0944B0FB-DEB6-4E6C-A3C0-6E9A47775C22 (resized).jpegFC3B283A-9715-4755-9EE1-B7A5946677AE (resized).jpegFC3B283A-9715-4755-9EE1-B7A5946677AE (resized).jpeg41108BC5-2130-43C2-97E2-014A8E2FFA04 (resized).jpeg41108BC5-2130-43C2-97E2-014A8E2FFA04 (resized).jpeg6EF14AA0-A376-466B-B45C-688B6B4D6C23 (resized).jpeg6EF14AA0-A376-466B-B45C-688B6B4D6C23 (resized).jpeg2D324A41-F2E8-4CEE-A3AA-0CCABD91285D (resized).jpeg2D324A41-F2E8-4CEE-A3AA-0CCABD91285D (resized).jpeg62055FFC-0489-4815-AC5C-3CA49EF7B8F2 (resized).jpeg62055FFC-0489-4815-AC5C-3CA49EF7B8F2 (resized).jpegA4E1882D-BBFF-4FD7-9B09-B90434FD8FAB (resized).jpegA4E1882D-BBFF-4FD7-9B09-B90434FD8FAB (resized).jpeg66C74D0F-DA46-476F-AC38-81E81DFA0CEA (resized).jpeg66C74D0F-DA46-476F-AC38-81E81DFA0CEA (resized).jpeg0924802B-0357-429D-A481-2B28977C86A5 (resized).jpeg0924802B-0357-429D-A481-2B28977C86A5 (resized).jpeg547B0641-8DA8-4116-B937-26E537C5FBE5 (resized).jpeg547B0641-8DA8-4116-B937-26E537C5FBE5 (resized).jpeg043F3B86-5591-4618-B0F1-1F0B43F2A3A0 (resized).jpeg043F3B86-5591-4618-B0F1-1F0B43F2A3A0 (resized).jpegFE41040A-0267-465A-92B0-AE3993B90316 (resized).jpegFE41040A-0267-465A-92B0-AE3993B90316 (resized).jpeg768AD0A9-E693-4E20-8D0D-CE5D90CD8983 (resized).jpeg768AD0A9-E693-4E20-8D0D-CE5D90CD8983 (resized).jpegA7EF4313-0F26-43F4-A0B5-C4DB66E3AA99 (resized).jpegA7EF4313-0F26-43F4-A0B5-C4DB66E3AA99 (resized).jpeg5FBD52EF-F789-49B1-946D-1BB07EEF77BB (resized).jpeg5FBD52EF-F789-49B1-946D-1BB07EEF77BB (resized).jpeg
#9960 2 years ago
Quoted from High_End_Pins:
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Looks amazing! Welcome back!
15
#9961 2 years ago
B3AB6077-83F4-4DBD-A425-5D36B72E31D9 (resized).jpegB3AB6077-83F4-4DBD-A425-5D36B72E31D9 (resized).jpeg93B92FAE-D522-4DBC-A785-7355E86DA12D (resized).jpeg93B92FAE-D522-4DBC-A785-7355E86DA12D (resized).jpeg0875B4CD-2910-468B-8166-AA9274CD698F (resized).jpeg0875B4CD-2910-468B-8166-AA9274CD698F (resized).jpeg7F4B1696-7395-4031-9804-AB7062F1AF21 (resized).jpeg7F4B1696-7395-4031-9804-AB7062F1AF21 (resized).jpeg2BB68EF1-EF64-4514-BF7B-C450ED4E11D9 (resized).jpeg2BB68EF1-EF64-4514-BF7B-C450ED4E11D9 (resized).jpegBD691DA4-4E6F-4998-B658-C129A21C6A11 (resized).jpegBD691DA4-4E6F-4998-B658-C129A21C6A11 (resized).jpeg00C4B683-1BE3-403D-9765-BFBD6DE75DCB (resized).jpeg00C4B683-1BE3-403D-9765-BFBD6DE75DCB (resized).jpeg7207A964-9C6E-4798-BE3B-CE15681B2697 (resized).jpeg7207A964-9C6E-4798-BE3B-CE15681B2697 (resized).jpegDFFFF1EA-054E-4FCF-846C-BA94ECF128B4 (resized).jpegDFFFF1EA-054E-4FCF-846C-BA94ECF128B4 (resized).jpegA254EE38-876D-428C-8499-2BC0533A45AE (resized).jpegA254EE38-876D-428C-8499-2BC0533A45AE (resized).jpeg6239E886-D076-4B8F-93E4-74AB17673350 (resized).jpeg6239E886-D076-4B8F-93E4-74AB17673350 (resized).jpeg8F28174C-CC76-4812-AC7D-FE7CA5DE5657 (resized).jpeg8F28174C-CC76-4812-AC7D-FE7CA5DE5657 (resized).jpeg40208472-5EB2-4460-9229-1F2057B315FA (resized).jpeg40208472-5EB2-4460-9229-1F2057B315FA (resized).jpeg37BE2025-E7AC-4D67-8838-0458AE8B9FBB (resized).jpeg37BE2025-E7AC-4D67-8838-0458AE8B9FBB (resized).jpeg3FF443AD-D728-439C-A7CF-D07FC715F079 (resized).jpeg3FF443AD-D728-439C-A7CF-D07FC715F079 (resized).jpegF0637A47-337D-4CAF-A2B0-277E82D7EE84 (resized).jpegF0637A47-337D-4CAF-A2B0-277E82D7EE84 (resized).jpeg3C2F2BD2-F08E-404E-A5EE-ABA9B9674461 (resized).jpeg3C2F2BD2-F08E-404E-A5EE-ABA9B9674461 (resized).jpegA46ACC35-E42E-40E7-998B-5833243D0C8E (resized).jpegA46ACC35-E42E-40E7-998B-5833243D0C8E (resized).jpeg7D12C2C7-A112-461C-B4A0-BCA13133EDA3 (resized).jpeg7D12C2C7-A112-461C-B4A0-BCA13133EDA3 (resized).jpeg0B3A7768-4E70-40D3-B7A0-06BF0AE2D692 (resized).jpeg0B3A7768-4E70-40D3-B7A0-06BF0AE2D692 (resized).jpeg
12
#9962 2 years ago
E77BF3DB-2866-4924-8CE1-03E9B666DC7F (resized).jpegE77BF3DB-2866-4924-8CE1-03E9B666DC7F (resized).jpegEF10A224-DF1A-4C89-9797-0C54D26EF5FC (resized).jpegEF10A224-DF1A-4C89-9797-0C54D26EF5FC (resized).jpeg143394DA-345F-43BE-A1F0-6C9F1E0DE065 (resized).jpeg143394DA-345F-43BE-A1F0-6C9F1E0DE065 (resized).jpegD00DE750-3E46-41F1-8F86-50BB4675CEA9 (resized).jpegD00DE750-3E46-41F1-8F86-50BB4675CEA9 (resized).jpegB9CD39D1-A840-4C96-97CF-54DB730891A9 (resized).jpegB9CD39D1-A840-4C96-97CF-54DB730891A9 (resized).jpegE74D8292-CE97-49CA-A235-7BAFAF129E4E (resized).jpegE74D8292-CE97-49CA-A235-7BAFAF129E4E (resized).jpeg616F81E5-CCA2-4291-8469-04CE23612CDB (resized).jpeg616F81E5-CCA2-4291-8469-04CE23612CDB (resized).jpeg243D08E5-6E13-4B2E-834A-2B53E5CCFCDE (resized).jpeg243D08E5-6E13-4B2E-834A-2B53E5CCFCDE (resized).jpeg18A47189-BFDD-4149-BFE4-984AF1A3D55A (resized).jpeg18A47189-BFDD-4149-BFE4-984AF1A3D55A (resized).jpegB619F43F-036A-43E1-8550-EE1E7CBF219E (resized).jpegB619F43F-036A-43E1-8550-EE1E7CBF219E (resized).jpegFC65B0AC-9E4E-471D-B214-BDA6124DCC66 (resized).jpegFC65B0AC-9E4E-471D-B214-BDA6124DCC66 (resized).jpeg1393C792-23FB-4332-A3F5-D59A3206D5F8 (resized).jpeg1393C792-23FB-4332-A3F5-D59A3206D5F8 (resized).jpeg0DA36A8D-8260-4A8B-BB4D-C2A47F896335 (resized).jpeg0DA36A8D-8260-4A8B-BB4D-C2A47F896335 (resized).jpegBB69409B-DCAE-4441-850D-732A2C13DE8E (resized).jpegBB69409B-DCAE-4441-850D-732A2C13DE8E (resized).jpeg02705370-DA23-44D8-814D-071267671B47 (resized).jpeg02705370-DA23-44D8-814D-071267671B47 (resized).jpegF3A527C3-8748-4F34-8FC4-C9EE6383FB56 (resized).jpegF3A527C3-8748-4F34-8FC4-C9EE6383FB56 (resized).jpeg
#9963 2 years ago
He's back!
#9964 2 years ago
I have to put on a drool bib every time I look at that CV!
#9965 2 years ago
That CV is amazing.
#9966 2 years ago
Quoted from NC_Pin:
That CV is amazing.
Some people buy artwork to hang on their walls, to me Chris’s restoration’s are functional art.
#9967 2 years ago
THE KING HAS RETURNED!
And seriously, those color choices. I don't know why I never imagined CV having anything other than the stock colors, but those flippers and posts really go with the color scheme.
15
#9968 2 years ago
06BA275F-94F4-4E55-803C-3B24AC040A58 (resized).jpeg06BA275F-94F4-4E55-803C-3B24AC040A58 (resized).jpeg239A40C3-D3AA-4592-B4D4-647175AD5627 (resized).jpeg239A40C3-D3AA-4592-B4D4-647175AD5627 (resized).jpegA569AED4-4EA6-4DA8-B9AA-8EE3BCC599C1 (resized).jpegA569AED4-4EA6-4DA8-B9AA-8EE3BCC599C1 (resized).jpeg11AD75E1-A26C-4EBE-95FB-1D47E1DDF666 (resized).jpeg11AD75E1-A26C-4EBE-95FB-1D47E1DDF666 (resized).jpeg3E928229-FC3B-46C6-BE07-4878C1DC1C74 (resized).jpeg3E928229-FC3B-46C6-BE07-4878C1DC1C74 (resized).jpeg71E4E25F-1A4F-42BD-9026-65F5CFBBEC36 (resized).jpeg71E4E25F-1A4F-42BD-9026-65F5CFBBEC36 (resized).jpegCEC08E03-1C5F-4DE9-BE18-5FA6ED788E79 (resized).jpegCEC08E03-1C5F-4DE9-BE18-5FA6ED788E79 (resized).jpeg097C2FE6-485B-4234-B105-43D96C0C0A49 (resized).jpeg097C2FE6-485B-4234-B105-43D96C0C0A49 (resized).jpeg4F6685BF-5583-410F-9B1B-B85F581044D8 (resized).jpeg4F6685BF-5583-410F-9B1B-B85F581044D8 (resized).jpeg50BD9A39-47CA-48A3-9470-B65934021F42 (resized).jpeg50BD9A39-47CA-48A3-9470-B65934021F42 (resized).jpeg405B0B65-F937-4564-909E-2D46A2A4D446 (resized).jpeg405B0B65-F937-4564-909E-2D46A2A4D446 (resized).jpeg463361FD-438A-40E2-8C1A-933597920939 (resized).jpeg463361FD-438A-40E2-8C1A-933597920939 (resized).jpegFCFEF3DA-BE65-4B0E-A8BC-BD02EF080DB9 (resized).jpegFCFEF3DA-BE65-4B0E-A8BC-BD02EF080DB9 (resized).jpeg8DC6F321-AEBB-4641-A018-FE305F0BE217 (resized).jpeg8DC6F321-AEBB-4641-A018-FE305F0BE217 (resized).jpeg984B1754-933C-462D-A420-A0DB0974263B (resized).jpeg984B1754-933C-462D-A420-A0DB0974263B (resized).jpegC4891710-A01D-41B7-8030-C4E69ADBA8D2 (resized).jpegC4891710-A01D-41B7-8030-C4E69ADBA8D2 (resized).jpeg704C3125-91A3-4808-9745-A2C9FE21CB20 (resized).jpeg704C3125-91A3-4808-9745-A2C9FE21CB20 (resized).jpeg0954CF66-890B-4DB4-9450-7FB6C2E8E8DC (resized).jpeg0954CF66-890B-4DB4-9450-7FB6C2E8E8DC (resized).jpeg7477B2A8-3820-4E31-BB9F-A3CDDDF52F10 (resized).jpeg7477B2A8-3820-4E31-BB9F-A3CDDDF52F10 (resized).jpeg7790B7BE-DD8F-4659-86FC-D2D077103A26 (resized).jpeg7790B7BE-DD8F-4659-86FC-D2D077103A26 (resized).jpeg71BB8E98-990C-4B2E-AE91-E32B7ACFA219 (resized).jpeg71BB8E98-990C-4B2E-AE91-E32B7ACFA219 (resized).jpegB0677021-22C0-42B6-B62A-15A28D11C288 (resized).jpegB0677021-22C0-42B6-B62A-15A28D11C288 (resized).jpegAA7ABF02-AF5D-4C72-88B2-3089457A1547 (resized).jpegAA7ABF02-AF5D-4C72-88B2-3089457A1547 (resized).jpeg51D76939-423F-4761-B950-CC3C26ADFC71 (resized).jpeg51D76939-423F-4761-B950-CC3C26ADFC71 (resized).jpeg92A3A489-F7D9-47DB-9C89-A0CCF45F064D (resized).jpeg92A3A489-F7D9-47DB-9C89-A0CCF45F064D (resized).jpeg6F87313E-F15F-4D95-9A5D-EAE85BF2B08E (resized).jpeg6F87313E-F15F-4D95-9A5D-EAE85BF2B08E (resized).jpeg3FBC0CB5-5519-4EE1-8135-A873C070A804 (resized).jpeg3FBC0CB5-5519-4EE1-8135-A873C070A804 (resized).jpeg5AE9C0ED-9A26-4ACF-92FE-0C87230BE9F7 (resized).jpeg5AE9C0ED-9A26-4ACF-92FE-0C87230BE9F7 (resized).jpeg
#9969 2 years ago
1300D07B-0C65-4148-8BE8-DE0E54778596 (resized).jpeg1300D07B-0C65-4148-8BE8-DE0E54778596 (resized).jpeg29C8F153-066D-48A2-822C-F073C760AC94 (resized).jpeg29C8F153-066D-48A2-822C-F073C760AC94 (resized).jpeg09825AD3-8276-4959-B117-FE473D7ACD03 (resized).jpeg09825AD3-8276-4959-B117-FE473D7ACD03 (resized).jpegE9E76E6B-D6AD-4AE2-BFB4-BA2CE746000B (resized).jpegE9E76E6B-D6AD-4AE2-BFB4-BA2CE746000B (resized).jpegF4DA1A1C-539C-4C9E-9386-A67BC5A8D4B2 (resized).jpegF4DA1A1C-539C-4C9E-9386-A67BC5A8D4B2 (resized).jpegE4E2E960-1290-4955-843A-AFB1330870CE (resized).jpegE4E2E960-1290-4955-843A-AFB1330870CE (resized).jpeg416CC88C-AB7F-4394-BCEC-A42F1539156D (resized).jpeg416CC88C-AB7F-4394-BCEC-A42F1539156D (resized).jpegDFDDBB22-9FFD-49C5-8F0B-F2539CB261FB (resized).jpegDFDDBB22-9FFD-49C5-8F0B-F2539CB261FB (resized).jpegACCA6F68-DB96-4B1B-A893-6B0FD904346B (resized).jpegACCA6F68-DB96-4B1B-A893-6B0FD904346B (resized).jpegE0083B4D-0769-444E-A083-2E5C6E486736 (resized).jpegE0083B4D-0769-444E-A083-2E5C6E486736 (resized).jpegB25996BF-E02E-4486-994A-2594B5CE8A0F (resized).jpegB25996BF-E02E-4486-994A-2594B5CE8A0F (resized).jpegFE174E45-C614-4068-AB9C-EBDF8E838E04 (resized).jpegFE174E45-C614-4068-AB9C-EBDF8E838E04 (resized).jpeg85D6D198-A037-4627-890A-DC902EFE6C38 (resized).jpeg85D6D198-A037-4627-890A-DC902EFE6C38 (resized).jpegB8A9F248-EC89-4A06-BA31-A1E235206BCC (resized).jpegB8A9F248-EC89-4A06-BA31-A1E235206BCC (resized).jpegF3B72A7A-6F5A-4EA6-8619-4753330A94FB (resized).jpegF3B72A7A-6F5A-4EA6-8619-4753330A94FB (resized).jpeg2B983C3A-6EAB-40D9-BA15-86734828D85D (resized).jpeg2B983C3A-6EAB-40D9-BA15-86734828D85D (resized).jpeg425D45DD-DECD-4E03-B6DC-FC0D8901673E (resized).jpeg425D45DD-DECD-4E03-B6DC-FC0D8901673E (resized).jpeg74E82FEB-F2BD-4C28-A8CA-76E9B9EB69A9 (resized).jpeg74E82FEB-F2BD-4C28-A8CA-76E9B9EB69A9 (resized).jpeg3B05DAEF-16A1-4CCA-BD4A-FAA1A7634C71 (resized).jpeg3B05DAEF-16A1-4CCA-BD4A-FAA1A7634C71 (resized).jpeg97F17B73-D1E9-41BD-9963-62C49123DF03 (resized).jpeg97F17B73-D1E9-41BD-9963-62C49123DF03 (resized).jpegF141D8C9-DFDA-45F8-9CA9-114349F2F8A4 (resized).jpegF141D8C9-DFDA-45F8-9CA9-114349F2F8A4 (resized).jpeg5C01CB7F-DF31-43E0-94DF-D1C982503510 (resized).jpeg5C01CB7F-DF31-43E0-94DF-D1C982503510 (resized).jpeg70074D89-4FFC-434E-B6B2-4F75B1530464 (resized).jpeg70074D89-4FFC-434E-B6B2-4F75B1530464 (resized).jpeg3EEA1723-C0D3-4433-BE2F-FA6CF1330341 (resized).jpeg3EEA1723-C0D3-4433-BE2F-FA6CF1330341 (resized).jpeg
#9970 2 years ago
I'm pretty excited about the new Godzilla pin, but I'm much more excited about the revival of this thread!
Welcome back and thanks for sharing!
11
#9971 2 years ago
36A9DA2C-83CE-4B46-AC77-41F09496B6D8 (resized).jpeg36A9DA2C-83CE-4B46-AC77-41F09496B6D8 (resized).jpeg9882B202-3EFF-48B7-8F88-5C11B6FD9883 (resized).jpeg9882B202-3EFF-48B7-8F88-5C11B6FD9883 (resized).jpeg811B8C02-7815-4912-9F29-D0B8A52F51F7 (resized).jpeg811B8C02-7815-4912-9F29-D0B8A52F51F7 (resized).jpegC9651144-FF5A-4C2C-B43F-59DF4A8B8D66 (resized).jpegC9651144-FF5A-4C2C-B43F-59DF4A8B8D66 (resized).jpeg7B3AB1D6-2BCC-4520-A4DA-FB7288630E3B (resized).jpeg7B3AB1D6-2BCC-4520-A4DA-FB7288630E3B (resized).jpegD6A964B6-73D5-407D-B82A-02ADFF1DFE37 (resized).jpegD6A964B6-73D5-407D-B82A-02ADFF1DFE37 (resized).jpegE53A9EC0-9959-4D73-9BEA-2176CCFB0E89 (resized).jpegE53A9EC0-9959-4D73-9BEA-2176CCFB0E89 (resized).jpeg14DA8755-D182-4B7B-B468-C495CF49E2B0 (resized).jpeg14DA8755-D182-4B7B-B468-C495CF49E2B0 (resized).jpeg373A8B7D-D7D2-46C2-98A8-D087C4935BEC (resized).jpeg373A8B7D-D7D2-46C2-98A8-D087C4935BEC (resized).jpeg0242C964-FF30-4F68-B2C1-010AFAFD8558 (resized).jpeg0242C964-FF30-4F68-B2C1-010AFAFD8558 (resized).jpegD2C9AA34-0E3E-4820-B5D0-1C7E499EA497 (resized).jpegD2C9AA34-0E3E-4820-B5D0-1C7E499EA497 (resized).jpegD2260A65-3C29-472D-9BF8-57F7BA1AA02A (resized).jpegD2260A65-3C29-472D-9BF8-57F7BA1AA02A (resized).jpegCF3FDB91-53CA-4890-AEFD-6B1D914A3B99 (resized).jpegCF3FDB91-53CA-4890-AEFD-6B1D914A3B99 (resized).jpeg1C309588-C414-4DD2-8F64-EFA6C8428489 (resized).jpeg1C309588-C414-4DD2-8F64-EFA6C8428489 (resized).jpeg3A12DBC6-1325-484F-9533-B255E7897F53 (resized).jpeg3A12DBC6-1325-484F-9533-B255E7897F53 (resized).jpeg6B6B28BC-4B51-44BC-98A2-7C064BC7309D (resized).jpeg6B6B28BC-4B51-44BC-98A2-7C064BC7309D (resized).jpeg
#9972 2 years ago
Oh man, I really might have to send my MM back through for the chrome treatment. Damn.
—Donnie
#9973 2 years ago
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#9974 2 years ago
Chris gets more done in a month than I would in three years.
#9975 2 years ago
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#9976 2 years ago
He’s back…but the Pics speak for themselves. No words necessary from THE HEP.
#9977 2 years ago
Every time I see your photos it makes me want to take my pins outside, but then I think all that would do is highlight all of the imperfections. Not only is your work world-class, but you have the cojones to display your work with high quality photos in the best lighting possible.
#9978 2 years ago
Chrome is the best choice for CV. Accents the neon and bright colors of the cab and playfield perfectly.
28
#9979 2 years ago
Ok yes I am back.
Had to put some pictures up real quick this morning to close out where I left off,let it be known and get the thread heading back the right direction before the riff raff took it over
Planned a bit more of a grandiose return but this one will have to do.
#9980 2 years ago
Glad to see the thread back up and running.
Hope you get those galleries on your website back online too!
#9981 2 years ago
Such a cool picture!
2910E88B-C7BE-454B-99C8-CF19D87B059B (resized).jpeg2910E88B-C7BE-454B-99C8-CF19D87B059B (resized).jpeg
#9982 2 years ago
Quoted from radium:
I hope so. I spent $1000 with my web lady upgrading it and it has been not so easy. Still doesn’t seem to work right yet.
That is an old platform and the designers have abandoned it but I have so much content and money invested in it over the years I am trying to salvage and upgrade it to whatever is the latest version available.
#9983 2 years ago
awesome work. been following your YouTube a lot, sorry for the multitude of questions (lol)... not sorry. love your work!
#9984 2 years ago
the live takes on YT were pretty interesting too, i'll take anything you have time for, such impressive work!
#9985 2 years ago
Quoted from hisokajp:
Thanks.
I am starting to get a comfort level with that.
Lots of good stuff coming up there too.
#9986 2 years ago
Kicking off my last SC project.
This one should be pretty easy. I have an NOS playfield for it that I have already cleared sanded and polished. image (resized).jpgimage (resized).jpg
Right now I am just removing complete assemblies so I can get the cabinet stripped and ready to prime. image (resized).jpgimage (resized).jpg
One of the nice things about SC is that the playfield can easily be removed and set aside as an assembly.
#9987 2 years ago
I really liked your YT videos Chris, especially your elaborations on your train of thought/rational. BUT... the multiple segments per day have a consequence of 'lots of choices, not sure what to watch'. I know it makes it easier to make short clips... but without any descriptions or lead-in to know what the scope of the video is, when there is alot of them, people are less likely to click through and watch. "too many choices, not sure which..." etc. Some lead in to know what the clip will be about would help.
Thanks again as always for your continued efforts to document and share your approach to things.
#9988 2 years ago
SC cabinet is gutted and being stripped.
#9989 2 years ago
Quoted from flynnibus:
Thanks for the feedback I will give that a try on a few.
Often I don’t know myself though because there will be multiple things in a single update but most of these videos will be deleted or made private after a week or two.
Reason being they are tied to certain projects or processes that become less relevant as they progress.
#9990 2 years ago
No complaints here.I've enjoyed and look forward to watching these ! Thanks for doing this!
#9991 2 years ago
Works for me, I like the short videos. Just do whatever works for you and your schedule.
#9992 2 years ago
Quoted from mollyspub:
Quoted from killerrobots:
Appreciate it. The Q&A seems to be the most popular overall so will need more questions for that.
#9993 2 years ago
I don't want to direct you one way or the other but if you are looking for questions here are some things that interest me:
- I was interested in seeing you use a silk screen for the back-box warning and was wondering if that was something a casual restorer should look into or if that is best left to the pros.
- It seems like you you aren't doing a lot of playfield repainting but if you every did one I would love to see details about what paint you use, what masking material, and how you deal with waterslides/decals over inserts...
- It would be interesting to see your opinions on the pros/cons for various plating and powdercoating options.
- Maybe more of a philosophical one but when doing a restoration how do you know when to stop....what is adding value and what is diminishing returns. How much effort to put in to areas know one will see. How do you gage what is good enough? What is absolutely necessary and what is just gilding?
#9994 2 years ago
That is pretty much all stuff that's been asked and answered here. Just saying as this is the only media i'll be using.
#9995 2 years ago
Quoted from punkin:
If you have better question then maybe you should ask them?
Seriously, what is the point of this post? Good for you asked your questions two years ago and can't figure out youtube.
#9996 2 years ago
Enjoy your day mate, can't see us reaching any understanding.
#9997 2 years ago
All fine questions but I should have clarified to put them in the comments portion of the Q&A videos.
I don’t want to clutter Pinside with YT stuff.
#9998 2 years ago
Quoted from punkin:
Thanks for keeping your cool and this in check Punkin.I would hate to see it go off the rails.
I am going to try to get it carrying on once again as it was.
#9999 2 years ago
Chris: you’ve mentioned several times about deleting these videos on YouTube after a certain time. Please don’t! They, just like this thread and previous threads, are a treasure trove of information that is hobbyists use to help with our projects.
#10000 2 years ago
Have a few of the more game specific ones left to do. image (resized).jpgimage (resized).jpg
Started building up the TZ playfield. image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
Cabinet for that is ready to go.
$ 399.00
Decals
$ 18.95
$ 18.00
Other
West Chicago, IL
$ 135.00
Sparky Pinball
Toys/Add-ons
$ 1,059.00
Flipper parts
$ 45.00
2,999 (Firm)
Port Charlotte, FL
YouBentMyWookie
Other
£ 38.00
Metal-Mods
Decals
$ 18.50
Playfield - Plastics
Plastics
3,800 (Firm)
Fredericksburg, VA
$ 9.95
$ 10.95
$ 17.00
Nordic Pinball Supply
Decals
Pinball Photos LLC
Decorations
Protection
$ 5.00
Toys/Add-ons
$ 54.99
Shooter rods
$ 9.95
Protection
11,599 (Firm)
Rochester, MN
$ 32.00
Toys/Add-ons
$ 24.95
Protection
$ 25.99
Lee's Parts
Led
Other
This page was printed from https://pinside.com/pinball/forum/topic/hep-this-week-9-17-18/page/200 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
