Quoted from High_End_Pins:
Lol!
No can’t deliver this one in person it is going all the way across the country to CA.
Wish I could hand deliver and set up each and every one.
This is news to me.
HAD I KNOWN....!!!
—Donnie
Lol!
This is news to me.
HAD I KNOWN....!!!
—Donnie
Quoted from vireland:
Are you using an LED OCD to make the insert LEDs attack and decay more naturally? I love that product. Spectacular results.
Pardon my ignorance, What is LED OCD?
Mike
Quoted from packie1:
Mike
I was looking that very subject up this morning at 0247.
http://www.ledocd.com
Wow! I can't get over how clear your playfield window is. It looks like glass. Thanks for the close up shots of those silicon caps! Nice to see them installed in proper sequence too!
Quoted from Fifty:
Thanks. I polished that. It probably will show a scuff here or there after a few plays but it is nice to at least capture it in the best form possible.
I found a good work around to the white bulb caps .As predicted the few I had were yellowed.It isn’t a common part here always an afterthought .
I capped everything but the white ones and used the frosted LEDs in natural form for those locations.
Maverick settled into a comfortable spot and fell asleep. Definitely a shop dog
Is that Olson's CFTBL high_end_pins ? If so - I assume that's my MRS in the bowl? How'd it work?
Matt
Mike
It's a board that controls the LED bulb timing when they're put in old B/W machines (and some Stern) not designed for LEDs. Makes the bulbs fade on and off smoothly instead of blinking on and off abruptly. Fixes attract mode light shows that LED bulbs break. You can adjust the timings to your taste. Really a fantastic product. Worth every penny.
Quoted from mikepmcs:
Thanks! And now I know and Knowing is half the Battle! GI JOE!
F-ng Cyclopes playfield is killing me.
Sanded
Tried reworking those sloppy off registration inserts a bit more. 1E53B946-225C-444D-948E-A8C0DE0F3455 (resized).jpeg
Looks a little better. Really limited on these because of the way the art is shifted. 49FD1CFE-88FF-4B3C-BE71-6CBE6D149A5F (resized).jpeg
Cleared again That’s it for it regardless of outcome it is massively improved.
Quoted from yancy:
I see hot dogs below the E-Y-E-S inserts and now I can't unsee it.
That’s how the Cyclopes lure the big blocks
Now you understand how those women ended up on their knees with their draws halfway off their butts. Pure battle of attrition.
Quoted from yancy:
Thanks a lot for pointing that out. Now I can't unsee it either...
Wow, I don't think I've ever heard you almost curse before!
Quoted from jaytrem:
I just try to keep it clean so I can pass for the public eye. I am cursing internally at these things all day long! This Cyclopes has been a journey only second to that woodrail. 2020!!!!
Tasty beer thirty. Living high on the hog on this one. On a Belgian kick right now.
Quoted from Sonic:
Matt
That is definitely your MRS.
it fit and stuck to the bowl perfectly.
I would absolutely recommend it.
So much better than the blade switch.
That plus Swinks decal really cleans the bowl up
I’m happy to see you like Belgian beer , must be hard to order I guess
By the way, gorgeous restoration like always !
I noticed in your Addams Family Video Updates™️ that you don't recommend using a beefed up speaker in the in cabinet woofer. Curious which speakers you DO use and recommend as the "stock" speakers for WPC games, Pre and Post DCS sound board?
Quoted from radial_head:
I usually use the stock speaker if it is there and in good shape on those games.
If not then the Flipper Fidelity standard speaker upgrade works well and is wired color/style correct.
Just the standard version though not the powered or ones with crossovers.
Those just don’t sound as good or better to my ears than the stock or simple versions.
There are probably lots of speakers out there that would do the job but I try to stay within the pinball community where I can.
New week.
Hopefully it will be more productive than last week.
This guy didn’t make the final cut here but I am returning it in case the owner would like to use it. image (resized).jpg
I just about have the Cyclopes cabinet built up.
Quoted from NC_Pin:
Chris, I can't find any information on Cyclopes. Was this a prototype that never went into production?
I decided to put a little extra touch on the Cyclopes cabinet by painting the older shooter housing snd shooter rod to match the cabinet art. B3F8DF1F-AFEB-43FB-A798-7FA7CC99B79A (resized).jpeg
I also got my SC project cabinet in primer. 61A9C7FA-86B4-473B-A149-898ED7D66D5C (resized).jpeg
Set up my FH JC project.
I have had the cabinet ready for a while now but the issue and hold up is that the supplied replacement playfield is not drilled nor dimpled. image (resized).jpg
Not a huge deal but without a template I can only proceed by gutting the base and using that old playfield to create one.
I already knew or could tell it had a terrible decal job. B5928127-9CC2-44D3-BFDF-9FF31F8C96AB (resized).jpeg
Add moisture issues to that. D66FE4EA-6FFA-4C13-A63C-E5C24A87F977 (resized).jpeg
After setting it up this just might rival the TAF train wreck I am dealing with right now. 5AFE662A-0D95-4A45-8442-9C4A00E71A88 (resized).jpeg
First I see it is missing the game/FH specific apron guard. Hopefully I can come up with that no guarantees.
The ramp is just stuck on there DB54946E-3C66-46F7-B643-ED449FABB10E (resized).jpeg
Opened up the head. Terrible. BC437355-C20C-4B53-BDC5-44B5EA9D1BC7 (resized).jpeg
Blue overspray on everything. 0978DB7C-728C-4077-BBC6-21CF4356FB91 (resized).jpeg
Missing the hinge brackets.
The boards are bad too.
CPU is corroded beyond repair. E61BE367-9F36-4D48-AC6E-BAD56336277D (resized).jpeg
Driver board is at the very least suspect. 3F1DBF88-809E-4BF6-A05B-C9CEE6AB4DEC (resized).jpeg
Inside crusty.
Quoted from xsvtoys:
I’m sorry Cyclopes has been such a pain in many ways, but man it looks cool as heck. Have really enjoyed the build.
Thanks.
Cyclopes project is a good one. I don’t dislike it on a personal level it’s nothing I haven’t seen nor dealt with before there.
Tough one to absorb commercially but a necessity if I want to provide the type of service that goes beyond restoring the usual suspects.
FH continued on today.
One discovery after the other nothing that can’t be dealt with but the game is a real POS
Even little things like the mirror lamp board are going to need extra attention.
The playfield was eventually gutted. C50419CE-01DA-476C-9B09-5CB44CA32E34 (resized).jpeg
I used that to drill and dimple the supplied replacement
FH JC lamp panel is a problem. 3BE69068-69C9-4316-9B27-7397490ABCBD (resized).jpeg
It’s waterlogged and bowed. 961EE53D-CCEF-472D-B98F-EDA060D2BDBB (resized).jpeg
I will need to make a new one.
These plastic sockets will not survive removal they are cooked. 484839A7-9FD9-46AF-849E-2D80D4587840 (resized).jpeg
Further complications are the mod sent for it. 25FA328B-FE03-404A-B5D2-0546B2AAC342 (resized).jpeg
Knowing I need to install this as well as build a new panel it makes the most sense to put provisions in place for the mod.
I map that out on the old one once torn down it becomes a template just like the old playfield .9C4ABFA1-1E44-430E-A86F-1B61EFAB27C6 (resized).jpeg
I make two panels. One stock and one modified 32409100-21D7-4DF8-AA7A-6B6C720DDBBB (resized).jpeg
The modified one is for this game so I will concentrate on that here.
I did not drill any lamp holes that would be covered by the mod and I drilled it for 44 style sockets(smaller) because I will not be reusing the plastic ones and can’t get them.
I map out pass through holes for the mods wiring 7D58EF55-37FF-4C07-A78B-BD131519FF12 (resized).jpeg
Those holes are drilled so the connectors can easily pass through and the wiring can be run exclusively in the back of the panel. 24172BE8-F1CB-47E1-979E-4B2A4E7B8D96 (resized).jpeg
Both panels are then primed because mdf is porous and paints best when primed and sanded.
Good idea ..... i notice the wedges have been hit and miss for availability for the past few years and expensive compared to a 44 socket.
FH lamp panels were sanded painted snd cleared.
Full gloss clear on those because I was also clearing the FH playfield and want to keep material waste to a minimum. D7D285A1-53D4-4C59-B4AC-E665DAC663D1 (resized).jpeg
Further complications are the mod sent for it. [quoted image]
I map that out on the old one once torn down it becomes a template just like the old playfield .[quoted image]
I had never seen that mod before. Looks like a must-have if you've got a Funhouse. Even moreso if your Funhouse is a POS in need of something - anything - good.
Quoted from ToucanF16:
Wow! It’s one thing after another with this FH! That pin lived a rough life in a tough neighborhood. It probably has some stories to tell.
I just got one of those animated Marquees for my FH. It’s not installed yet, so I’ll be watching what Chris does.
Who sells these?
Quoted from fossmin:
Who sells these?
http://www.arcadeupkeep.com/shop/4594679907/funhouse-m3-backglass-title-mod/11396061
Sold out though. Maybe contact them to see if they will make them again.
The Sc is coming together
Used my cameo to make some spinning disc decals since I had a sheet of the material.
Looks pretty cool, but seems like it reads TUNHOUSE. Not sure why they didn't add 2 additional LED's in the F. Maybe it's just me.
Chris
What color ramps are you putting in SF? I recently did some themed vinyl decals for a guy who was putting clear ramps in his and wanted something to hide the coil under the right ramp at bottom. Would be happy to share files with you or send you a set if you were interested.
I don't have a pic of the decals actually installed, but here they are along with a pic of the test fitting on plain paper.
Quoted from SilverUnicorn:
Chris
