(Topic ID: 225528)
HEP This Week 11-15-21
By High_End_Pins
  • 10,299 posts
  • 514 Pinsiders participating
  • Latest reply 4 days ago by mbenivegna
  • Topic is favorited by 523 Pinsiders
Topic poll
“EBD Trim legs will be black regardless ”
  • Stainless/Factory 35 votes
    31%
  • Blacked out 54 votes
    48%
  • Painted Gold matched to cabinet 24 votes
    21%
(113 votes)
This poll has been closed.
149 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 10,299 posts in this topic. You are on page 14 of 206.
#651 3 years ago
A very common question in HEP threads is what is guidecoat why use it.
This is a good chance to show what can be lost n sanding without it if you have a rougher piece of wood.
When primed and still wet you can see the divots. Spots like this will be easy to see if painted or decaled over but they become much harder to spot once the primer dries.
948E9017-7D09-4DD8-91CE-BEE8AA32B9FB (resized).jpegEB09B838-A5B8-400D-B69A-590BAB9B1DFB (resized).jpegF4A6A4BE-14D4-451B-8ECB-F117FE145CDD (resized).jpeg
#652 3 years ago
By guide coating while the primer is uncured the black overspray settles into this low spots.
It is also why the guidecoat application can look sloppy but is strategically sprayed.
You spot the imperfections wet and focus the guidecoat on them when spraying.
#653 3 years ago
Quoted from g94:
Being an amateur-restorer myself and spending months on a single restore, it is amazing to see how you crank out these beautiful games on a weekly basis. You're a man-machine, the terminator of pinball restoration...
Thank you.
I have seen some of your projects on here and know you have a great understanding of what it takes to pull this off.
#654 3 years ago
So the guide coat helps show imperfections on the wood better so you can see them and correct them as you sand? Does the guide coat also give you a "guide" as to how far you can sand the primer without potentially sanding through it?
#655 3 years ago
Chris,
I don't have a game going to you and probably never will (although I would love it). But you are an inspiration to many of us. Your weekly updates are incredible, and I love to see your progress. I may just have to send you some local beer because I am in awe! Thank you for your sharing your "journey".
#656 3 years ago
If you would take Canadian dollars at par I'll send you my quicksilver
#657 3 years ago
Quoted from Mitch:
If he did that he’d need a big warehouse.
As I would be sending games as well.
#658 3 years ago
Quoted from High_End_Pins:
[quoted image][quoted image]
Fantastic tip...thanks for sharing
#659 3 years ago
Before I settle in with the lamp harness wiring on the IJ and the evening beer I kick on the compressor in the paint shop.
It cost more than the building it is in which is sad but it is an essential tool and clean dry air on demand is important. [quoted image]
I will mask and prime the TAF cabinet real quick now that the button holes are made and the Tommy cabinet is out of harms way.
I didn't know CP made screw compressors. How long have you had it?
#660 3 years ago
Quoted from mario_1_up:
About 10 years.
#661 3 years ago
Worked through the IJ GI rewire this morning.
New color correct wire.
1783D5C3-87ED-4222-9596-FA3DA1799FB6 (resized).jpegF60F39EB-1F78-4E8F-B7BD-E6B93E863A45 (resized).jpeg
New screws. The gold colored ones are correct for lamps. B211C5B8-B955-4682-8791-004B01AD6CC5 (resized).jpeg
#662 3 years ago
Starting at the very end of the orange strand.
This is identified by the single wires gathered at the furthest socket. 05EE5148-C4F9-4B66-9FBD-2571AEC86462 (resized).jpeg
The end is on the other side and has doubled wires st the sockets. 015F4FF4-6256-4926-81AD-C9D677EF525E (resized).jpeg
Short protections where needed. FBB70D6D-121B-4742-B157-F52A7E18872C (resized).jpeg
Then worked all the way to the other side of the orange strand. 38860F04-A0E0-4960-95BF-EE8EF91AC100 (resized).jpeg
Now I can do the same with the brown strand.
#663 3 years ago
Always amazing work as always Chris, makes me and helps me work better and harder on my projects.
I'm also always amazed when you show your parts inventory, the cost of that alone must have been astronomical. However, with the speed and volume of work you do without sacrificing quality it's a must have to have this stuff in stock and ready to go.........
#664 3 years ago
Brown strand done and the lamp harness is just about out of the way just needs one or two feature lamp sockets located and secured then I can move to the solenoid harness.
The trash from these two harness reworks adds up and isn’t the type of thing that you can fully appreciate just by looking at the game or pictures but it is a big part of truly rolling the odometer back to as close to zero as possible.
#665 3 years ago
Busy day today so for a workout I had to settle for a run around the neighborhood.I am due a rest/recovery day anyway so today is a good one for that.
It is even better now though because of James B. Thank you!
I eat my larger meal as a late lunch. The youngest son is special needs and a handful once he gets home from school so it provides my wife the best opportunity to fix us a good meal and to eat it in peace
Today is Alaskan King Crab legs and sockeye salmon with some steamed asparagus. BCC6C485-B563-408D-BACE-18EB66981836 (resized).jpeg
#666 3 years ago
After a lunch like that and a light workout I need to get moving around a little bit before the Friday evening beers.
Going to sand and paint the new TAF cabinet and possibly the do the final black out on the Tommy cabinet interior.
I based that earlier in the week when I was stenciling but blocked it from the clear to minimize the risk of dragging the hose in the outside at that time.
#667 3 years ago
Enjoy the rest, food and brew as it's well desevered! Many thanks to you sharing the art of your work. Its a huge help to us all and helps me become better by learning from one of the best. I can't thumbs up your posts enough but thank you Chris. I owe you some Golden Monkeys for all your help.
#668 3 years ago
Alright closing out another Friday around here.
Tommy lower is masked to do the final black
I don’t need to worry about doing the head that was cleared fully on the first pass.
#669 3 years ago
As I start to sand the TAF lower the worth of the guidecoat becomes very apparent.
Remember those divots?
The guidecoat will make sure you do.
This is a bit rough but will level out with some extra care but if not addressed would look pretty ugly under some black paint or decals.
#670 3 years ago
As I sand further I am being “guided” to the areas that need more attention.
Guidecoat!!!
#671 3 years ago
The known rough side is now in good order.
Would have been tough to get to this level without the guidance of guidecoat
It’s 4:20 Friday afternoon LDSB by George.
Only little flight glasses are allowed this early in the paint shop.
#672 3 years ago
Where do you get your lamp sockets? I like your method of daisy chaining the power wire on a tab connected to the lamp base.
#673 3 years ago
The other side of the TAF cabinet is equally rough.
Would be tough to catch these straight lines any other way.
This is probably a top piece of wood in a stack that line is possibly from banding the stack together.
#674 3 years ago
Quoted from brenna98:
Pinballlife for those.
#675 3 years ago
Good timing.
Had a large beer in my shop the other day while working on a pin project and I asked what would Chris do? And now I know. Pour it into 3 small glasses..
#676 3 years ago
Quoted from WolfManCat:
Good timing.
Yes. Have to regulate yourself until the hard work is out of the way.
#677 3 years ago
Two glasses later with lots of water to fill in the gaps. image (resized).jpg
We are ready to paint.
#678 3 years ago
Based in black.
#679 3 years ago
TAF cabinet and Tommy interior cleared.
0AA78F82-CC66-4968-953C-A30C37960D78 (resized).jpeg3EA826D2-FF7E-4DC7-9977-B50D8D0AAF98 (resized).jpeg5BD5B8DD-0199-4DF8-9365-03410048840F (resized).jpegA02FEB38-7347-4DB2-B115-B6DC9D476793 (resized).jpegA856EDC5-762C-42A4-89DD-811C4197B917 (resized).jpegE86D0708-F818-4BD7-8063-0803E1D83B25 (resized).jpeg
#680 3 years ago
Chris, for addams family what is the post as seen in the pic?
The manual leads me to believe its this part number:
https://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=02-3409
But the part looks wrong.
#681 3 years ago
Quoted from lordloss:
It is this one
https://www.marcospecialties.com/pinball-parts/02-4036-1
#682 3 years ago
#683 3 years ago
IJ playfield wiring is almost complete.
Nickel plated brackets,short protection and on plugs.
081CCAEF-E695-4E83-B442-E863CB4530CA (resized).jpeg25C28440-7606-4C93-A9E7-56006738F76C (resized).jpeg3E965A00-4F99-4964-BD26-712720868A6F (resized).jpegD4C1440C-7646-4B17-BDA1-3D7E662B0D62 (resized).jpeg
#684 3 years ago
Dinner time
Thanks for the crabs Wolfmancat!
I never thought I would type that but I really mean it. They are huge!!
Also thank you j.m ratkos for the beer.
It is really smooth
The two James have contributed to an excellent and relaxing evening for me. Much appreciated!!
#685 3 years ago
Is there a point to the nickel plating other than cosmetics?
#686 3 years ago
Quoted from Aniraf:
Yes
Most often these are plated to remove existing corrosion so while the cosmetics are nice it isn’t so much the point.
The added benefit is that they will not easily corrode again so it also adds better protection.
#687 3 years ago
IJ playfield wiring is complete until it gets finished on the topside after I place it in the cabinet.
The wiring now runs well clear of the target bank which is a tight spot in the factory configuration.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#688 3 years ago
Dinner time
It is really smooth
I only give my crabs to the most special.
#689 3 years ago
IJ playfield is now in the cabinet.
#690 3 years ago
Building up the new Revolutionary Pinball speaker panel.
This one works with the ColorDMD LCD.
#691 3 years ago
IJ lives.
#692 3 years ago
New week closing out some projects from weeks past,working towards doing that with others and starting some new ones.
First is the IJ
The apron is decaled with much nicer decals. D435F768-4C60-4413-B643-6EE1F402A6A0 (resized).jpeg
Then rebuilt and installed using black screws to blend in.
#693 3 years ago
Next up for IJ will be rubber and a new plastic set.
Using yellow lane guides and amber caps on this build.
It is a combination I personally like that blends well once assembled.
#694 3 years ago
TAF cabinet is screened and prepped for decals.
Lightly sanded on the inner because it will have interior art.
#695 3 years ago
Now I can prep the Tommy for the final tweaks and clear.
#696 3 years ago
Sanding the Tommy cab for final paint and clear.
Why?
Stencil edges. Clear has a tendency to not run but gather and picture frame any sharp lines which are left behind from the first painting.
#697 3 years ago
Sanding is complete for the Tommy cabinet final repaints and clear.
#698 3 years ago
There are just a couple minor things to tighten up nothing most would notice.
#699 3 years ago
Repainting the IJ plane in the process.
#700 3 years ago
When your trying to sand the clear to get rid of edges, there's a fine line (see what I did there) between sanding too much and taking paint off, or sanding too little and not getting rid of the edges. I guess it's just experience? Take that letter 'B' for instance, that's from sanding, I assume. I'm also assuming that you save the paint so you can touch that up. But doesn't touching up that red create as bump with the paint that will show up through the next layer of clear?
