(Topic ID: 225528)
HEP This Week 11-6-23
By High_End_Pins
5 years ago
  • 13,648 posts
  • 621 Pinsiders participating
  • Latest reply 8 days ago by ToucanF16
  • Topic is favorited by 614 Pinsiders
Topic poll
“EBD Trim legs will be black regardless ”
  • Stainless/Factory 35 votes
    31%
  • Blacked out 54 votes
    48%
  • Painted Gold matched to cabinet 24 votes
    21%
(113 votes)
This poll has been closed.
194 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 13,648 posts in this topic. You are on page 128 of 273.
#6351 3 years ago
I used to work for Binks in the repair department. I rebuilt hundreds and hundreds of their spray guns. Thor guns (precursor to the model 7) model 7's, 18's, 2001's, BBR's, automatic guns were the most common but nothing high end like yours. My salary was probably covered by selling fluid nozzles because nobody had the correct thin-line 19/32 wrench to properly remove them and they used pliars instead. 20 bucks each time instead of a $5 wrench...
#6352 3 years ago
I used the spray cars and Binks is the only show in town. I own a home now and trying to figure out how to get a rig again without my neighbors going full liberal on me. Looks like HEP has a proper spray room
11
#6353 3 years ago
Skateball cabinet has dried down to its proper gloss level. image (resized).jpgimage (resized).jpg
Before I move it out I check my red match to the apron. image (resized).jpgimage (resized).jpg
I am happy with that so it can head into rebuild.
#6354 3 years ago
Placed the head on the lower to make sure everything lines up
Looks good.
9E9FFECF-ED99-46D9-A6F7-75D40E4033D7 (resized).jpeg9E9FFECF-ED99-46D9-A6F7-75D40E4033D7 (resized).jpeg
Touch up bottles of each color
513C8A48-8F80-4471-AF81-BA1E77D279FC (resized).jpeg513C8A48-8F80-4471-AF81-BA1E77D279FC (resized).jpeg
#6355 3 years ago
Started working on the Select a Card playfield.
Cleaning it with the idea of reducing the need to repaint isn’t happening. 8B70339F-2AA7-4639-9234-26D9F6406F35 (resized).jpeg8B70339F-2AA7-4639-9234-26D9F6406F35 (resized).jpeg
It looks a little better but there is just too much age in there A275C3A9-509C-4D89-B90F-4C0E0778A3B6 (resized).jpegA275C3A9-509C-4D89-B90F-4C0E0778A3B6 (resized).jpeg
D0EB17AB-4017-42E3-829D-BB5A7AA47ED6 (resized).jpegD0EB17AB-4017-42E3-829D-BB5A7AA47ED6 (resized).jpeg471174F0-C00D-448C-95E7-CE366F994A09 (resized).jpeg471174F0-C00D-448C-95E7-CE366F994A09 (resized).jpeg
#6356 3 years ago
The wood itself might be the biggest challenge
2DCB74A7-7714-4915-88DB-D232508666A3 (resized).jpeg2DCB74A7-7714-4915-88DB-D232508666A3 (resized).jpeg6DE6700D-9B80-4F70-8641-8117C402F1E4 (resized).jpeg6DE6700D-9B80-4F70-8641-8117C402F1E4 (resized).jpeg03898BBB-75C2-4D8B-ABD4-80062A55DC31 (resized).jpeg03898BBB-75C2-4D8B-ABD4-80062A55DC31 (resized).jpeg
#6357 3 years ago
This is about all that can be done upfront.
Chemicals,sanding or pretty much anything else just creates more damage. 78BA0DA1-8772-4C51-B480-546DE4D542DE (resized).jpeg78BA0DA1-8772-4C51-B480-546DE4D542DE (resized).jpeg
I will set and glue the inserts now.
I will do these with it clamped on the side Because they are very easy to move around. In this position they won’t sink as the epoxy sets up. 30890DFA-6979-4813-A61F-09D2FEB48A27 (resized).jpeg30890DFA-6979-4813-A61F-09D2FEB48A27 (resized).jpeg
0434101B-92E9-469C-9CB3-B122CCED2A64 (resized).jpeg0434101B-92E9-469C-9CB3-B122CCED2A64 (resized).jpegDDC09D6C-9AF7-4F1B-86DD-942A6DAD67E0 (resized).jpegDDC09D6C-9AF7-4F1B-86DD-942A6DAD67E0 (resized).jpeg
#6358 3 years ago
Inserts are set in the select a card playfield.
Will clear it next just to give put some protection down so I can start to more aggressively work on it.
6D0B35DF-AED0-4307-A3CD-00F7B1A7C6FB (resized).jpeg6D0B35DF-AED0-4307-A3CD-00F7B1A7C6FB (resized).jpeg0F5D291D-C132-49D4-8EEF-A4A6EDCB70E3 (resized).jpeg0F5D291D-C132-49D4-8EEF-A4A6EDCB70E3 (resized).jpeg8BB9E00E-536E-4C8D-AC35-2D7D0C2B4B82 (resized).jpeg8BB9E00E-536E-4C8D-AC35-2D7D0C2B4B82 (resized).jpeg9D563AF3-A117-4476-85A0-E75475773209 (resized).jpeg9D563AF3-A117-4476-85A0-E75475773209 (resized).jpeg
#6359 3 years ago
Quoted from High_End_Pins:
Chemicals,sanding or pretty much anything else just creates more damage. [quoted image]
I will do these with it clamped on the side Because they are very easy to move around. In this position they won’t sink as the epoxy sets up. [quoted image]
[quoted image][quoted image]
So what's the plan to get the wood coloring even in the playing area?
Basically, this is what CPR's one-off digital PF printing service was made for. Sand to a blank and re-print. Unfortunately, no one has done the art for this, nor probably ever will.
10
#6360 3 years ago
Quoted from PinMonk:
I usually approach these one step at a time.
Most likely solution will be airbrushing the wood tones in a overthinned similiar color to blend and camouflage.
Can’t do anything until there is a level and stable surface so that comes first.
This patient is 70 years old so if I can make him look like he is 30 and work like he is 20 that will be about as good of a miracle as I am capable of.
#6361 3 years ago
The first clear is on the Select a Card
Mostly looking to glue it all down and fill the opened grain82C2654B-FC4F-4B03-942C-1E7CCE3796EC (resized).jpeg82C2654B-FC4F-4B03-942C-1E7CCE3796EC (resized).jpeg98B6F945-6955-4314-8C40-0360C3E8F91C (resized).jpeg98B6F945-6955-4314-8C40-0360C3E8F91C (resized).jpeg4D52A48F-0798-45BB-92E5-2BC6529C8877 (resized).jpeg4D52A48F-0798-45BB-92E5-2BC6529C8877 (resized).jpeg
After a few coats I got about as close as you can in step 1
I will see how it handles the clear and absorbs it.
Concerns unknown at this point will be if this clear lifts the old finish.
If not we are in a good spot.
F9E2A854-44FC-4492-81F8-208BDDD33320 (resized).jpegF9E2A854-44FC-4492-81F8-208BDDD33320 (resized).jpeg6B600514-A72B-4BB6-9F41-D28BD0EC4ABA (resized).jpeg6B600514-A72B-4BB6-9F41-D28BD0EC4ABA (resized).jpeg176F30D2-255D-4580-8E54-B0E52493E985 (resized).jpeg176F30D2-255D-4580-8E54-B0E52493E985 (resized).jpeg8237416E-07DB-4D8D-957B-EB54983FCA74 (resized).jpeg8237416E-07DB-4D8D-957B-EB54983FCA74 (resized).jpegE89BDD84-2285-45F3-9D12-FF4A8501BFBB (resized).jpegE89BDD84-2285-45F3-9D12-FF4A8501BFBB (resized).jpegF638174A-B278-48F6-AB87-5E18532F3C3E (resized).jpegF638174A-B278-48F6-AB87-5E18532F3C3E (resized).jpeg
#6362 3 years ago
Also prepped and final cleared the CP playfield.
448BEF70-A04B-4834-84E9-87292CA1F1B8 (resized).jpeg448BEF70-A04B-4834-84E9-87292CA1F1B8 (resized).jpeg42251D87-7EC6-40D2-85B2-2D0851F5399E (resized).jpeg42251D87-7EC6-40D2-85B2-2D0851F5399E (resized).jpeg58177C51-FF0D-4D9A-B6F5-1D95491AE011 (resized).jpeg58177C51-FF0D-4D9A-B6F5-1D95491AE011 (resized).jpeg818FB1F3-5BCA-49E2-BA39-F99B3838A04C (resized).jpeg818FB1F3-5BCA-49E2-BA39-F99B3838A04C (resized).jpeg0A4E184C-C5F3-4AE7-BB7C-8411E7E4C178 (resized).jpeg0A4E184C-C5F3-4AE7-BB7C-8411E7E4C178 (resized).jpeg6B6701C0-E025-4C74-B5F1-F740ED0E06CE (resized).jpeg6B6701C0-E025-4C74-B5F1-F740ED0E06CE (resized).jpeg7A929691-99DA-41DF-86E3-69F0985CA02B (resized).jpeg7A929691-99DA-41DF-86E3-69F0985CA02B (resized).jpeg
#6363 3 years ago
Skateball cabinet makes it into rebuild area.
Since it is the first one I have done I park it next to the original to verify accuracy.
Anytime I do a game for the first time I try to do the original scheme justice. Once I get into multiples I try to get more creative if allowed.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgB447FBB5-8CEE-402B-BFEF-F3D08A9121DA (resized).jpegB447FBB5-8CEE-402B-BFEF-F3D08A9121DA (resized).jpegAA85ACF7-3645-4BB7-8213-527C17AAF51C (resized).jpegAA85ACF7-3645-4BB7-8213-527C17AAF51C (resized).jpeg
#6364 3 years ago
Champion pub
Cabinet is braided 934B7B35-0BE3-41CC-84EE-AA3E1A6AE17B (resized).jpeg934B7B35-0BE3-41CC-84EE-AA3E1A6AE17B (resized).jpeg
Ackbard rebuilt big job for a backboard. Made some no insulators put some protection in place. B589055D-BCA4-4DC3-A0DC-D2BD623F5FE7 (resized).jpegB589055D-BCA4-4DC3-A0DC-D2BD623F5FE7 (resized).jpeg
015AF3D5-B2E7-4A3C-A84F-82EA25547986 (resized).jpeg015AF3D5-B2E7-4A3C-A84F-82EA25547986 (resized).jpeg8B860045-53A3-49C4-B3E8-305E2CE68469 (resized).jpeg8B860045-53A3-49C4-B3E8-305E2CE68469 (resized).jpeg433BAE96-7C48-4901-A4DE-7F6FC1D0E4E7 (resized).jpeg433BAE96-7C48-4901-A4DE-7F6FC1D0E4E7 (resized).jpeg56F8B268-4375-469B-ACCD-C1AFC433B14B (resized).jpeg56F8B268-4375-469B-ACCD-C1AFC433B14B (resized).jpeg5703D391-F9A9-44D5-8807-FE3E5CE5E22C (resized).jpeg5703D391-F9A9-44D5-8807-FE3E5CE5E22C (resized).jpeg63BB662F-EF40-4535-A64A-B4AFA8B4BA29 (resized).jpeg63BB662F-EF40-4535-A64A-B4AFA8B4BA29 (resized).jpegCE618B7E-9787-4678-8ACB-D6A8B68D9E8C (resized).jpegCE618B7E-9787-4678-8ACB-D6A8B68D9E8C (resized).jpegADF24FAF-611E-47AD-9184-8CE60CB952EC (resized).jpegADF24FAF-611E-47AD-9184-8CE60CB952EC (resized).jpeg
#6365 3 years ago
Rebuilding and completely rewiring the boxer. Another big job.
This one has so many splices and broken wires it will just need all new wiring.
A481A910-D980-4322-9785-D296F16CC478 (resized).jpegA481A910-D980-4322-9785-D296F16CC478 (resized).jpegC9EB34A6-B4F5-4E4A-865C-2CB84D19C690 (resized).jpegC9EB34A6-B4F5-4E4A-865C-2CB84D19C690 (resized).jpeg19C4EC7F-00BE-4C63-96F2-70671B0FB3F1 (resized).jpeg19C4EC7F-00BE-4C63-96F2-70671B0FB3F1 (resized).jpeg6CF63A5B-A016-42CD-9A41-4D4A90D647C7 (resized).jpeg6CF63A5B-A016-42CD-9A41-4D4A90D647C7 (resized).jpegC223A646-3CBB-4682-B5B9-1D3C1FA57997 (resized).jpegC223A646-3CBB-4682-B5B9-1D3C1FA57997 (resized).jpeg
#6366 3 years ago
Chris, I am curious...mechanically how complex is CP? It seems like there is a lot going on with the game. What would you consider the top 5 (or so) complex games?
#6367 3 years ago
CP boxer rebuilt and rewired. 949604E6-030A-4CFB-AFD8-F3344347E398 (resized).jpeg949604E6-030A-4CFB-AFD8-F3344347E398 (resized).jpeg
E286D537-889C-4307-AA3A-2495BCBDAE7A (resized).jpegE286D537-889C-4307-AA3A-2495BCBDAE7A (resized).jpeg
51C1474B-75D7-47C6-BEC2-557A7A0B7F7B (resized).jpeg51C1474B-75D7-47C6-BEC2-557A7A0B7F7B (resized).jpeg
0148E287-D41A-4FD2-ABDA-23762F77BCB2 (resized).jpeg0148E287-D41A-4FD2-ABDA-23762F77BCB2 (resized).jpeg
I had hoped to replace the left arm because it has a chipped knuckle but after wasting my money on two different replacement arms I conceded to just reusing the original.
The colors were not even close. The material used was far too rigid and even worse they don’t fit at all.
Original 0D8DD92A-9275-4A47-98AC-3EC1376888C7 (resized).jpeg0D8DD92A-9275-4A47-98AC-3EC1376888C7 (resized).jpeg
Replacements at the bottom B1FA9C8D-A150-4BD8-A7B1-BA6D14D681C8 (resized).jpegB1FA9C8D-A150-4BD8-A7B1-BA6D14D681C8 (resized).jpeg
Square is too small F2FAE5D3-2B7D-4CB1-9301-7025DA113818 (resized).jpegF2FAE5D3-2B7D-4CB1-9301-7025DA113818 (resized).jpeg
A boxer with a busted knuckle is better than one with a prosthetic arm.
0BCFBDA2-38EC-4F77-B79E-99F7D1DE9A61 (resized).jpeg0BCFBDA2-38EC-4F77-B79E-99F7D1DE9A61 (resized).jpeg
#6368 3 years ago
Quoted from NC_Pin:
CP isn’t too bad overall but it does have a lot of mechs to go through and many of them are unique.
It is one of the more complex WPC-95 games.
On that list I would include NGG With the gopher mechs,mini playfield, disc and possibly CV. Because of the ringmaster,unique backglass.
None of them are too bad overall but if you really are going to break them down and truly rebuild and improve everything then there are a lot of extra steps and many more hours spent.
In terms of complex games in general I think the three level System 80 games,double playfield games,Banzai Run,Safecracker and probably several others come to mind but really the are all mostly coils and plungers with a motor here and there.
What makes some more complex is how they are constructed or just that they have lots of those coils,plungers brackets and motors to deal with at one time.
#6369 3 years ago
Black knight cabinet is prepped and based.
68434A41-5091-4169-ABF5-749F2917BBBE (resized).jpeg68434A41-5091-4169-ABF5-749F2917BBBE (resized).jpegA2D3B988-F3F8-42E0-8B77-C9060EC887CC (resized).jpegA2D3B988-F3F8-42E0-8B77-C9060EC887CC (resized).jpegimage (resized).jpgimage (resized).jpg
#6370 3 years ago
Select a Card playfield is prepped
Then masked and wood tone frosted. This is a very tough process on something so dingy and aged.
It is going to be impossible to make it look as though no work was done but I have preserved the natural grain as well as I can while still eliminating all the ground in dirt.
From a distance it may look like it is simply tan but in person and from a players view you can see the grain.
8243969A-2A1D-4D95-8CEA-ABAB321E9D91 (resized).jpeg8243969A-2A1D-4D95-8CEA-ABAB321E9D91 (resized).jpeg1232FE60-A9A7-48C0-B644-F4046A9549C3 (resized).jpeg1232FE60-A9A7-48C0-B644-F4046A9549C3 (resized).jpeg1D42EBC5-3F33-4CB8-99BC-BA04E3C55C73 (resized).jpeg1D42EBC5-3F33-4CB8-99BC-BA04E3C55C73 (resized).jpegB5000607-295F-400D-AD43-C7802421C3F2 (resized).jpegB5000607-295F-400D-AD43-C7802421C3F2 (resized).jpegD572060E-383D-4094-BEE0-7CDA6410DC38 (resized).jpegD572060E-383D-4094-BEE0-7CDA6410DC38 (resized).jpeg
#6371 3 years ago
Wood tones unmasked.
I will probably catch a couple more colors but will wait to do the areas around the inserts until I know those are fully sealed and level. Not there yet but much closer.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#6372 3 years ago
Select a Card playfield cleared again
Inserts are sealing up and leveling out.
7DDE324A-D4B6-448E-AB46-A11334F767B6 (resized).jpeg7DDE324A-D4B6-448E-AB46-A11334F767B6 (resized).jpeg69AAEBA6-B43E-4687-A37F-E6D35BF8035D (resized).jpeg69AAEBA6-B43E-4687-A37F-E6D35BF8035D (resized).jpegCE3074AE-FFC7-4E86-A6A4-C52C5C19DB14 (resized).jpegCE3074AE-FFC7-4E86-A6A4-C52C5C19DB14 (resized).jpeg
#6373 3 years ago
Black knight cabinet cleared. This stencil has stacking colors so clearing it first then sanding and stenciling will be the best method.
E287A350-92B9-4788-A27D-5357A0798EBD (resized).jpegE287A350-92B9-4788-A27D-5357A0798EBD (resized).jpeg0D980855-C919-44C0-8E74-23463E7036C3 (resized).jpeg0D980855-C919-44C0-8E74-23463E7036C3 (resized).jpeg17248DD7-32ED-4C2C-8ABD-DF84E98405DB (resized).jpeg17248DD7-32ED-4C2C-8ABD-DF84E98405DB (resized).jpeg4F158160-1BF9-4BA0-81A9-B567E467D88D (resized).jpeg4F158160-1BF9-4BA0-81A9-B567E467D88D (resized).jpeg5E977F29-C7F4-4E00-AF9A-BA68242B6139 (resized).jpeg5E977F29-C7F4-4E00-AF9A-BA68242B6139 (resized).jpeg4E17E8C8-6779-4D94-A33E-EC5A91181E71 (resized).jpeg4E17E8C8-6779-4D94-A33E-EC5A91181E71 (resized).jpeg
#6374 3 years ago
Evening beer.
5451264D-EA70-4EFD-A967-081346921718 (resized).jpeg5451264D-EA70-4EFD-A967-081346921718 (resized).jpeg85778398-E5C8-4EDF-9636-CF93E2601D2C (resized).jpeg85778398-E5C8-4EDF-9636-CF93E2601D2C (resized).jpeg
#6375 3 years ago
Evening beer.[quoted image][quoted image]
How was this beer Chris? Ironically I just picked one up yesterday.
#6376 3 years ago
Quoted from meSz:
It was good. Not great but a tasty beer overall.
I think the biggest issue with a beer like that is it is a little too weak for the style.
If they dialed it up a little would be better.
In that ABV range I would probably rather have a good Belgian triple and save the porters and stouts for the higher ranges.
#6377 3 years ago
CP cabinet is building.
I deferred to gloss black since gold is a bit overdone and few other options really seamed to make sense like chrome and really even traditional stainless with this color scheme.
3D09049C-7082-4A98-BCEA-EA1AE6894A37 (resized).jpeg3D09049C-7082-4A98-BCEA-EA1AE6894A37 (resized).jpegFAFB9B46-A2FB-45EE-8E5B-11D051BDD587 (resized).jpegFAFB9B46-A2FB-45EE-8E5B-11D051BDD587 (resized).jpeg
#6378 3 years ago
One of the best things about trying to do everything in house or worse case locally is that I don’t have as much risk or down time.
The parts I dropped off for powder are already back in my hands.
I was able to inspect them and even more importantly count them to insure they are all there. 5DE39D40-4D41-4EB3-866F-BE2C80B94E9F (resized).jpeg5DE39D40-4D41-4EB3-866F-BE2C80B94E9F (resized).jpeg
86B05C2D-2739-4A3E-8E57-1DAA8F634BCC (resized).jpeg86B05C2D-2739-4A3E-8E57-1DAA8F634BCC (resized).jpeg
I am also about to really communicate my needs to the coater.
In this instance I was able to show him exactly where he needed to tie things off and how important it was not to get them any thicker than they already are. 0F8BA994-2304-4E8C-B354-4D0E890F14DF (resized).jpeg0F8BA994-2304-4E8C-B354-4D0E890F14DF (resized).jpeg
Something like this pound in barbed wireguides are a disaster when they get replated with a layer of nickel,copper then chrome or brass.
Looks nice yes but does much more harm than good at reassembly.
E1054CDA-5BCD-446E-AD73-128EC2E3ABB6 (resized).jpegE1054CDA-5BCD-446E-AD73-128EC2E3ABB6 (resized).jpegAD20A0A4-7A6D-40BC-90BD-0EFA0100BC0A (resized).jpegAD20A0A4-7A6D-40BC-90BD-0EFA0100BC0A (resized).jpeg
#6379 3 years ago
The CP bolts are rusty and rough
626E2742-3750-40E3-8A84-012BAFE0E04F (resized).jpeg626E2742-3750-40E3-8A84-012BAFE0E04F (resized).jpeg
915EE287-FDE5-46BC-B706-4B05963F481F (resized).jpeg915EE287-FDE5-46BC-B706-4B05963F481F (resized).jpeg
Blasted 2375385A-BE9C-4AB4-AB6C-0BC412160985 (resized).jpeg2375385A-BE9C-4AB4-AB6C-0BC412160985 (resized).jpeg
D44A7DED-980E-4157-8868-959EDBB98EBE (resized).jpegD44A7DED-980E-4157-8868-959EDBB98EBE (resized).jpeg
Metal etched and then painted. F16721A3-F318-412E-9F80-4E6BEBA32D0F (resized).jpegF16721A3-F318-412E-9F80-4E6BEBA32D0F (resized).jpegD059C94E-31DD-44F4-BBB8-76E7901AFB99 (resized).jpegD059C94E-31DD-44F4-BBB8-76E7901AFB99 (resized).jpeg
The hinges were done along with the coin door which was in nice shape.
That door was done in the factory style. I will change out the slots later. I like to paint these assembled when I can do the specks all match up. 6881676E-744C-4E6B-A2C0-3BE00D3F37EB (resized).jpeg6881676E-744C-4E6B-A2C0-3BE00D3F37EB (resized).jpeg
9F1E30CF-00EB-45AF-88F9-4FEF978EC7F5 (resized).jpeg9F1E30CF-00EB-45AF-88F9-4FEF978EC7F5 (resized).jpeg1B22E78D-CDED-44B2-9346-8B93CF0AE37B (resized).jpeg1B22E78D-CDED-44B2-9346-8B93CF0AE37B (resized).jpeg
#6380 3 years ago
I know that's a factory look, but it's always struck me as odd. Were the specks initially added to hide manufacturing flaws or location wear? Have any of your customers ever requested no specks?
#6381 3 years ago
Quoted from yancy:
Only the racist ones.
#6382 3 years ago
Quoted from yancy:
I think the specks are to add durability. Most textured finishes are on that order.
Not often are people too specific about the coin door finishes unless it is something other than black.
In this case putting the specks back on helps because it makes it easier to reuse the original door.
#6383 3 years ago
I would love to see how you set up your gun to achieve the speck finish. I have watched other restore threads on how to do this and it seems pretty difficult. I know Bryan Kelly did a great video on his technique but I find it pretty intimidating to get the right amount without full-on blasting the paint.
#6384 3 years ago
CP cabinet is built and wired.
#6385 3 years ago
CP playfield is sanded and polished.
99ADA9DC-3074-4F87-BEDF-DB815E19C3FF (resized).jpeg99ADA9DC-3074-4F87-BEDF-DB815E19C3FF (resized).jpeg634CDCAB-BFB8-4936-86D1-D2BC1AE6AC64 (resized).jpeg634CDCAB-BFB8-4936-86D1-D2BC1AE6AC64 (resized).jpeg98597B9D-D6BE-45CE-A353-171DE03EE1E3 (resized).jpeg98597B9D-D6BE-45CE-A353-171DE03EE1E3 (resized).jpeg
#6386 3 years ago
CP wireguides are installed as well the t nuts.
I did the wireguide install on a solid flat surface there was a good strong backing as the were driven in.
18F27351-6169-4AF7-948C-7B84F73E6E6F (resized).jpeg18F27351-6169-4AF7-948C-7B84F73E6E6F (resized).jpeg1D8792B4-D967-4243-BB8E-E8E68281C381 (resized).jpeg1D8792B4-D967-4243-BB8E-E8E68281C381 (resized).jpeg5FB453DC-40CB-4909-9545-B89611C7F939 (resized).jpeg5FB453DC-40CB-4909-9545-B89611C7F939 (resized).jpegC5EA5E31-4913-48EC-8FDA-1D3FE071BA4A (resized).jpegC5EA5E31-4913-48EC-8FDA-1D3FE071BA4A (resized).jpeg
#6387 3 years ago
I may have missed it, but I've wondered about coloring wire guides before. Do you buy them already colored or do you do it yourself? I assume if one wanted to do their own they would need to be powder coated to hold up over time? Also, when powder coating something that is already chromed should you first remove the chrome?
#6388 3 years ago
How do you get the guides back in w/o messing up the finish on them - hand forced?
#6389 3 years ago
Quoted from Mr_Tantrum:
A few posts up he was talking about sending them out to the powder coater.
#6390 3 years ago
Quoted from GCS2000:
I have a block with felt and a plastic hammer.
It protects the playfield and acts a gauge for seating them.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgCC147054-0657-4143-AB74-CE1F142A8ED3 (resized).jpegCC147054-0657-4143-AB74-CE1F142A8ED3 (resized).jpeg
#6391 3 years ago
Cool, I should have scrolled up.
#6392 3 years ago
That. Is a T-Shirt.
#6393 3 years ago
Chipping away at the Black knight cabinet. Too much to even discuss
8E0F3605-0611-47E5-95A3-E0D8995018AD (resized).jpeg8E0F3605-0611-47E5-95A3-E0D8995018AD (resized).jpegD2FBD99A-5CBA-43B1-8A0A-0FBC6A57E216 (resized).jpegD2FBD99A-5CBA-43B1-8A0A-0FBC6A57E216 (resized).jpeg0F49588A-D5DD-458C-859D-8411F825EDDB (resized).jpeg0F49588A-D5DD-458C-859D-8411F825EDDB (resized).jpegDC72560F-9470-48A6-8FBF-E86A6560C4F9 (resized).jpegDC72560F-9470-48A6-8FBF-E86A6560C4F9 (resized).jpeg66617BB9-3586-4673-9206-724F7B21CAD8 (resized).jpeg66617BB9-3586-4673-9206-724F7B21CAD8 (resized).jpegE94DE102-C267-4D7E-BC8E-2EB05BFECE43 (resized).jpegE94DE102-C267-4D7E-BC8E-2EB05BFECE43 (resized).jpeg009CFDB8-AB7D-44EA-8576-157CD0D8472A (resized).jpeg009CFDB8-AB7D-44EA-8576-157CD0D8472A (resized).jpeg2A487C84-8AE7-49F1-B629-15E5A97F86E9 (resized).jpeg2A487C84-8AE7-49F1-B629-15E5A97F86E9 (resized).jpeg
#6394 3 years ago
Stencil 1 pt 2
F9088351-2A18-4A0D-9D12-5E107F95799E (resized).jpegF9088351-2A18-4A0D-9D12-5E107F95799E (resized).jpeg59B9C5E4-21C0-459F-87FD-5CD011D6F615 (resized).jpeg59B9C5E4-21C0-459F-87FD-5CD011D6F615 (resized).jpegB7817B33-F9CF-4B6A-B4F7-3456188FE8A8 (resized).jpegB7817B33-F9CF-4B6A-B4F7-3456188FE8A8 (resized).jpeg6FE98F7A-495E-4ACB-A61E-46F48ABEFA5E (resized).jpeg6FE98F7A-495E-4ACB-A61E-46F48ABEFA5E (resized).jpeg584A9624-6074-4F2B-9072-E143F380EAC1 (resized).jpeg584A9624-6074-4F2B-9072-E143F380EAC1 (resized).jpeg14A30D1D-1FEC-4275-A279-0EC5DDDA84D4 (resized).jpeg14A30D1D-1FEC-4275-A279-0EC5DDDA84D4 (resized).jpegE9150BAE-A263-4F96-B4BF-71D3F6F06443 (resized).jpegE9150BAE-A263-4F96-B4BF-71D3F6F06443 (resized).jpeg
#6395 3 years ago
Stencil 2 pt?
DFE80378-285A-49E1-B939-C6A6D016AA09 (resized).jpegDFE80378-285A-49E1-B939-C6A6D016AA09 (resized).jpeg668D2002-32DB-4CB2-B52D-4AED953B8DCB (resized).jpeg668D2002-32DB-4CB2-B52D-4AED953B8DCB (resized).jpeg65318B21-77E2-4152-86C0-F71749067056 (resized).jpeg65318B21-77E2-4152-86C0-F71749067056 (resized).jpegACA3CD57-3CAE-414B-A75E-7994859D7664 (resized).jpegACA3CD57-3CAE-414B-A75E-7994859D7664 (resized).jpegA4749E93-1357-48BE-8006-67462772BC72 (resized).jpegA4749E93-1357-48BE-8006-67462772BC72 (resized).jpegE93E9CC5-8079-4CE1-B565-12D8A398FDE3 (resized).jpegE93E9CC5-8079-4CE1-B565-12D8A398FDE3 (resized).jpeg0E58D314-6E24-4495-BD33-17829FCA3BD2 (resized).jpeg0E58D314-6E24-4495-BD33-17829FCA3BD2 (resized).jpeg839E5774-FF19-47B3-99C8-40A562CCA862 (resized).jpeg839E5774-FF19-47B3-99C8-40A562CCA862 (resized).jpeg
11
#6396 3 years ago
Un masked
Have some glue to clean up then so will clear it in full gloss again.
C927D50D-BA7B-4C4B-80FC-1566F5793F30 (resized).jpegC927D50D-BA7B-4C4B-80FC-1566F5793F30 (resized).jpegA5C4B82A-E920-4113-99BD-1ABBAF827778 (resized).jpegA5C4B82A-E920-4113-99BD-1ABBAF827778 (resized).jpeg921C4303-FDEA-485B-9309-954E3C84EB95 (resized).jpeg921C4303-FDEA-485B-9309-954E3C84EB95 (resized).jpegBDA03E4C-8E93-4781-8C49-01FAD69EBEB4 (resized).jpegBDA03E4C-8E93-4781-8C49-01FAD69EBEB4 (resized).jpeg
#6397 3 years ago
Nice!!! Love it when the cabinet paint mods start flying....it's been a while!!!!
11
#6398 3 years ago
Bk cleared
Not sure where it goes from here but so far so good.
This is full gloss because I anticipate at a minimum sanding and reclearing maybe more.
I will probably tweak a few things though maybe add one more color in there not sure yet snd please no suggestions I like to figure it out on my own sometimes. Not always though
0BC0529D-8053-42B3-AA1F-C85739A994D3 (resized).jpeg0BC0529D-8053-42B3-AA1F-C85739A994D3 (resized).jpeg07A2B85C-C2FE-4840-AFED-EFE4131A8FF8 (resized).jpeg07A2B85C-C2FE-4840-AFED-EFE4131A8FF8 (resized).jpeg2EDA60BB-BCD6-4025-B768-D9288117F42F (resized).jpeg2EDA60BB-BCD6-4025-B768-D9288117F42F (resized).jpeg2CF3508F-C3E1-4C17-A048-10542883CF55 (resized).jpeg2CF3508F-C3E1-4C17-A048-10542883CF55 (resized).jpeg1DEE3F48-ABE0-409C-B23E-33E0BCE6DEDB (resized).jpeg1DEE3F48-ABE0-409C-B23E-33E0BCE6DEDB (resized).jpeg492F9F1A-00E1-47E1-B83B-FC0FF328DE3F (resized).jpeg492F9F1A-00E1-47E1-B83B-FC0FF328DE3F (resized).jpeg6876343C-5ED6-4F90-93D3-7FC10ACBAE29 (resized).jpeg6876343C-5ED6-4F90-93D3-7FC10ACBAE29 (resized).jpeg860A32C6-FA8F-42C7-91AD-628F94177192 (resized).jpeg860A32C6-FA8F-42C7-91AD-628F94177192 (resized).jpeg6B43A9AD-702C-4A28-9192-136005E65BE0 (resized).jpeg6B43A9AD-702C-4A28-9192-136005E65BE0 (resized).jpeg9F47D8D6-8E8C-43F9-B61B-A960B05C6677 (resized).jpeg9F47D8D6-8E8C-43F9-B61B-A960B05C6677 (resized).jpegC92D86D7-4A6B-4422-9A2C-D5D2F0E2DEAB (resized).jpegC92D86D7-4A6B-4422-9A2C-D5D2F0E2DEAB (resized).jpegB0BD8E10-5AE9-4EAA-9AC0-6E39557B62A8 (resized).jpegB0BD8E10-5AE9-4EAA-9AC0-6E39557B62A8 (resized).jpegD0488BB0-B8B0-4E77-892A-FBB1DA1A9CB2 (resized).jpegD0488BB0-B8B0-4E77-892A-FBB1DA1A9CB2 (resized).jpeg503725F3-7FC1-4DB2-8CAC-510126C8C62E (resized).jpeg503725F3-7FC1-4DB2-8CAC-510126C8C62E (resized).jpeg1FEF181A-C7D8-40D2-B09E-826FAC6BBE2B (resized).jpeg1FEF181A-C7D8-40D2-B09E-826FAC6BBE2B (resized).jpeg04B76F58-96C3-477C-ABB0-151D242B6222 (resized).jpeg04B76F58-96C3-477C-ABB0-151D242B6222 (resized).jpeg
#6399 3 years ago
Working late tonight?
Going to have to send you some Irish Death stout for a little caffine boost.
#6400 3 years ago
Quoted from WolfManCat:
Thanks.
Yeah I started that paint job about 1 thinking I would be done around 5 but I ended getting nutty and of course taking a lot more time than I thought.
Pretty common around here
I did manage to have a late dinner and fit in one beer.
3F8A5368-0138-4959-A9A9-9C3032DE0A0C (resized).jpeg3F8A5368-0138-4959-A9A9-9C3032DE0A0C (resized).jpegA49F84D0-F7DB-44D9-BBC5-2DCDFEA4763E (resized).jpegA49F84D0-F7DB-44D9-BBC5-2DCDFEA4763E (resized).jpeg
Toys/Add-ons
This page was printed from https://pinside.com/pinball/forum/topic/hep-this-week-9-17-18/page/128 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
