(Topic ID: 225528)
HEP This Week 5-10-21
By High_End_Pins
2 years ago
  • 9,190 posts
  • 469 Pinsiders participating
  • Latest reply 16 hours ago by High_End_Pins
  • Topic is favorited by 494 Pinsiders
Topic poll
“EBD Trim legs will be black regardless ”
  • Stainless/Factory 35 votes
    31%
  • Blacked out 54 votes
    48%
  • Painted Gold matched to cabinet 24 votes
    21%
(113 votes)
This poll has been closed.
127 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 9190 posts in this topic. You are on page 120 of 184.
#5951 1 year ago
Fathom cabinets stenciled
94459E64-72DB-4110-B488-D4BF0DDC38E5 (resized).jpegDAF2ADF6-CAE8-464D-9966-5594FB209417 (resized).jpeg06EE6C6C-CDDC-4001-BB0A-EFF2CAD5E6C2 (resized).jpegC8F5E77E-0576-465F-98EA-CD0CDCCC8DB0 (resized).jpeg
#5952 1 year ago
Fathom cabinets cleared.
DD1B27A1-FF1A-49E2-B545-C8FD5EF9F5AF (resized).jpegF84CEFB5-2A19-4377-B185-60029A21DF1F (resized).jpeg23A9CB53-403B-40D2-B686-31186C49BDE6 (resized).jpeg2B1DB14D-ED20-4A2B-B055-70BD5876ACF5 (resized).jpegAFC806A3-0BE7-408E-8163-0D0C84BC5AA4 (resized).jpegCB73B127-0D4E-4784-BDFC-2DC008B13446 (resized).jpeg7662D4B1-23CF-49F9-890D-0766A217A465 (resized).jpeg7DB89E27-72DA-47F8-ABEA-0C9D5FC5E262 (resized).jpeg0BF4E4BD-0373-402C-8710-5BA6F0C3E942 (resized).jpegA0B72F20-B323-49CA-A7A8-272730E86644 (resized).jpegA7F8274B-C6FE-4EE5-ACD5-76F5AD737448 (resized).jpegB35944D2-6286-4B2F-BEA0-98B906B120BC (resized).jpegBDD65E5B-E8A7-4F86-BB03-C95E2C8D0359 (resized).jpegECB9B3D2-A858-4282-8229-925989A1AC7C (resized).jpeg
#5953 1 year ago
Make your job easier doing two cabinets at once?
#5954 1 year ago
Quoted from ToucanF16:
Not really. On exactly the same cabinets.
The only real advantage is that they are using the same paint and clear so I waste a little less and have less clean up between colors.
If two different cabinets at the same time then it might actually be worse than doing them one at a time up until it is time to clear them both.
#5955 1 year ago
IJ cabinet is ready to decal then decaled.
Corner alignment is as good as it gets on these with the main focus being what is not covered once assembled.
28A35776-D259-4C13-A6D4-39949B2B2EBA (resized).jpegBC3E2700-2547-40DB-94C7-8508C9A4CFBA (resized).jpegD55AC879-6A9E-404E-8BC2-6F0AD9AD933D (resized).jpeg45402510-D74B-4D83-8812-98E429D8BC6A (resized).jpeg7EE0DC69-7E7B-4D25-BBB3-2E765A16EFFB (resized).jpegBDE7F325-2000-461F-AE82-18E276417E8E (resized).jpeg
#5956 1 year ago
Time to set up the the IJ base game.
124FAAF0-0E9A-4B02-9FF2-93ADDC224D63 (resized).jpegAD6D25F6-69AD-41D8-90D6-A4A1E01DAD67 (resized).jpeg9DD513AA-C1FC-4E9B-989B-AE5A2E44E27A (resized).jpeg
#5957 1 year ago
There are always small clues about condition.
Little things like using the wrong bolt on the hinge.
A strangely dark translite
Then there is the typical blackened metal BA1777FF-5AD5-409B-80F8-7F3A176C5FBF (resized).jpeg
The playfield on this one won’t even pull forward and latch properly
#5958 1 year ago
The playfield looks ok. I should be able to salvage it.
I had been holding out for a repro but after being strung along for a couple months(next week,in two weeks ,cutting it now,etc)I simply run out of time and have to move on.
The shooter lane is probably the biggest issue that I can spot right now until torn down completely.
36E75D6D-5CF2-4DBA-B134-3440090FE6D8 (resized).jpegB6EBC732-FE3A-48A2-AC70-32D0529ADE8B (resized).jpeg
#5959 1 year ago
After fighting it a bit I was able to get the playfield latched.
Same old same old.
Coils coming unspooled.
#5960 1 year ago
IJ playfield is stripped.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#5961 1 year ago
Man, given that shooter lane wear I’m surprised the playfield itself didn’t fare worse.....
#5962 1 year ago
Quoted from High_End_Pins:
I just had a busy couple days this week
Yearly physical etc.
I have managed to get some work done.
The parts came back from plating. [quoted image]
That allowed me to work on building both Spirit 2 and 3 back up.
Spirit 2 mechs
So how do you decide between replatting and tumbler? I have a pretty beaten up project with quite a bit of rust on all the metal which i was considering sending for replatting. Would every metal parts of assemblies be able to be platted? drop target, slings, ball through...?
#5963 1 year ago
Quoted from hisokajp:
Just my 2 cents ..... tumble first and see what it looks like. It’s surprising how pieces will clean up. If it still looks bad then have it plated.
#5964 1 year ago
I think that's the worst shooter lane I've ever seen!
#5965 1 year ago
Mylar is pulled from the IJ playfield set. 3FD78B93-4F81-425B-BF95-0F9E97FE3879 (resized).jpeg
The playfield is chemically cleaned
41B3AD54-561A-4245-8A39-D4C003181425 (resized).jpegEFC47545-9BFC-4A21-989F-168F39829B81 (resized).jpeg
#5966 1 year ago
Prepped and cleared for the first time. Will need some repaints and all that but I did get to a much better starting point and was able to eliminate some ghosting it had in a few inserts.
46DC3E0F-8697-4F50-8F06-F64F5E585664 (resized).jpeg447018E0-F4A0-4AE9-9AC9-ABB7F91B3556 (resized).jpeg2A173645-DAFC-4CD6-BC2A-050A6E78AE66 (resized).jpeg1C18EF1B-DA69-4440-9D0D-796EFC817EDD (resized).jpeg
#5967 1 year ago
Fathom cabinets are sanded and prepped for the final clear.
The process involves leveling the stencil colors.
This final clear will be a matte clear that should yield about a 75% gloss or so.
33952AB6-CF63-4CEE-80A8-652FD824E3BE (resized).jpeg41B4AE47-DEF2-414A-AD54-8793C07EF306 (resized).jpegB869FF74-C585-45D2-BEF9-AE26E921BFFD (resized).jpeg73EE59A8-6201-43CA-BC60-17C97F70861A (resized).jpegEE1E710A-15BC-41D6-9055-7ED09227176B (resized).jpeg
#5968 1 year ago
Final clear on Fathom cabinets
F95967A9-A5C4-444F-9CA4-8E3E1624E373 (resized).jpegF531039E-AC85-42AE-B1FE-2187BA66AFB7 (resized).jpegD33F72D8-BB1F-4653-A25C-D1208602D131 (resized).jpegF9BDC900-D29F-426F-B2D8-5FFF1A53B6EC (resized).jpeg7384D167-0FC7-46EF-B202-51FED2BD3196 (resized).jpegFE140158-9B68-4BF2-BF62-B1E4FEED2825 (resized).jpeg2A31B858-0395-45F4-9E54-83665DF86279 (resized).jpeg
#5969 1 year ago
Got the final clear down on the Spirit 2 apron.
The art itself on the apron has a couple minor flaws but it looks great overall and a nice finish helps that much more.
Also cleared the POA for IJ the first time.
182BD733-89CC-4EDE-A853-4E28524178AB (resized).jpeg3DB1F747-CB96-4516-BE14-8650E893517F (resized).jpeg97D4E7C9-E28D-4724-A3F6-C9E1E9896E82 (resized).jpeg
#5970 1 year ago
Time for the Thursday beer. And it really is that.
#5971 1 year ago
Mmm, blueberry maple!
#5972 1 year ago
Prepped and cleared for the first time. Will need some repaints and all that but I did get to a much better starting point and was able to eliminate some ghosting it had in a few inserts.[quoted image][quoted image][quoted image][quoted image]
wow - pretty amazing how quickly that PF cleaned up and thorough!! with your 'chemical' method. The ground in stuff really is history.
#5973 1 year ago
Quoted from mollyspub:
You need to see more shooter lanes. It's mostly just dirty, but not blown out like many I have seen...
#5974 1 year ago
What product do you use to "chemically" clean?
11
#5975 1 year ago
Quoted from Muskie82:
I use a few different things which I think I covered here somewhere.
Dirt is usually water based or solvent based
Water based cleaners are used to clean the organic or water based soils because they reactivate and remove them best due to there common component water.
Cromax v3921 is a good product for this.
Solvent based cleaners are used for solvent based dirt. This would be oils and other things that are not water based for the same reasons as the water based cleaners in that they have a common component which is solvent or are made specifically to remove solvent based contamination.
There are several cleaners that will do this I like to use straight acetone because it is usually the main ingredient in all those cleaners where as the water based ones are much trickier and propriety.
The cleaning process used on the IJ playfield might be a little deceptive because it took a good bit of sanding to get it to the point it was at once cleared but the cleansing process is essential and does help a lot.
First water based dirts are removed
Then solvent
Then sanded and prepped
Then water based cleaned again
Then solvent based
Then ready to coat.
#5976 1 year ago
Spirit 2 playfield build is coming along.
It ended up evolving into a really time consuming rewire
The way the slingshots are wired is that the two switches share a lead of the coil
This means that each sling shot switch requires six wires to be color correct and it’s own plug then a separate plug for the actual coil after routing a jumper wire through the harness.
With the game having 5 slings it is tedious. 88A61113-1B4E-4DED-AE5A-919C7FB01AEE (resized).jpegC4FB4DE6-E55F-45A5-8E3D-83083E603F2E (resized).jpeg
All lamp sockets are now two lead so that involves a good bit of mapping and fishing the new insulated wire into the harness.
#5977 1 year ago
IJ playfield was ready to prep for repaints.
The areas that need work are numerous but nothing major. Sometimes a lot of little things is more work that one big one but the real issue when dealing with this type of thing is that it can lead to a lot of color matching,masking and clean up.
The yellow is the first concern.There is ground in dirt ,chips ramp flap wear 133D6E9B-912D-4857-9F06-603A17F4A40C (resized).jpeg
The playfield is sanded and cleaned
The yellow is masked and sprayed.
#5978 1 year ago
Then the wood tones are lightly frosted because of bulb burn and ground in dirt.
After that blue areas of concern,some orange
4 colors in total plus some black work.
1DECEBFF-8BA1-46F5-8D4A-FBD18666688A (resized).jpeg15492737-A944-4411-BF6B-A48C9DD21B8F (resized).jpeg7308A3D9-0CDA-4666-83AE-37B2E992801C (resized).jpeg8B2C9C8F-9480-4074-AD7B-8BE07FF761CA (resized).jpeg
#5979 1 year ago
IJ playfield ready then it is cleared and looking much better.
0614415C-5296-4182-9CAF-5B1E04EA62E7 (resized).jpeg259F04F0-7E4D-4089-95EC-61689D570079 (resized).jpeg96EFAAA2-7620-4A30-A7D0-7142AFEFFAFC (resized).jpegBFAEC856-1C91-49B4-8838-38CCAF60F41D (resized).jpeg3A2B10DD-5413-4F73-B7D6-8D8B35F5F406 (resized).jpegB8438820-9853-44AE-B7C2-50539A4F116E (resized).jpegC8D98BCA-786C-40EC-A78B-D5A0B2403972 (resized).jpeg0F9CF62D-0F96-4700-9BBC-8380A9712D16 (resized).jpeg6862E011-0D70-4E38-A4ED-9043A78E5D56 (resized).jpegDC035679-6B20-4F20-BE9C-C723ECA4ED1F (resized).jpeg0954AC0C-5061-4893-ADD4-7D959E2531FE (resized).jpegEC57A6B4-99C7-46B1-904F-DB76D157DECD (resized).jpeg
#5980 1 year ago
IJ cabinet is building as well.
#5981 1 year ago
Whoa! I just had to put these side by side. That's some Voodoo right there.... Is that really the same play field?
#5982 1 year ago
HEP exposed! Shows fake before & after "process" photos of a beater and an NOS playfield. I knew there had to be a catch.
#5983 1 year ago
Quoted from yancy:
Is this a joke?
#5984 1 year ago
Quoted from radial_head:
Is this a joke?
Yes
#5985 1 year ago
Everyone knows this isn’t about pinball, but more for Chris to show off his beer and awesome lunch and dinners he has often.
10
#5986 1 year ago
Got one Fathom cabinet braided and up on legs.
This was the former BTC lower and a reworked original head. image (resized).jpg
Here is a comparison between the HEP paint scheme and the BTC.
One is a perfect match to the apron the other is probably somewhere more in the realm of original but a bit too drab.
#5987 1 year ago
The other is also ready to do the same but is going to have chrome trim.
#5988 1 year ago
Also the BTC stencil work is questionable. Bally logo on the head, woof. Is that freehand?
#5989 1 year ago
Quoted from yancy:
Crappy auto-outline. The thickness is a dead giveaway.
#5990 1 year ago
Fathom chrome is braided and up on legs.
The build up of the head of that one will be more involved because it is a brand new head do the lock,arm and other parts take much more effort to put in place.
294F1B63-E159-4D0B-8FD2-4AD9B8A07BA2 (resized).jpeg3DBC690E-7028-48C2-9778-74EFAFF2FC20 (resized).jpeg5A61F804-2CCB-43C8-AC3A-38ABDA4CC4B4 (resized).jpeg
#5991 1 year ago
Back to the Spirit 2 playfield wiring and soldering marathon.
Working through the flippers now as well as the lamps still.
#5992 1 year ago
Playfield has made it into the cabinet of Spirit 2.
14
#5993 1 year ago
Curtis turned 22 yesterday.
He had to work so that meant two parties
10
#5994 1 year ago
The nickel plated ball guides and parts are placed on the Spirit 2 playfield. It is then powered up for testing.
1297961D-0D1F-4843-BBA4-B58544D8A473 (resized).jpegD6A9196A-FB61-4169-8A27-225232C23E65 (resized).jpegC778E5A0-5C0E-4225-B70A-B9E6D47364EC (resized).jpegE951BD25-4248-4723-844F-CADA74CDAF3A (resized).jpegF86DB020-4144-4F00-9882-D38093287863 (resized).jpeg
#5995 1 year ago
Congrats to the boy!
My favorite thread on all of pinside; I really appreciate your explanations and reasoning behind the things you do and the techniques you use, it’s a real inspiration seeing your work.
I’ve also taken a few of your beer suggestions, haha.
Cheers!
#5996 1 year ago
Quoted from Grandnational007:
Cheers![quoted image]
Cheers!
Wednesday beer
7804CDB9-2912-4FA9-9A59-16CAAAADDF0F (resized).jpegABE10495-CB58-4133-9E60-6CC402F811CD (resized).jpeg
#5997 1 year ago
Happy bday Curtis. My birthday was yesterday as well. That sweet my bday is the same as someone famous.
#5998 1 year ago
Happy 22nd Curtis, looks like Dad's training regimen is paying off, your looking fit! Keep it up!
#5999 1 year ago
Happy Birthday Curtis !
#6000 1 year ago
How long until he needs a full restoration?
