(Topic ID: 225528)
HEP This Week 3-27-23
By High_End_Pins
  • 12,242 posts
  • 586 Pinsiders participating
  • Latest reply 7 hours ago by Stretch7
  • Topic is favorited by 575 Pinsiders
Topic poll
“EBD Trim legs will be black regardless ”
  • Stainless/Factory 35 votes
    31%
  • Blacked out 54 votes
    48%
  • Painted Gold matched to cabinet 24 votes
    21%
(113 votes)
This poll has been closed.
181 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 12,242 posts in this topic. You are on page 113 of 245.
#5601 3 years ago
The lower is done the same way.
A slight bevel was made during the repair process of the cabinet around the start button.
That is then also done in the decal for a more durable application.
92109F4D-3566-4443-AEBB-496E0D118482 (resized).jpeg14488B72-A442-4B92-B6C5-DE1D814C795D (resized).jpeg008655AB-4909-4C1D-AF6E-65EAECEB8805 (resized).jpeg58B26AA6-2BD2-4C99-8951-7E69CE756159 (resized).jpeg
#5602 3 years ago
Lower POTO is all set and can be reassembled.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#5603 3 years ago
I opened a box for the POTO labeled side rails.
Nice and new
But too short
I will rework the originals. It is a bit of a process. They can’t simply be powder coated because they need to be straightened
Clamp them in a vise with some wood to get the bends out.
Then work them over with a peck hammer.
Structural work is done.
Then sanded and the remaining low spots are wiped with filler. Then sanded straight.
67E00595-E2EC-40FD-AC73-0E9947D950C0 (resized).jpeg41399441-58C1-4F8F-8AE1-C25D3466A21F (resized).jpeg644EEFFA-3406-4E28-905F-65365538FDF2 (resized).jpeg
#5604 3 years ago
The rails are ready to refinish.
Rattle cans are the only option on some types of products. If you use them there is no way you can really shake them by hand well enough to really mix the contents thoroughly.
This is why a paint shaker is a needed tool
The first step is to etch the bare metal. Done
Now we need to create that textured finish.
First step there will be black chip guard.
If you keep a can of IJ on hand it is essential that you clean the tip before and after each use. This stuff is made to shield the lower portion of cars and trucks from chipping so ruining a plastic spray tip is no problem for it.
5750C100-EAA2-4B5A-88CF-48E94B9A86FA (resized).jpegF9B8CB95-467C-4859-B9FC-B9D363B6D163 (resized).jpegDD7FBF0C-1756-4C1A-82C8-4FA632B37B90 (resized).jpeg7F67CE0E-FD6C-41E2-8F2C-D0D31C5EB9C7 (resized).jpeg
#5605 3 years ago
The first pass of chip guard is sprayed.
It is black and there is absolutely an art to spraying it to get the finish you are looking for.
812B74A6-0138-49FA-9EA9-A218215EC2F0 (resized).jpegE92EC5E5-EB7D-40ED-8942-421504673227 (resized).jpeg83C6F3CC-0162-47A6-A5B2-F72FD6FD8C63 (resized).jpeg1E67F42B-4BCE-45B5-87A7-EC53057D6EB5 (resized).jpeg
#5606 3 years ago
The next pass is done with clear chip guard. Exact same product but clear and glossy.
This will add some depth to the finish and continue the layering process.
This will not be the final finish just another step towards it.
475F5D19-B5CD-4A51-A258-45CD8FC372D6 (resized).jpegD222A933-A789-45A3-9E4D-178D72F6F8AE (resized).jpeg4781A717-A19A-4174-9125-173DD2144A69 (resized).jpegE9492A9D-5AF3-475C-B025-757A031F32A7 (resized).jpeg
#5607 3 years ago
The final step is to spray it once again with the satin black chip guard.
This is done very strategically to also create more depth and layering as well as fine tune the final sheen.
Looks about right no more dents.
24C038A8-217B-4CF9-B4F8-0E2BEACB680A (resized).jpeg37FC569C-E9FF-44E4-8F5F-AB7EA5CCCBEC (resized).jpeg140B932C-7D65-41F2-AEF3-60EF60854DBE (resized).jpeg1185BB9A-B5A8-46B7-AECC-32C17D5A5B9C (resized).jpegF2CFC311-2463-44F0-8B31-E9538E22DF59 (resized).jpeg
#5608 3 years ago
Now that the rails are in order I will need to make some black screws to hold them on instead of nails.
I use a small case #4 x1/2 inch. These also are used to hold on bumper caps.
Can’t sand them best to blast. BECD8D4C-E924-4E86-B9E0-5ACDA05262FE (resized).jpeg
Good to go.
#5609 3 years ago
Unreal.
#5610 3 years ago
No kidding. Every day I open this thread and every day I'm astounded at what Chris does.
#5611 3 years ago
Same process is done to the lock bar to give a guaranteed match once everything is in place.
#5612 3 years ago
Your the man! Never thought about putting a rattle can in a shaker before! LOL That's just awesome!! Coming from a fellow autobody man
#5613 3 years ago
POTO cabinet is back on four legs.
Has upgraded leg plates one had to be cut to clear the cord housing.
New door was needed. I will see if I have any red reject buttons that fit at some point.
I will also see if I can light the start button if so it will probably just be GI
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#5614 3 years ago
I am drooling over this POTO restore. Just amazing (as always). Makes mine look like a turd
Chris
#5615 3 years ago
We start this Monday off at the warehouse loading up Fathoms.
One of these goes with the POTO.
The other with the long ago completed Special Centaur.
I was held up waiting for decent side rails for one the other didn’t make much sense to worry about until I got the POTO a bit further along
#5616 3 years ago
Chris, is that just a sheet of masonite on the truck bed? I have a lined bed, and would like to find a means to easily slide games onto the bed without damaging the bottom.
#5617 3 years ago
I have a small lot of cabinets I would like to get rid of.
They are STTNG ,MM
A really nice lower cab for T2 and BSD that has been decaled with gloss black powder coated trim.
No pictures or packing and shipping just want to get them out of the way. if they were junk I would have done this with them.
#5618 3 years ago
Quoted from sgtski1978:
Yes works great.
#5619 3 years ago
Thanks, Chris
#5620 3 years ago
Just when I think I've seen it all, that POTO side rail restoration takes the cake. Amazing process. Your auto body work must have been insane.
#5621 3 years ago
I have a HUO TAF that is way past ready for a refresh. I need to get off my arse and send it to you for a restore.
#5622 3 years ago
The Fathoms are unloaded.
One came loosely assembled in a new BIg Time cabinet.
Not a huge fan of that but it is fine as long as the owner is happy with it.
#5623 3 years ago
Spirit 2 is building back up along with the Fathom that needed rails.
17
#5624 3 years ago
Here is the issue with the rails.
This is a Marco rail.
This is a pinballife rail.
The grain is the proper direction.
It is nice and sturdy about twice as thick as the Marco version.
The Marco version is good for powder coating since the direction of the grain is irrelevant at that point and the thinner material gives some room for the added thickness of the powder but if installing the rails as is is desired the Pinballlife rails are the best option.
#5625 3 years ago
This gives me all the parts I need to build the new cabinet back up.
I have all that stuff pre plated but I don’t like to use it until I have the replacement/exchange parts in hand.
#5626 3 years ago
Quoted from High_End_Pins:
They are STTNG ,MM
No pictures or packing and shipping just want to get them out of the way. if they were junk I would have done this with them.[quoted image][quoted image]
Wish I lived close, I would take that T2 cab.
#5627 3 years ago
After working through various wiring hacks
7D305F73-DAB3-4C36-BA30-7FFBD112F741 (resized).jpeg2ED47D88-A498-4B2D-A94C-2A6720C1E3BF (resized).jpegmaking a drilling template for the side pivots and hardware 159A6E92-B6DB-4CE0-A78B-758646C47775 (resized).jpeg
Then measuring and comparing everything
8B2F0E3A-2718-46F3-8DAC-96CECC8BD0A6 (resized).jpeg8F6E6007-59F1-4D63-9AD6-EA8DE0E27B7C (resized).jpeg
test fitting everything
Fathom 1 cabinet is building up.
#5628 3 years ago
The good ole twisted wire trick! Did they at least put some solder on it?
#5629 3 years ago
Quoted from heni1977:
The good ole twisted wire trick! Did they at least put some solder on it?[quoted image]
I think so.
They ran this one straight from the target bank to the head.
#5630 3 years ago
I unpacked and set up the second Fathom that came in the Big time cabinet.
As predicted there are some concerns.
First the foam it was packed in is stuck to the face.
Hopefully I can deal with that.
Next the paint job kind of sucks because the corners don’t meet AADD384A-D757-4212-8152-12B597C6313A (resized).jpeg
Next I had a HELL of a time getting the backglass out. I had to pry the thing out.
The issue is that it is missing the proper reliefs for the lock arm.
This is correct as shown on Fathom 1
This is incorrect as shown on the Big Time Cabinet fathom 2
As I unpack everything the scope of the project becomes more evident.
The first thing I did was install the protectors at the legs and bevel the bottom edge of the cabinet.
4B61338E-E820-48AC-8F1A-F1A737C479B8 (resized).jpegAD3C540C-4812-4704-8D02-28FE546906F9 (resized).jpeg
#5631 3 years ago
After setting Fathom 2 up next to number 1 I am really having second thoughts about the Big time Cabinet
I hate the colors,nothing seems to fit,the paint job sucks,the foam imbedded in the face .The ground braid is a mess and while it is factoryish it just isn’t my style.
Three of the main things I focus on with my cabinets are that everything fits easily especially the backglass
The art work matches up corner to corner.
Another really important part is color choice and scheme.
The cabinet shades should match the apron and backglass shades if possible.
The BTC isn’t close
Fathom 1 is
11
#5632 3 years ago
Fathom 1’s lamp panel was in rough shape.
Instead of making a new one I can salvage this one.
Second sand flat and fiberglass glaze it since it is mdf
Now bust that down
Took a bit
Prime
Guidecoat
Dried overnight
Sanded and painted
Also dried overnight.
8352F6D1-A044-4B44-A33F-8555273CFEA0 (resized).jpeg644BAD67-DECC-48F0-A8EF-351FFB6DB1A8 (resized).jpeg7F11277C-D910-44A1-AB19-C0DA93202D40 (resized).jpeg
10
#5633 3 years ago
Back to POTO for a minute.
I prepped painted and cleared the wireforms.
The original coating was in good shape with just a little spot of wear in a spot or two so it was best to refresh them.
These will hold up even better this way because they have the original powder coat plus a light coat of fresh red base followed by two medium coats of clear.
327879C6-CC75-4F6C-8163-B8CDC8310AEF (resized).jpeg0D0E0BF4-8604-4C03-B656-639CF3BE0402 (resized).jpegB11A47B4-F743-48E2-A3D4-8DF6D19502F6 (resized).jpeg
#5634 3 years ago
Your wooden dollies you use under the cabinets for painting, would you care to share the dimensions? Are they built that size for a particular reason?
#5635 3 years ago
Quoted from nitrojcrawf:
48 long
16 wide
21 tall(without wheels)
They are just built in similar dimensions to a standard pinball dolly.
They are easily stacked and heads or other parts can be screwed to them if needed.
#5636 3 years ago
Fathom 1 lamp panel is rebuilt and placed.
New sockets,insulated wire
59259E0F-17CC-485C-B8B1-476F893E18E9 (resized).jpeg295CF9E2-F9C8-40F8-992F-4FC4C88B9CA2 (resized).jpeg23EA7812-E7D0-4B27-95EA-311CD42ED0D2 (resized).jpegC4EC48D8-5416-415E-A891-7FD82F4E2917 (resized).jpegDE660100-F948-45EC-B031-810E5B0C2BEB (resized).jpeg
#5637 3 years ago
Then built for and installed Fathom 1
#5638 3 years ago
Who helps you pick up and place CABs onto and off the dollies for painting or other assembly processes.
or does all your workouts allow you to man handle it all yourself?
#5639 3 years ago
Fathom 1 Cabinet is wired and powered up for testing.
#5640 3 years ago
I am ready to settle in and start the Fathom 1 playfield build up. I have already thoroughly cleaned the wiring.
First step is to get the banks off and onto plugs.
These are probably the worst two since they have the knock down feature which means 4 coils and three switches per bank
#5641 3 years ago
I will enlist the help of the yeti.
#5642 3 years ago
Quoted from pinwiztom:
I can generally manage the empty cabinets myself but if not then it’s the wife or Curtis that are there when needed.
#5643 3 years ago
I will enlist the help of the yeti.[quoted image]
That looks so good!
#5644 3 years ago
After tearing down the old Fathom 1 playfield and adding the various connectors I am ready to build up the new one.
A9FA81D6-DA8A-4B75-A391-89B88EDDD45C (resized).jpeg97A8ACB0-0D0E-4770-8AC2-DD8A5BB50593 (resized).jpeg088182F2-9648-4C7F-BE1D-0E1D7A2C0542 (resized).jpegF8B1AD19-07D9-476E-96D0-6CBE76DB9EDD (resized).jpeg69EE4D0B-CF29-4645-AAEA-A8FA03665C42 (resized).jpeg375E9A44-C36D-4E95-B263-B59F01D66AC8 (resized).jpeg
#5645 3 years ago
Thats a days worth of Molex connector install on that wire loom!
#5646 3 years ago
Fathom 1 playfield slowly building up.
The wire guide holes have been a challenge.
There are lots of them and many were hard to spot or in need of adjustment.
#5647 3 years ago
There are lots of them and many were hard to spot or in need of adjustment.[quoted image][quoted image]
Mirror-polished ball guides are so great. Love that look.
#5648 3 years ago
Quoted from PinMonk:
That is factory on these.
I actually had a set of stainless I debated on using but these polished back up well with only a slight trail.
Ready to flip and wire shouldn’t be too bad once I get through the lamp sockets.
#5649 3 years ago
Underside build up begins.
First are the switches. They have new caps and protections as needed.
#5650 3 years ago
Lamp sockets will start tomorrow.
All this has to be copied.
Gweem's Mods
Sound/Speakers
$ 35.99
$ 18.95
$ 19.95
Toys/Add-ons
$ 54.99
Shooter rods
$ 39.00
Sparky Pinball
Toys/Add-ons
This page was printed from https://pinside.com/pinball/forum/topic/hep-this-week-9-17-18/page/113 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
