(Topic ID: 225528)
HEP This Week 3-14-23
By High_End_Pins
  • 12,169 posts
  • 584 Pinsiders participating
  • Latest reply 5 hours ago by number_runner
  • Topic is favorited by 574 Pinsiders
Topic poll
“EBD Trim legs will be black regardless ”
  • Stainless/Factory 35 votes
    31%
  • Blacked out 54 votes
    48%
  • Painted Gold matched to cabinet 24 votes
    21%
(113 votes)
This poll has been closed.
180 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 12,169 posts in this topic. You are on page 109 of 244.
#5401 3 years ago
Quoted from High_End_Pins:
They turned out great The key is to leave some slack in there for them to move around.[quoted image]
Once they come out of the tumbler, do how do you protect them? The tumbler usually removes some sort of protective coating on the metal.
#5402 3 years ago
Quoted from epeabs:
flitz in the media adds a bit of a wax/polish protective coating to the parts
#5403 3 years ago
Spent this morning working on a NOS BSD playfield.
When this was sent to me I thought it would be an easy thing to squeeze in.
Turned out to be a much bigger job because it was not drilled nor dimpled on either side
It also had moisture issues.
The need to drill and dimple it meant it would have to sit until I found or had a good template to work off of.
That finally happened when I completed my last BSD project. That playfield was rough enough to justify using.
#5404 3 years ago
The topside was drilled and dimpled first.
3575315D-7418-4CF0-89A3-8035162EA4CA (resized).jpegCE0C3631-672F-4473-B9E7-89ABFE2CF09E (resized).jpeg6D0C02F6-E17F-44EC-8B34-B8AA5E1AC5CB (resized).jpegF0FBF242-7A15-4C9E-8BEE-292C6DFC213C (resized).jpeg
#5405 3 years ago
Then the underside was done. There were so many holes to place I used a marker to keep track.
EA363038-B70B-4B52-8909-6D57F2A962D3 (resized).jpeg543A048E-BA9F-4370-B433-32C655673E76 (resized).jpeg67959AD2-843F-41B3-8A94-DEAFFFF36F05 (resized).jpegF99B9809-3506-411F-8D2B-E504B1812D92 (resized).jpeg26ED9BD5-0236-4FF1-9C86-D69F3DB74A9C (resized).jpeg8B903FB7-4E3A-41BE-8DB0-1574DF1F21D0 (resized).jpeg
#5406 3 years ago
Then it was prepped for the first clear application.
The playfield doesn’t have any major scratches but it has quite a few small nicks. D0257F14-B753-4679-B0D2-E49E512F4B89 (resized).jpeg
When the issues are this small sometimes a simpler approach works best. You can’t accurately match gradients especially in tiny spots.
What I like best in these situations is just to study the art itself and enhance that.
Here are two small examples.
Small white dot works better than a mismatched gradient and it looks completely factory. E90E9B77-9572-449D-9698-B859A5CAC5C0 (resized).jpeg
Same approach here
#5407 3 years ago
The playfield is then cleared for the first time.
There is more work needed but this is the foundation to work off of.
The main concerns from here on will be trying to clean up the natural wood in the holes where it has a blackened/mildew look and getting the inserts closer to level in some areas.
6BD6A1CB-0006-4BFA-8655-BA3C9DD59AB4 (resized).jpegF56EC8BD-CB19-4096-81AA-D1D63575ACF2 (resized).jpeg36041DD4-76EA-4228-B872-D0B196F08B86 (resized).jpegA1A6DE29-FF9A-4A02-ACEE-6A8DD5135AFD (resized).jpeg54B5FAA3-9EAB-4D6B-8784-BD15CA79D28A (resized).jpeg167FDC2B-3EBE-4D00-8A8A-07B3907ADD2E (resized).jpegF80DE24C-C3D1-429A-BB02-72FE4D1DC713 (resized).jpegC5699D2B-845D-4B4A-8EC8-55C33EE8556C (resized).jpegA4DE5051-4CD1-4B13-8399-9A87638DA7B3 (resized).jpegF6536C61-4A14-497A-9809-E2E3F77C132A (resized).jpeg
#5408 3 years ago
You do incredible work. High attention to detail. And i like the way you find work arounds for impossible stuff like matching the gradients.
Does anyone ever ask you to do your magic to more modern titles like machines that are from 2000s or 2010s? I was thinking classic sterns like LOTR or TSPP are getting toward the age where they may be rolling through?
#5409 3 years ago
Quoted from Rickwh:
Check out the topic index at the top of each page in this thread. It has most of the completed pins linked. There's a link to a completed Simpsons in there. He did a LotR, too, but I don't recall seeing final pictures for that one, just some in-progress ones.
#5410 3 years ago
These are always a pain to pick out of the tumbler then a pain to pick the media out of.
That was solved with some simple zip ties.
You do realized that half the forum just sh*t themselves for never having thought of that before?
#5411 3 years ago
Hey Chris, have you seen this yet? There is supposed to be a special compound and pad to use with it but I haven’t seen it.
#5412 3 years ago
Quoted from bam10:
Hey Chris, have you seen this yet? There is supposed to be a special compound and pad to use with it but I haven’t seen it.[quoted image]
No. I haven’t.
For me I find most of the time that grits that go over 2500 to 3000 are not going to do much of anything substantial enough to justify the step.
If you were polishing a jet black show car that no one could even touch it might be practical but nothing useful in the world of pinball I can think of.
#5413 3 years ago
No. I haven’t.
3m says that using 8000 after 3000 you use the dedicated pad and polish for 1 step buffing. We will see
#5414 3 years ago
No. I haven’t.
I had a jet black car once - my first and my last. It looked great for about two hours after being washed.
#5415 3 years ago
Quoted from lb1:
LoL same here. My saying is everyone owns a black car..... once.
12
#5416 3 years ago
SC playfield is fully wired now.
Then placed in the cabinet.
A5BCF6EA-DB95-4DD0-92E2-5A7837E89435 (resized).jpeg9F2FCDA5-A4CD-4658-95DB-1B933272ECC0 (resized).jpeg2A9542F2-7D1C-43FE-BBBE-02CC223DCEB2 (resized).jpeg438418E9-4DEE-45CC-87D9-DE11D82554FD (resized).jpeg6C7A420A-4D18-4109-A645-710B7B7EDE45 (resized).jpegB2E9103C-F1B0-4EB4-B585-93145DB140D9 (resized).jpeg114EE8F8-86E7-4414-A6E7-A25FD16C31DB (resized).jpeg
#5417 3 years ago
I detect a briney note in the air.
#5418 3 years ago
SC Apron is placed then powered up for testing.
923228AB-EAC6-4FAE-8C0D-B291D6E9EDF7 (resized).jpegBED45D62-98E3-4B0D-816F-9745D3AD5DC7 (resized).jpeg
#5419 3 years ago
Following. Took me 3 years to track down all the new old stock parts for my high end phantom of the opera restore. good luck man
#5420 3 years ago
Getting pretty close to finished with the SC.
12
#5421 3 years ago
One of the last details for the SC is to make the bank look a little more realistic.
Using a multi step process of misting and shading different base coats over one another
Then intermixing those here and there
The bank is ready. The idea is to make it look like it is made of granite or stone. I don’t want to overdo the details and make it look sloppy so I rely on the shading to give it some depth in areas that would be carved like the lettering then just accent what I think would be symbols and the handles.
EFBE761C-BB1B-4149-ADCA-95418E26A3F5 (resized).jpegC446C06F-F4CD-4B8D-8237-CD8918184D81 (resized).jpeg
#5422 3 years ago
Brilliant!
#5423 3 years ago
Damn dude, that SC is beautiful. That game is such a pain in the ass.
#5424 3 years ago
Quoted from TaylorVA:
Thanks Taylor.
I hadn’t done one for a couple years and had forgotten just how cramped it is to work on.
12
#5425 3 years ago
The bank is now placed.
I added a subtle spotlight to help brighten it up and make it a bit more of a focal point. 07814D48-428A-45C5-9D6E-C7E73102BD83 (resized).jpeg
Truthfully this entire area could use a little more light because there is just no GI anywhere near the spinning dial. 7513BE02-9252-4295-95FE-8E4A4A836626 (resized).jpeg
The spotlight blends in well.It would have been easier to mount it on the plastic above the upper flipper but that would have block the line of site for the player FF566995-F371-4B58-A0EB-EB254BDC5D3C (resized).jpeg
#5426 3 years ago
Game is powered up
This is without the spot light.
The rest are with both highlighting the bank itself and the better overall lighting in that general area now.
I am not a big spotlight guy but this one was a good addition.
A6209367-8AB6-4F0A-AAAF-06D2851C1DB7 (resized).jpegFCC2DE0C-46CC-464B-A1FE-D3B844513972 (resized).jpegD44433A2-A3C5-48FA-B00F-A0F6B9AE8949 (resized).jpeg
#5427 3 years ago
I'd deposit my money there.
14
#5428 3 years ago
SC is all set. Should make it outside for pictures later today.
Still trying to get the timing back down with the time change.
#5429 3 years ago
Still trying to get the timing back down with the time change.[quoted image]
Gorgeous!!!!
#5430 3 years ago
She's a beaut Clark!
#5431 3 years ago
Quoted from ChrisS:
Hey Chris,
I may have missed someone asking before but do you have and collect pins at this point? Do you play or with doing all the restores you find you don't want to play once your day job is done.
Just curious.
Love the thread. It's impressive and keeps me motivated to work on my projects.
No I don’t collect pins anymore and only play for fun a few times a year.
I still enjoy the process and hobby in general just not that aspect of it anymore.
The job and occasional grind of doing this for a living definitely plays a factor in it.
#5432 3 years ago
I added a subtle spotlight to help brighten it up and make it a bit more of a focal point. [quoted image]
Truthfully this entire area could use a little more light because there is just no GI anywhere near the spinning dial. [quoted image]
The spotlight blends in well.It would have been easier to mount it on the plastic above the upper flipper but that would have block the line of site for the player [quoted image]
Those tiny directional LED spotlights Stern started using on Deadpool would be perfect for this. They don't need a large cone to direct the light and the whole assembly is about as big as a dime.
#5433 3 years ago
I would agree with that sentiment except for one experience in my life. I worked at a pizza restaurant all through high school and during summers and winter time off in college. I worked 40 plus hours a week making pizza, I ate pizza 3-4 times a week for 5-6 years, and to this day I still love pizza - all kinds.
#5434 3 years ago
and another great one from HEP!!
16
#5435 3 years ago
SC finished.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#5436 3 years ago
SC playfield.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#5437 3 years ago
SC inside.
#5438 3 years ago
Do you mind me asking what you used at the top of the translite glass to block the view above the backboard assembly?
That has to be the nicest SC in existence. Amazing work.
#5439 3 years ago
Quoted from Steve_in_Escalon:
Thanks.
I used this stuff.
Placed just below the top channel then the side channels are installed.
#5440 3 years ago
Awesome Safecracker restore!!! Owned one once for a week before I flipped it, kinda wish I kept it.
I will say this for Safecracker: it is a HEAVY ASS pin for as small as it is!!!
#5441 3 years ago
Quoted from AUKraut:
SC was the first game I ever did.
Looks like that was over 17 years ago. Time really does fly.
#5442 3 years ago
I will pack the SC up and ship it straight out of here too heavy and awkward to move around anymore than I need to.
What’s next? TOM.
Should go quick.
Then Fathom I have been waiting for decent side rails to be available again.
The last few batches I had received were terrible.
These were just some of the issues.
Ripples down the entire bend.
Mis matched grain patterns one is a left the other is a right. Completely unusable.
The protective film seems to protect them from sending a decent set of rails despite charging for them. It is really ridiculous. Parts quality continues its decline into the very basics at this point.
#5443 3 years ago
For as many rails as you replace, I'm surprised you can't just get a local shop to make up bunch for you. Nothing special about metal when you're a metal guy.
#5444 3 years ago
SC is pre packed. Maverick supervises.
I will palletize it once I know the pick up day.
E5D00319-B7C2-499F-9A52-E931D1AC3BF4 (resized).jpegC03B130A-E9C6-41BD-B62B-DC880BACA5B8 (resized).jpeg
#5445 3 years ago
The TOM is set up to teardown
" Pretty typical TOM. Broken trap door bracket corrosion etc.[att=5295911,1788352 caption="1DB001C6-EB55-4C7D-836F-9583B5A6CBFA (resized).jpeg73BC9167-9E1B-4434-A23F-FDB42473E7D5 (resized).jpeg40432F7A-3BD4-4F4E-ADFD-498643CD7087 (resized).jpegA1EA3AFB-B17A-4E7C-90C3-4488AA42CA13 (resized).jpegE91A58EF-2854-48EA-B3A6-F859FF0AB2C6 (resized).jpegEEF6DF91-96DF-4D67-B61A-24675A4C5DCE (resized).jpeg
#5446 3 years ago
Thanks so much for letting us look behind the curtain on your process. You are truly a wizard!
I have a quick question. Referring to the photo you posted (quoted) after re-drilling the ball guide through hole... Do you attempt to fill the old hole in the replacement playfield field?
Thanks and please keep up the amazing work!
#5447 3 years ago
Quoted from Walamab:
On that particular fix or adjustment I like to file it and make it more of a slot then use a washer under the post of the ballguide. That gives me more flexibility during the assembly.
#5448 3 years ago
Gutting the TOM base game.
First up is the lamp panel from the backbox.
This one is made out of plywood and is missing a chunk.
The backside isn’t too back some wire and socket issues.
The panel is gutted then repaired and refinished.
04C9DD8E-533D-4A7F-AF7E-DD4B4375B2ED (resized).jpeg17A6B33B-85FA-438A-A372-211E64B1A85D (resized).jpeg362DD1EA-3BC6-499C-856E-2CB5357BF5E2 (resized).jpegD9684AB6-5067-4C1C-8CA7-E763FDE2D86E (resized).jpeg
#5449 3 years ago
Panel is then rebuilt with plated parts and new sockets as needed.
7600D41B-7207-4368-B7AA-57C9E8F7D0EB (resized).jpeg320AB681-93EF-44B3-A773-A0B6B6BEF991 (resized).jpeg86EE0692-5A84-46F8-967E-187266485C17 (resized).jpegBB4637B6-0215-4E7F-A88F-F05A245D3C6B (resized).jpegDF592B55-83FC-4FB1-8E1A-F10D8E418F40 (resized).jpeg
#5450 3 years ago
I have a special request. I've owned and partially restored/maintained my TOM for many years. I've taken apart the armature/trap door mechanical assembly a thousand times. I've never found an adequate solution to eliminating the eventual pop-out-straight-down-the-middle issue. New armatures, weaker coils, it's been one continuous, losing battle!
I'd love to see what you do in your restoration to this assembly, and what tricks you might have to avoiding this problem (shared with many TOM owners).
$ 49.99
Toys/Add-ons
Pinhead mods
Protection
Protection
This page was printed from https://pinside.com/pinball/forum/topic/hep-this-week-9-17-18/page/109 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
