(Topic ID: 225528)
HEP This Week
By High_End_Pins
5 years ago
  • 14,080 posts
  • 630 Pinsiders participating
  • Latest reply 3 hours ago by High_End_Pins
  • Topic is favorited by 623 Pinsiders
Topic poll
“EBD Trim legs will be black regardless ”
  • Stainless/Factory 35 votes
    31%
  • Blacked out 54 votes
    48%
  • Painted Gold matched to cabinet 24 votes
    21%
(113 votes)
This poll has been closed.
204 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 14,080 posts in this topic. You are on page 101 of 282.
#5001 4 years ago
Quoted from Langless28:
Do you only stock your wire collection in 18awg? So you don't mind replacing a smaller wire with 18awg as long as they are color correct?
Depends on the application.
Some are exclusively stocked in 18 others exclusively stocked in 22 and there are some color combinations that are stocked in both.
Switches and feature lamps are 22
Coils main runs of GI are generally 18 but sometimes chained with 22.
Grounding sides of coils can sometimes be 22 if not and if color coordination is a concern but I really need a 18 in those cases I will use two 22s that are color correct.
#5002 4 years ago
Working on mini harnesses for the switches on the BSD
Each roll over is done on two Pins regardless of location.
All wiring is color correct to aid common sense if working on the game. image (resized).jpgimage (resized).jpg
The jet switches are done on three pins with leg protection.
Targets are done in a similar way.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#5003 4 years ago
chris
when you add the molex connectors, are you standardizing the orientation of your wiring?
with the joust playfield swap, I'm finding that 99% of my connections are of the two wire variety with red and some combination of white, gray, brown, blue or some striped variation. with all of my connectors, I've oriented them so that the [pointed] end of the connector is always red (and I use some variation of pin and socket on the plug or recepticle end
in the event that should someone inadvertently plug the wrong 2 connectors together, it eliminates the potential for shorting out the circuit
#5004 4 years ago
Quoted from j_m_:
chris
Yes I do.
#5005 4 years ago
Just about ready to place the harnesses.
These will be pretty much just a matter of plugging everything together at this point.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#5006 4 years ago
BSD playfield is wired
I switched over to the taller playfield resting brackets
I can’t see any reason they should not work but if I run into anything I will let that be known.
I like the higher resting points with this style compared to the original. image (resized).jpgimage (resized).jpg
Should be particularly advantageous on this side since the pictured coil bracket is taller than the original resting bracket.
#5007 4 years ago
Quoted from Nhpolarbear:
I enjoyed your interview on Loser Kid podcast.
Same here. A good listen.
10
#5008 4 years ago
BSD playfield has made it’s way into the cabinet.
#5009 4 years ago
Quoted from chalkup8:
Ditto! I was hoping the interview with Chris was the whole 2 hours! If I was interviewing him it would have been! Thanks for taking the time Chris!
#5010 4 years ago
BSD lives
I think the caps and Lane guides will work well once fully assembled. I like the lighting.
I think blue would have been a better background choice on the plastics instead of purple since the playfield is more blue based but we have to work with what we are given
42A3EDA8-D34D-48E3-9C23-B8635995003D (resized).jpeg42A3EDA8-D34D-48E3-9C23-B8635995003D (resized).jpegF2C3DA7C-49BB-4CB6-B48E-5740E37E6B0A (resized).jpegF2C3DA7C-49BB-4CB6-B48E-5740E37E6B0A (resized).jpeg1051A9A7-EA5D-4325-BD47-49805773D358 (resized).jpeg1051A9A7-EA5D-4325-BD47-49805773D358 (resized).jpegimage (resized).jpgimage (resized).jpg
#5011 4 years ago
is ron jeremy going back into this BSD or is it being replaced with one of brock's mods? he did a really awesome job on the sculpting (I just wish that he followed through on the flickering torches)
#5012 4 years ago
Not Ron..
A585D86D-82E7-47A3-A695-536D1C4D03C2 (resized).jpegA585D86D-82E7-47A3-A695-536D1C4D03C2 (resized).jpeg
#5013 4 years ago
Since Ron was tied up with Jim we got this guy instead.
62C7D032-5D2E-4DA4-AEBB-8A0BE46F494E (resized).jpeg62C7D032-5D2E-4DA4-AEBB-8A0BE46F494E (resized).jpeg
#5014 4 years ago
Almost there on the BSD. This one has really been dragging out.
Due to corrosion and theme I have shrink tubed(?)all stand offs.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#5015 4 years ago
It's one thing to be good at playfield touch ups
It's one thing to be good at clear coating
It's one thing to be good at wiring
It's one thing to be good at cabinet restoration / decals
It's one thing to be good at choosing good beer
It's another level altogether to be good at ALL these things!
Love this thread!
Chris
13
#5016 4 years ago
BSD is done.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
10
#5017 4 years ago
Playfield
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#5018 4 years ago
That's bloody beautiful work by HEP once again! Bam Stroker would be proud (spelling on purpose since I here it a lot).
10
#5019 4 years ago
Inside.
#5020 4 years ago
Really kind of amazing watching these come to life. I'm fascinated by the skills coming together and executed so well by one person...the wiring alone is mind bending... and so many different parts... so many different machines and configurations...very well done
#5021 4 years ago
Quoted from fooflighter:
Thank you.
That reminds me about something I meant to do which is mention the Mod father.
He did a great job painting those village buildings.
It is something I could do myself if needed but he does it so well and quickly why bother?!
Thanks Chuck!
#5022 4 years ago
Quoted from High_End_Pins:
Thank you.
Thanks Chuck!
I really like the shrink on standoff trick!
Shrink comes in many colors.
I can see infinite possibilities with this.
Thanks.
#5024 4 years ago
Inside.[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Is burning your brand into the playfield your favorite part of the restore? Probably elicits a real sense of accomplishment and pride, I would assume.
#5025 4 years ago
Such an awesome looking BSD. Love the small touches, like the black buttons with red inserts.
#5026 4 years ago
Quoted from Mr_Tantrum:
It is in the top five. When I get to that point I know I am almost done.
#5027 4 years ago
Time to start setting up the next games.
Right now I am actively working on the following
Spirit 2
Spirit 3
HG 2
TOTAN
Radical
Fathom
POTO
Of those TOTAN and HG 2 are ready to start closing out.
The weird thing is that means it is time to actually set them up
TOTAN on legs it’s a rough one.
#5028 4 years ago
TOTAN on legs it’s a rough one.[quoted image][quoted image][quoted image][quoted image][quoted image]
Not for long!
Chris
#5029 4 years ago
Depositing the customer's check in the bank is probably number one.
#5030 4 years ago
Random question out of sheer curiosity - how long does it take to go through (or play) the game to make sure all the switches are adjusted properly, pops are registering strong, etc. I've never restored a game but I can assume that is a time consuming pain to go through and make sure it plays great in addition to looking great.
#5031 4 years ago
Quoted from grantopia:
Some take minutes others hours. In the past it could take days and be frustrating but I learned to really pay close attention to certain processes and make it very serviceable during the build.
This takes much more time and effort on the front end but saves a ton of time and aggravation on the back end.
One of the worst things to have to do is to take a game halfway apart after assembling in order to adjust a ball guide or replace a switch so I automatically just replace,adjust and check the flow of everything as I place it instead of just slamming it together and trying to figure out what’s wrong later.
By doing that I rarely if ever have to remove any parts after the build nor spend countless hours troubleshooting.
#5032 4 years ago
The only thing missing is the Willuams/Bally serial tags inside the cabinet and on back side.
#5033 4 years ago
Quoted from chad:
I quit using those. I am working on developing my own
The reason is that besides the originality aspect of it they are kind of pointless here.
What would be better is something that gives it a more accurate born on type of date once it has been done.
#5034 4 years ago
HG new cabinet is up on four legs. Well kind of.
#5035 4 years ago
I heard that chris has top men working on it
top men!
#5036 4 years ago
BSD is packed and ready to go across the country.
AAD366E1-BDF1-4F71-A9F7-9092E833390F (resized).jpegAAD366E1-BDF1-4F71-A9F7-9092E833390F (resized).jpegimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#5037 4 years ago
Got Spirit 1 packed and ready to also cross the country.
259AA1DE-194E-49BA-A438-A0A34B0B53BD (resized).jpeg259AA1DE-194E-49BA-A438-A0A34B0B53BD (resized).jpeg572604E0-83A9-46F1-B0BB-74A447A3EC19 (resized).jpeg572604E0-83A9-46F1-B0BB-74A447A3EC19 (resized).jpeg
#5038 4 years ago
Now I will spend a quiet evening with Basic
Becky.
She is new around here
874B7DB1-0CD5-4950-B38C-16F0380DB2EB (resized).jpeg874B7DB1-0CD5-4950-B38C-16F0380DB2EB (resized).jpegE0F6D4C2-9A26-4F45-99EB-7FD86380294A (resized).jpegE0F6D4C2-9A26-4F45-99EB-7FD86380294A (resized).jpeg
#5039 4 years ago
When I was an electrical apprentice I had a Foreman that would say" Bluff the rough, face the finish". It's another cheesy construction saying, but it rings true through all trades. Preparation is everything. This is my favorite Pinside thread, please keep it up.
#5040 4 years ago
Radical cabinet is ready for rebuild.
Cabinet protectors
#5041 4 years ago
Radical lower up on 4 legs with rails.
Gloss black was the requested trim.
Works pretty good. Blends n and let’s the art pop out a bit more.
I had thought about painting a set of legs to match the yellow stripe and pattern since I could match that 100% and they are at the leg locations anyway but then thought” why continue to torture myself?”
#5042 4 years ago
Cabinet protectors
Do you cut the decal around the protectors to provide relief and prevent wrinkles?
#5043 4 years ago
Quoted from Atari_Daze:
Yes on decaled cabinets. Not on this one though because the repairs around the legs have already solved the problem.
#5044 4 years ago
Also requested on the Radical and now installed are inside decals.
6BF5CC24-F298-4AFF-A07B-38AF20910318 (resized).jpeg6BF5CC24-F298-4AFF-A07B-38AF20910318 (resized).jpeg
#5046 4 years ago
Head is now built and placed on the Radical lower.
Found a pretty nice matching blue t moving.
12
#5047 4 years ago
Broke out the GI BCS and grabbed my board.
Probably a bad combo.
9A70986E-D125-4F3A-BC8D-83D5D9FF3747 (resized).jpeg9A70986E-D125-4F3A-BC8D-83D5D9FF3747 (resized).jpegA23050C8-91E1-4C0E-958A-C5626264E42C (resized).jpegA23050C8-91E1-4C0E-958A-C5626264E42C (resized).jpeg086AF9E9-0889-46E3-B2BB-88EF8FF4C4D5 (resized).jpeg086AF9E9-0889-46E3-B2BB-88EF8FF4C4D5 (resized).jpeg
#5048 4 years ago
Broke out the GI and grabbed my board.
Especially right next to that nice looking cabinet job!
11
#5049 4 years ago
Quoted from too-many-pins:
Yeah. We decided it would be less risky indoors for Maverick to skate.
He picked right up on that even knew when to bail.
#5050 4 years ago
Love It! I am a big Maverick fan. See ya in a couple weeks! -Skip-
Tools
Pincoder Store
Tools
10,500
Corbin, KY
$ 8.00
Playfield - Plastics
Minty's Mods
Plastics
$ 29.99
Pinball Shark
Shooter rods
$ 109.95
pinballmod
Toys/Add-ons
4,200 (Firm)
Gresham, OR
pinballmod
Toys/Add-ons
Metal-Mods
Decals
$ 84.99
FlyLand Designs
Decals
Displays
PinballSolutions.eu
Displays
$ 649.95
Pin Stadium Pinball Mods
Led
Mitchell Lighting
Led
$ 18.00
£ 38.00
PinballToys
Led
$ 9.95
$ 225.00
Cabinet - (Alt) Translites
FlyLand Designs
(Alt) Translites
$ 1.29
Daddio's 3D Printed Mods
Toys/Add-ons
Pinball Photos LLC
Decorations
$ 18.00
2,995 (OBO)
Castro Valley, CA
YouBentMyWookie
Other
$ 63.00
Toys/Add-ons
Decorations
$ 27.50
$ 225.00
FlyLand Designs
(Alt) Translites
$ 18.99
Tools
FlipMods
Tools
$ 27.95
This page was printed from https://pinside.com/pinball/forum/topic/hep-this-week-9-17-18/page/101 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
