Starting with MM 1 we will go over conditions from the inside out.
This is without a doubt the worst MM I have seen. Not so much cosmetically but mechanically. Although the cosmetics are bad too.
Top to bottom.
At the flipper section underside I will do my best to show everything that is wrong compared to MM 2.
MM 2
MM 1 auto fire bracket broken and welded together crooked
MM 1 flipper assemblies are complete garbage.
Wrong plungers,wrong switches,missing parts and more. image (resized).jpgimage (resized).jpgimage (resized).jpg
MM 2 has at least a respectable normal flipper set.
