HEP Pinball Magic 2018 Finished 10-13-18
(Topic ID: 211164)
By High_End_Pins
10 months ago
  • 248 posts
  • 50 Pinsiders participating
  • Latest reply 3 months ago by yancy
  • Topic is favorited by 76 Pinsiders
There have been 386 images uploaded to this topic. (View topic image gallery).
There are 248 posts in this topic. You are on page 2 of 5.
#51 7 months ago
Playfield is out of the cabinet.
All sub assemblies removed so far are on plugs now.
#52 7 months ago
Following again ... Just played a game! Tough to shop best of luck!
#53 7 months ago
Quoted from transprtr4u:
Thanks. Should stay pretty current in terms of updates to the thread now that the seal is broken.
#54 7 months ago
Subscribed!
#55 7 months ago
Following along. I'm definitely switching coils to plugs on my future restorations/playfield swaps.
#56 7 months ago
Quoted from pinheadpierre:
I agree with this statement, my Houdini is all done with plugs, so much easier to work with!
#57 7 months ago
Wiring is removed.
#58 7 months ago
Full Mylar is being removed.
#59 7 months ago
Mylar is removed along with the glue.
#60 7 months ago
Nice job on the Mylar removal no paint or insert lift!
Impressive!
#61 7 months ago
Gutting the cabinet.
#62 7 months ago
Impressive!
Thanks. I actually have a NOS playfield but I hate to waste it since the game really doesn’t need it.
Nice insurance policy though.
#63 7 months ago
Head and trim are off.
Just about ready to go into the paint shop.
#64 7 months ago
Quoted from High_End_Pins:
If you ever want to part with it ... I would love to have it clear coated!
#65 7 months ago
Cabinet is now stripped completely.
#66 7 months ago
Cabinet is ready to prep.
#67 7 months ago
Before I get to that I will drill and dimple the NOS playfield.
I doubt I use it for this project but at the same time this will be my only chance to have a template to work off of. The NOS playfield has most holes but no dimples at all top or bottom.
I will make a template off the original playfield.
#68 7 months ago
Paper is cut out in the exact outer shape and size of the playfield then anchored with tape so it is tight.
#69 7 months ago
Some basic “landmarks” are cut into the paper for ease of alignment once transferred over to the NOS playfield.
#70 7 months ago
Underside template is made and can be transferred over now.
#71 7 months ago
Placing the template on the NOS is pretty easy with the landmark cut outs
#72 7 months ago
Template is now secured.
I do not actually dimple I predrill using a small bit and a guard so it cannot go past the first layer or two.
#73 7 months ago
Everything now predrilled underneath and checked off for verification.
#74 7 months ago
Template is removed from the NOS playfield and then the underside is sanded clean to remove any burrs.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#75 7 months ago
Impressive!
Yeah, I've heard horror stories about mylar removal on this game. Mine could use it but I'm not that brave / stupid to try it.
#76 7 months ago
Same method used on the topside.
#77 7 months ago
Looks nice. Someone mentioned there was a 3 pop bumper version?
#78 7 months ago
Looking great! Thanks for sharing!
#79 7 months ago
I really appreciate the documentation of how to transfer dimples. That's something that looks so simple when you do it!
#80 7 months ago
Quoted from pintechev:
True artisan!
#81 7 months ago
Going to prep and clear the playfields today.
#82 7 months ago
Nice job! Do you always start at 180 grit and work your way up or just 180?
#83 7 months ago
Quoted from KornFreak28:
Depending on rough the lane is or how deep I want to cut I could start as rough as 80 it as fine as 320.
#84 7 months ago
Playfields are prepped. Not cleaned or touched up just prepped
While I am still doing the dustier operations I am going to prep the cabinet as well.
What a I want to do before I start doing any serious masking or painting is clear it so it will be less fragile during that process.
Before I do that I will address the few structural repairs. One panel at a time.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#85 7 months ago
First side is done.
#86 7 months ago
Second side in process.
While it hardens I will shift over to the lower cab.
The neck was loose and not correctly lined up on all three sides so it is removed.
#87 7 months ago
I will remove all the nails and staples.
It looks like this has been addressed once before at some time.
#88 7 months ago
Panel is prepped and ready to reattach.
Then reattached using slightly larger barbed finish nails where the staples once were.
#89 7 months ago
Some of the plys were separating on the transformer support so I have injested glue and wrapped with tape as a way to clamp.
Later on in the process I will install a support block under it as well. Since it is slotted into the cabinet walls I prefer to repair and shore it up over replacing it.
#90 7 months ago
Working on the lower cabinet repairs and seams now.
#91 7 months ago
Initial cabinet repairs are complete. The entire cabinet is now lightly scuffed and will then be chemically cleaned and prepped.
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#92 7 months ago
Was it not cost effective to build a new cabinet with the Capcom style? I don't think I've seen you restore a cabinet in awhile.
#93 7 months ago
Quoted from turbo20lbs:
Just depends on the game and art options.
Stenciled cabinets would definitely go with new cabs
Decaled cabinets pretty much the same but on a game like this where you have to save the existing art it is not possible because of the art options not the construction itself.
#94 7 months ago
NOS playfield prepped. Does not need anything more to be cleared.
#95 7 months ago
Original playfield prepped.
Will need some very minor touch ups from the disassembly process not due to wear.
This would be things like minor chipping at the wire guide spots and a spot here or there where a or part bonded over the years.
These spots will just need a little brush touch since they will be covered back up during reassembly. No need to turn a tiny spot into a huge repaint in this case.
#96 7 months ago
Minor touch ups are done on the original.
Not much effort put into that just more for the current presentations sake.
Once I clear it I can revisit them if needed but for now just putting back anything that was missing.
#97 7 months ago
Cabinet is prepped and mask.
First will be applying adhesion promoter.
This is very important since I can only lightly sand without getting into the colors of the art work.
#98 7 months ago
Adhesion promoter applied and the purple breakthroughs are just lightly airbrushed in freestyle no masking.
I am doing that just to fill the gaps but will do a much more detailed masking and painting on the next pass.
#99 7 months ago
Thank you for documenting all these restores. I'm sure these threads have helped inform and inspire tons of people.
#100 7 months ago
As always thanks for posting. What are you using for an adhesion promoter?
$ 45.00
Clayton, NC
$ 50.00
$ 239.00
Tilttopper
3D MODS
$ 32.00
Hdmike mods
Bright Lights Pinball
$ 69.95
