(Topic ID: 166226)
HEP MEDUSA Restore Finished 10-29
By High_End_Pins
  • 397 posts
  • 87 Pinsiders participating
  • Latest reply 1 year ago by PACMAN
  • Topic is favorited by 71 Pinsiders
There have been 444 images uploaded to this topic. (View topic image gallery).
There are 397 posts in this topic. You are on page 3 of 8.
#101 3 years ago
Quoted from RVH:
I've never met TigerLaw or Pavball but I have got a feeling this is not going to be TigerLaws game.
You are right!! This one is mine and will have its very own room in the house!! I'll allow TigerLaw to play it any time he wants though.
Christopher is also doing TigerLaw's TAF and that one will be his. We are both so very excited!!
#102 3 years ago
Wide head games with hinges to fold the head (Mystic to Embryon) had these striking diagonally shaped “necks”.
#103 3 years ago
Playfield and playfield parts prep today.
Starting with a CPR gold and working from there.
The original Medusa playfield I have here has a much longer and more pronounced shooter lane so I am changing the CPR to be more in tune with that.
I do not know in this case if it is crucial but I do know I am better off to address it now . I am going to take it to the edge of but not into the art so it will be a slight comprise .
#104 3 years ago
Shooter lane further defined and compared to another CPR Medusa pf here in house.
Also have a few inserts cracking out.
Not knocking CPR on any of this stuff I am thankful for the playfields but just detailing how I am going from point A to point B on this project and what some of my personal objectives are.
#105 3 years ago
Playfield is sanded and prepped.
Inserts leveled and the minor spots left behind were minimally touched up.
Clear should do the rest.
#106 3 years ago
I dread dealing with the rollover inserts on this one during assembly but to minimize it I am taking care not to add anymore clear to the already present problem.
The method is to mask them with handles I can pull off while clearing so they are only dusted towards the end of the application.
#107 3 years ago
Looking good.
#108 3 years ago
Apron will take a bit of work but since we can't get the good apron decals anymore I have no choice but to rework the original.
It isn't bad but not perfect either.
I would like to just clear it and work from there but it has some larger bare metal spots so I need to base it a bit before clear.Just doesn’t make sense to clear over bare metal. Same go's for the spinner.
#109 3 years ago
Apron and spinner masked. Not to thoroughly since I have a good match and don't want to risk the art unclear ed to a razor cut.
#110 3 years ago
Apron and both sides of spinner based.
Then unmasked.
#111 3 years ago
Will clear that stuff with the playfield.
#112 3 years ago
How'd you match the color so well, Chris?
#113 3 years ago
Apron spinner and playfield cleared and drying.
#114 3 years ago
Quoted from beelzeboob:
I do it by eye with the various paints and toners I have here.It is the same paint uswd on the cabinet once I settled back into the factory scheme..Honestly this is not a hard color to match compared to many.
When I used to paint cars for a living it was a daily event so just second nature at this point.
#115 3 years ago
Since I am sticking with the original paint scheme I am going to try to eliminate the stainless on there.
First step ia modifying a rail set prior to powdercoat or paint.
Of note I did buy a correct set from Marco but they were paper thin,flimsy and don't line up quite right. They force the back of the rail to the very back edge of the cabinet almost beyond and give a little more gap than desired in the front.
The alignment is a mix of the rails hole being off and my cabinet holes being just a touch further apart by design.The factory hole come close to overlapping.
Anyway this is all in the name of an extra 1/8 inch or so but I really like an even bordering of the rails front and back.
First are the factory cabinet holes.
Then my cabinet holes.Just a touch wider so we don't end up with the blow out in the factory cab.
After that the Marco rail fit which would be fine but not my ideal.
#116 3 years ago
I have a much thicker and more robust set of standard rails from Pinball life.
It is not a fun process but I am going to drill it to better fit and align with my project.
After drilling and working the metal I have it fit and the alignment is more ideal with a more even fit front and back.
#117 3 years ago
Those Unibits like in the first pic of the post above are really handy. I used to use them to tap into drain lines all the time.
#118 3 years ago
Going the powder coat route on trim.I will probably wait to get that back before picking the gold shade for the stencil.
One thing I want to be sure of since I decided on this is that I eliminate all traces of the stainless on the outside.This means everything down to the coin door frame bolts.
There is a lot there to inventory pack and ship.
I do have a local source but really prefer to deal with pinball people because the better understand the application. I find that when I deal outside of the hobby people might make the wrong side look good,bend things up stuff like that.
Pinball guys usually recognize the parts better.
The other thing about having it all powdered is that I can sand paint and clear over that if needed not as easily done over stainless
#119 3 years ago
Also sorting through metal and what needs to be plated,what I will polish manually.
#120 3 years ago
The coil assemblies are being rebuilt.All will be replaced due to condition.
Going with the Pins oil version on these because they carry the wider variety in the matching wrapper.
#121 3 years ago
Playfield is just about ready to sand and polish.
#122 3 years ago
Wow! I can't wait to see that thing in person at Tiger's house.
#123 3 years ago
So, the original cabinet was like rotten/termite victim/other major fault or you are just doing this just because? Usually people dont do complete cabinet swaps without there being something horribly wrong with the original.
#124 3 years ago
Quoted from Luzur:
This is the highest of the high end restore.....everything as good or better than a machine coming off the line brand new. Hence the new cabinet. Chris has posted the used cabs for sale in the past at a reasonable price.
#125 3 years ago
Quoted from Luzur:
Why waste a ton of time cleaning up an original cabinet when a repro is better in every way?
#126 3 years ago
Quoted from Luzur:
Well it was the first game I ever found a dead frog in.
http://christopherhutchins.com/gallery/album681
#127 3 years ago
Quoted from High_End_Pins:
Had the frog turned to stone?
#128 3 years ago
Quoted from RVH:
It was more like dried wood.
You know the funny thing is as things age or deteriorate they always do the opposite of what you want.
The cabinet got soft and flimsy ,the frog got hard and rigid.
#129 3 years ago
Once I get everything back from powder coating this will take back off.
Decided to wait on the final paint for the cabinet so I can hopefully perfectly match the stencil color to the powdered trim,
.If not damn close without guessing.
#130 3 years ago
No, that's about right.
#131 3 years ago
Prepping the cabinet for painting and stenciling.
#132 3 years ago
Parts are back from powdercoat so I can better pick/ match the gold when stenciling.
#134 3 years ago
Main color sprayed again just to insure coverage and consistency.
#135 3 years ago
Head stenciled.
#136 3 years ago
Gorgeous work. Two questions:
1) Did you get the modified/updated stencils from Jeff at Pimball Pimp for the head?
2) What kind of color did you go for? Brand?
The Gold color is ten times better than the one used by Bally, 36 years ago.
Yves
#137 3 years ago
Yeah I am interested in the brand and color of the gold as well. Looks amazing.
#138 3 years ago
Stenciling the lower now. Just a mist coat to start with.
#139 3 years ago
did I miss something? what happened with the stone look? or was it not working out and decided to go more original looking?
#140 3 years ago
Three and a half coats lightly applied.
#141 3 years ago
Unmasked lower. Painted the neck gold as well for now because of future plans. Traditionally they are black and I can easily black it out later if I decide to go a different route.
#142 3 years ago
Quoted from CaptainNeo:
From Post 89: I decided my best bet was to go back to the original general scheme and work from there. It will still be unique but not at the expense of good taste. The reasons that I am heading back to factory scheme are that I could not get a combo on this particular game that works for both the playfield and the backglass.
Beautiful job as always Chris!
#143 3 years ago
Will paint the various things that could not be powdered to match.
Will blast them first f.
#144 3 years ago
Screws blasted as well. These are new and will be used to attach the rails.
#145 3 years ago
The lone plastic part must be properly prepped and primed for plastic painting if you want it to last .
The metal has to be etch primed prior to base application. If this were a larger area or something like a car it would need a bit more than that but for these and the application it is an extra step but not overkill.
#146 3 years ago
Etched and ready to base.
#147 3 years ago
Quoted from jwilson:
Cause there not. Period. How many repro's have you used ?
#148 3 years ago
Quoted from Classic_Stern:
These are .I have used about 80 so far.
#149 3 years ago
Based in gold.
#150 3 years ago
Cabinet and head plus parts cleared.
Full gloss right now. Slightly dulled down next time.
$ 149.95
Allteksystems
$ 21.00
New York City, NEW YORK
Third Coast Pinball
$ 139.00
