(Topic ID: 173984)
HEP Four Million BC restore
By High_End_Pins
  • 332 posts
  • 67 Pinsiders participating
  • Latest reply 3 years ago by High_End_Pins
  • Topic is favorited by 63 Pinsiders
2 key posts have been marked in this topic (Show topic index)
There are 332 posts in this topic. You are on page 7 of 7.
#301 4 years ago
Apron was masked as well as possible and refinished in the cabinet base color.
#302 4 years ago
Apron cleared.
#303 4 years ago
New glass.
Frame and rails were regrained. It was tedious but really the only option.
Other parts of the frame were nickel plated.
The seals were soaked in bleach and washed. They are yellowed from age but should be hidden once in place.
#304 4 years ago
love these threads!
How the heck are you able to mask off so close and change the background color on an apron?
so impressed!
#305 4 years ago
Glass frame built.
#306 4 years ago
Frame in place Once the apron dries this one will be done and the total order filled.
Strange pair. Both games cosmetically reinterpreted but yet still original art.
#307 4 years ago
Quoted from Whysnow:
love these threads!
so impressed!
Thanks. No secrets. This is how I do it.
#308 4 years ago
Out-of-this-world craftsmanship. Just insane what time, skill and dedication can produce.
#309 4 years ago
So tell me the clear flipper buttons light up green, right?
Something I have been thinking of doing to mine.
#310 4 years ago
Quoted from orangestorm87:
No that could easily be done though but I honestly just picked those because they worked well with the scheme.
Same thing with this newer generation shooter rod.
Once placed it just looked right to me.
I kind of like subtle changes too that can be easy tweaked later if desired.
#311 4 years ago
Both games look really good. Thanks for taking the time to make these threads, I really enjoy seeing your process.
#312 4 years ago
love these threads!
so impressed!
I was wondering the same thing. Especially the lettering. But I see now. Nice job.
#313 4 years ago
Quoted from High_End_Pins:
so just frisket and a blade?
#314 4 years ago
I like masking tape because it sticks better and holds up to automotive paints and clears but you can see through frisket and that does seem to work okay with latex or oil based paints.
#315 4 years ago
Look closely at the background of the lettering. Well played.
#316 4 years ago
Yeah. It is amazing work. I can see masking the black and making the color change. But how do you work around all of the pica type sized red lettering? Tell me that's a decal. Yes? No?
#317 4 years ago
Just a tag on EM repair tips.
Certainly not new to high end experienced restorers.
Normally, if restorers have problems with non reproduced panel doors either to lack of availability or changes due to cabinet shrinkage or small age changes which happens frequently even with cabinet rebuilds, I just take the dimensions to a HVAC duct shop. The panel is $40 new.
In this case, I am still working on the cabinet anyway for touchup.
It is closer to original than making one out of plywood which many do out of simplicity, and shops can produce the correct factory metal mil thicknesses and dimensions that are identical to original manufacturers and you do not have to have a rusty piece of garbage that you have to soak in Evapo-Rust.
Replace the lock and hinge.
Be mindful of the dry condition of the wood, as even properly fitting doors can cause cracking, even if correctly dimensioned.
#318 4 years ago
Apron is polished and installed.
#319 4 years ago
Game is finished.
Hopefully I can get as well as the Fire outside for final pictures.
#320 4 years ago
Looks great! Followed thread from beginning to end. You are a master of your craft sir.
#321 4 years ago
Master ..,Master ...!!
#322 4 years ago
This is absolutely stunning, bravo.
But still, I am disturbed by the game's portrayal of the pilocene / zanclean era...
#323 4 years ago
That game is so let down by the plastics... ashame no one has made an alt set.
#324 4 years ago
Finished game
#325 4 years ago
Few more. Since the glass is part of the rail assembly it is hard to get good playfield pics without removing it.
#326 4 years ago
What a beauty. Great work Chris.
#327 4 years ago
I like the homage of the white garage door!
#328 4 years ago
Glass up.
#330 4 years ago
beautiful restoration chris. thanks for taking the time to share the process with the rest of us
#331 4 years ago
Great work as always!
-scott
3 months later
#332 3 years ago
As noted in the Fire post.
HEP gallery is coming back to life
Here is the much delayed and still not fully organized 4MBC album
http://christopherhutchins.com/gallery/album688
