(Topic ID: 173984)
HEP Four Million BC restore
By High_End_Pins
  • 332 posts
  • 67 Pinsiders participating
  • Latest reply 2 years ago by High_End_Pins
  • Topic is favorited by 66 Pinsiders
There have been 363 images uploaded to this topic. (View topic image gallery).
2 key posts have been marked in this topic
Display key post list sorted by: Post date | Keypost summary | User name
Post #33 Tip where Chris opens up the leg bolt holes and bevels Posted by High_End_Pins (3 years ago)
Post #43 Description of a 'Guide Coat' used in prep'ing surfaces Posted by RobertWinter (3 years ago)
Topic indices are generated from key posts and maintained by Pinside Editors. For more information, or to become an editor yourself read this post!
There are 332 posts in this topic. You are on page 1 of 7.
22
#1 3 years ago
Starting out just gutting the game for the parts I need to get in order first and foremost.
That will be the cabinet and playfield.
I wont say too much about conditions at this point because it will be better to focus on that when I am restoring the actual part itself.
#2 3 years ago
Gutting and removing head.Will save all tags by carefully removing them.
#3 3 years ago
I wish I could talk to the artist that thought "hey, lets make the plastics look like burlap. Nothing says dinosaurs and cavemen like burlap."
#4 3 years ago
Head gutted and removed.
I will strip this first then move to the next thing.
The idea is to keep pace a bit as I go so it doesn't overwhelm me as a syand alone project since I have others also brewing.
#5 3 years ago
Oh boy, that's going to be some fun work right there.
#6 3 years ago
Cautiously stripping the head since there may be lead paint involved.
#7 3 years ago
Head stripped.
#8 3 years ago
I will skim coat all surfaces of the head focusing on one side at a time.
#9 3 years ago
Lightly level surface
Now guide coat.
Now block.
#10 3 years ago
Ready for the next side. Same,process.
#11 3 years ago
What does "cautiously" removing the head paint mean? Are there extra precautions you use to keep possible lead dust down? (Or dies festool virtually eliminate all dust?)
#12 3 years ago
Quoted from Mbecker:
Long sleeves,long pants rubber gloves,dust mask and yes the Festool definitely helps.
#13 3 years ago
Quoted from Eric_S:
Dinosaurs with Cavemen?...back in 4 MBC?? Burlap fits in that theme well Really cool game.
#14 3 years ago
Repairs complete ready to prime head.
#15 3 years ago
Head primed.
#16 3 years ago
Ready to gut the lower today.
#17 3 years ago
Will pull the playfield as an assembly so plastics are removed along with the apron.
#18 3 years ago
Playfield out.
#19 3 years ago
Pulled as assembly.
Has some issues to sort out.
#20 3 years ago
Lower gutted.
Missing some wood all the way around the bottom lip.Rear is the worst.
Floor itself is straight and solid.
#21 3 years ago
What kind of bondo/filler do you use for cabinet repair?
#22 3 years ago
I went over to my warehouse and gutted another game I had for the lower.
This was a german version and while it adds to the workload a bit it is really more practical and will provide a better platform for this level of restoration.
#23 3 years ago
Ready to strip and repair.
#24 3 years ago
Stripped lower ready to repair.
#25 3 years ago
Small pilot holes are made to better bond the deeper fill areas.
#26 3 years ago
Skim coating and dealing with the worst areas first. This lower is overall solid front to back it is only the rear that is chipped badly at the legs and very grainy.
I use a higher grade of filler that is made for anything up to carbon fiber because it is very hard and strong and since it will bond well to carbon fiber wood is no problem.
There is not a lot of effort or ability to get the skim coat down neatly because it is a large area and you have to move fast before the filler starts to kick off.
The sanding procedure will but the most important part of getting it straight.
#27 3 years ago
First coat knocked down.
Will need another lighter round.
#28 3 years ago
With the wood grain so open and the wood seemingly nice and dry, these pilot holes look awfully small to me to make a difference.
#29 3 years ago
Second coat applied .
Much easier to get a smoother application this pass. .
#30 3 years ago
Second coat lightly sanded now guide coated and ready to block.
#31 3 years ago
Your speed of execution defies comprehension. And you're simultaneously documenting the whole process with excellent pictures and useful tips. I'd still be working on taking the head apart.
#32 3 years ago
Back is blocked .
Grain free and straight.
Will open the holes back up next.
#33 3 years ago
Holes are opened back up.
I like to just wrap a little sand paper around a dowel and do a slight bevel until I see wood again.
That way I know leg bolts will not easily chip it out at anytime in the future.
It is still basically just roughed in at this point and will finesse more as I go.
#34 3 years ago
What is the material you're using to "skim coat"...Bondo or something else?
#35 3 years ago
Same process front.
#36 3 years ago
Quoted from ForceFlow:
I like Half Time.To really skim adding a little lacquer thinner to the mix will make it soupier.
#37 3 years ago
Thanks for documenting all of the restoration - great stuff! Is the Half Time the same product used for the major wood repair or is there another filler product being used as well? Just trying to learn something ...
#38 3 years ago
Front done.
#39 3 years ago
Outside bottom sanded clean.
I will run a bead of glue all the way around the ply just to catch any loosening spots and shore up the rest.
#40 3 years ago
Bead run.
Smoothed in with a mini roller and clamped where needed.
Will let that set overnight then do the final sand and prep prior to priming.
#41 3 years ago
Quoted from lb1:
He seems very enthused.
#42 3 years ago
Quoted from High_End_Pins:
What do you mean by guide coated?
#43 3 years ago
Quoted from Mitch:
From what I recall from my auto body repair days in college, it's a light misting of paint, usually black, over the primer. Once you sand the guide coat off it reveals any imperfections.
"GUIDE COAT is designed to give the auto body refinish technician a visual guide to a smooth surface when sanding most primer surfaces and body fillers. It helps detect low spots, sand scratches or other minor imperfections in the repair."
#44 3 years ago
OMG, I can't wait to see what you do with this pin!
#45 3 years ago
Look at that F Ing mess of wiring.
Amazing to see the evolution of pinball.
#46 3 years ago
Quoted from RobertWinter:
Great description.
#47 3 years ago
How will you match colors? If you scan what you have right now you will scan patina. Or do you have manufacturer color chips? Or are there official color codes?
-14
#48 3 years ago
Seems a bit much for this machine....
-6
#49 3 years ago
Quoted from Jjsmooth:
I really do wonder why this game is special enough to someone to spend this kind of money on it. It looks pretty blah.
36
#50 3 years ago
I think you're missing the point of the excercise. +some of us are tired of seeing only TZs, MMs, AFMs etc get restored. Watch the man do his work and learn a thing or two.
Portland, OR
San Ramon, CA
$ 22.50
$ 180.00
Tools
PinDoc Restorations
$ 12.00
$ 54.99
$ 189.00
Displays
Boston Pinball Company
$ 139.00
Sparky Pinball
€ 9.95
Multigame
$ 27.00
$ 4.49
Creo Pinball
$ 79.95
$ 78.00
Apparel - Unisex
Project Pinball Charity
$ 3.00
$ 5.00
