New! Dark mode!
(Topic ID: 99379)
HELP.......Flipper stuck up ....
By Monarca1091
6 years ago
  • 32 posts
  • 15 Pinsiders participating
  • Latest reply 1 year ago by PinballManiac40
#1 6 years ago
Hi I need some help from my fellow pinsiders .....I just got an attack from mars and after playing it a few games the left flipper stays up .....I changed the coil and sleeve but as soon as I turn the pinball on the flipper goes right up again ...anybody got this problem before and how did they solved it ?
#2 6 years ago
Have you checked EOS switch?
#3 6 years ago
Sounds like a bad transistor. Check Q87 on the power driver board with your DMM.
#4 6 years ago
Do you have to start a game or just turn the machine on?
If sticking in the up position as soon as game turns on I too would check shorted transistor.
If it has to actually start a game. Probably focus on the flipper components and stay out of back box.
Take a picture of the flipper coil and surrounding area and maybe we can spot a simple mistake or something bad that is not obvious. Pics are worth a 1000 words.
#5 6 years ago
Quoted from GoodToBeDad:
I agree.
Definitely sounds like a transistor.
Time to grab a flashlight and start looking for a crispy transistor on your board.
I had the same thing happen to me with one of the slings.
Simple/cheap repair if you're good with a soldering iron.
#6 6 years ago
Man my tz went bad today ...I fucken hate Williams/bally games ........I should have continued getting more sterns ...
And I know sterns break also , but the last longer with out breaking .....
#7 6 years ago
If you have a stuck up flipper, just smack it around a bit and give it an attitude adjustment.
#8 6 years ago
Quoted from Monarca1091:
What broke on the TZ?
#9 6 years ago
It says check fuse f114 and f115.....
#10 6 years ago
If it's been like that for 4 hours or more, see your doctor
#11 6 years ago
Many threads here and good info on the " check f114 and f115 fuses" on pinwiki. http://pinwiki.com/wiki/index.php?title=Williams_WPC#Check_fuses_F114_and_F115_message
#12 6 years ago
Check the C2 capacitor next to the Q2 voltage regulator on your driver board. Those get hot and when they go bad, they will pull down your 12v and cause that error message.
#13 6 years ago
Common problem that most Bally/Williams owners will have to deal with at some point.
Read through the link above as it has steps to diagnose the problem.
Most of the time it boils down to a bad Bridge Rectifier or the C2 capacitor.
Sometimes even though that little capacitor looks good, it has leaked out of the bottom and messed up a trace on the board.
Good luck.
And the flipper sticking up is most likely the driving transistor as stated above.
#14 6 years ago
Quoted from Jeekayjay:
Go see the doctor ? Pssst .....I'm going to lock myself with my wife........
#15 6 years ago
Ok guys I fixed the tz ,thanks for all the help ........now getting back on track about the afm ......here are some pictures .....
#16 6 years ago
Quoted from ozuba:
I checked the eos switch and its good .....
#17 6 years ago
Quoted from Shoot_Again:
As soon as I turn the machine on the flipper goes up ...I will post some of the flipper coil and surrounding area tomorrow ....thanks guys for all the help ...
#18 6 years ago
I didnt have a dmm , I went to buy one today and I will check that tomorrow .....and if it is where can I buy a transistor and what are the specific transistors I need ? Once again thank you for your help ...
#19 6 years ago
That flipper uses two transistors: a TIP36C (Q87) for the initial flip and a TIP102 for holding it up. I suspect it is the TIP36C that went bad. Pinball life and Marco Specialties both have them. Any good, local electronics supply store should also carry them.
#20 6 years ago
If you turn on the game and it immediately goes up 9/10 it's the transistor . The best way to tell if it electrical or physical is when it happens shit off the game . If it drops then it's electrical if it stays up it's physical . I bet you anything the transistor is the culprit
#21 6 years ago
Get them at the online sites above.
If you walk into an eletronics shop and ask for a TIP 102 they will look at you like you are crazy.
Their order books do not use that as the order number and you will need to get a different number off the transistor.
#22 6 years ago
So help us all by telling us what you did to fix the TZ F114/F115 fuse issue.
Chris Hibler - CARGPB #31
http://www.Team-EM.com
#23 6 years ago
Quoted from ChrisHibler:
It was a blown fuse..... Behind a tag that was hanging blocking that fuse .....such a easy fix .....
#25 6 years ago
Did you solve the flipper problem?
#26 6 years ago
I had the same issue, turned out flipper opto board was loose and didn't close (or was it open), worth checking that too in the switch test
5 years later
#27 1 year ago
Hello. Sorry to revive such an old thread, but I think it makes sense to have all the flipper stuck tech together...
Please help me. I was putting side blades on my Twilight Zone and when I fired it back up to start a game, the upper left (piano shot) flipper stays energized. I think it is different from the OP, because you have to start a game to get it to stay up, not just power on. Also in coil test all flipper functions work, but the hold test of the upper left does nothing.
By reading this thread I'm taking it is less likely a transistor issue, and more mechanical? I lean that way since I had the playfield gyrating to get the inner artwork on and I may have bumped something. Please see the photo below, but everything seems good to me.
I've got a guys weekend at my house next week and hope to resolve it stat.
Thanks,
Chris
#28 1 year ago
as above, when you turn off the machine, does the flipper immediately drop or stay stuck. If it stays stuck, it is mechanical and you will have look at the assembly and see why it is sticking.
#29 1 year ago
no, when turning the machine off it drops.
#30 1 year ago
Quoted from Homebru:
I actually prefer different threads for different games because not all titles/manufactures will have a same end result. Also, a different thread on a specific problem/game will allow others to search for problems easier.
Since you were installing your side blades, lift the playfield back up and check the wiring to the flipper button opto board to be sure it is seated and that the opto interrupter is not bent outward from the board as that would signal the game to fire the flipper.
#31 1 year ago
^^^^winner!
Thanks so much. Just futzing with the left flipper button/board/blade seems to have fixed it.
#32 1 year ago
^^^^winner!
The interrupter blade must have been jammed up. Happy flippin'
