(Topic ID: 339687)
HELP: Bank a Ball Gottlieb No Power
By deafdumbkid
1 year ago
  • 13 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by Flipsteen
    #1 1 year ago
    Had this thing in storage 12 years, used to power on and play but CANNOT get to power on when I hit start button
    We have been through EVERYTHING with multimeter, continuity everywhere, yes slam switches, power switch, start button, we scrubbed down the Jones connectors real good, but still NO dang power, all 5 balls in
    ANY ideas?
    ANY help most appreciated and thank you
    Lee in NC
    Owner, Godzilla Premium, Black Hole, Firepower, Flight 2000, Meteor, 2001, Bank a Ball, Strikes & Spares
    #2 1 year ago
    Does it fire up if you manually trip the SS/Start relay in the trip relay bank in the bottom of the cabinet? If so, almost any of the switches shown here could be at fault.
    Beware that the entire circuit runs at 120 volts AC so unplug the game before poking around the circuit.
    /Mark
    #3 1 year ago
    Quoted from MarkG:
    /Mark
    sadly it doesnt, we tried! Thank you though
    #4 1 year ago
    If you manually trip the SS relay, do you get 120 VAC between the red and white wires at the transformer?
    #5 1 year ago
    Quoted from MarkG:
    we do indeed, but will look again, thank you
    #6 1 year ago
    If you're getting 120VAC in, you should be getting 24VAC out and the R/120V Hold relay should fire. If not the 10A fuse on the 24V transformer output might be bad.
    #7 1 year ago
    Quoted from MarkG:
    Thanks mark will check it, but fuse showed continuity
    #8 1 year ago
    Hold in the power button while manually turning the score motor
    #9 1 year ago
    Quoted from Budman:
    will try thank you
    #10 1 year ago
    Quoted from deafdumbkid:
    At the risk of overstating the obvious, that doesn't mean anything unless you removed the fuse from the holder to measure it.
    #11 1 year ago
    Quoted from MarkG:
    granted I am not a genius with a multimeter, i will check tonight ty
    #12 1 year ago
    will try thank you
    Quoted from Budman:
    tried but no success thank you, going to glat replace fuses tomorrow even though they show continuity
    #13 1 year ago
    With power off, I would locate all the bounce and slam switches at bottom of cabinet, under playfield, on coin door and double check they are all closed and making good contact not only by eye but with a meter. Has been the culprit for me more than once when machine doesn't power up.
