I have a JM and all the gi on the same strand is not working. When testing for power at j115 it has 6.3v, but at j121 I have no voltage. Fuse is good.
From my understanding power comes in at j115 and goes through a pre driver and a couple resistors then into the "triac" which looks like a transistor attached to the large heat sink, from there power goes out to the connector
At j121.
The predriver tests the same as the others .8 so I assume it's good. I am unsure of how to test the triac. It is labeled as bt138 500e.
Is it possible to test it, and is it the same part as this one for sale at marcos.
http://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=bt138
Is there anything else that would affect this gi strand. Fyi it is the brown and white/brown strand.
