(Topic ID: 296968)
Help with Tales from the Crypt!
By Pinball-DOOD
2 years ago
    There are 69 posts in this topic. You are on page 1 of 2.
    #1 2 years ago
    Hey all!
    I just recently acquired a Tales from the Crypt and I am currently having an issue where when I hit the flipper buttons, the back right VUK under the playfield fires. The flippers are super sluggish and that VUK coil is, too. The outlet plug seems to be slightly damaged and the same VUK coil was damaged. The game was working fine until I started LEDing. The auto launch coil is inoperative, also. Any ideas? Thanks!
    #2 2 years ago
    03598D62-344E-4DEB-97F9-4C8EBAF82968 (resized).jpeg03598D62-344E-4DEB-97F9-4C8EBAF82968 (resized).jpeg666C2D04-1C4E-4203-9BF8-B79F6E4F76E9 (resized).jpeg666C2D04-1C4E-4203-9BF8-B79F6E4F76E9 (resized).jpeg
    #3 2 years ago
    Disconnected the VUK coil and the flippers are still sluggish. The coil launch is not working
    #4 2 years ago
    I'd get an outlet checker and plug it into the service outlet. See if hot, common, and ground are all working right.
    That would let you know from wall to service outlet is good.
    #5 2 years ago
    Quoted from LTG:
    Thanks! But I am leaning towards a bad driver. The game Boots okay! It just some coils are not working and the flippers are weak. Could it be outlet-based?!
    #6 2 years ago
    I have never owned a Data East so this is new to me!
    #7 2 years ago
    Auto launch and kickback coil is out!
    #8 2 years ago
    For non working coils, you need to check fuses, test for voltage at coils. For weak coils, check the Coil Pulse Power setting in standard settings. Should be at least normal, not the lowest setting. Try hard and see if it makes any difference.
    If flippers are making the VUK fire, the switch likely needs adjustment. Put the game into switch edges test and pound on the playfield with your fist to see if any switches trigger. VUK rebuild kits are available from the usual sources.
    #9 2 years ago
    Quoted from phishrace:
    Thanks, I will do this and get back to you.
    #10 2 years ago
    If you added any LED light strips disconnect them. I've had a few Data East games have coil problems because of LED light strips. Disconnected them and the coil issues went away. Not saying this is the issue you're having but it's worth a shot.
    #11 2 years ago
    Quoted from 1iblind:
    Hmm, interesting. I didn’t install any so I’m not sure
    #12 2 years ago
    I am confused to why there is little power to the flippers and multiple coils are dead and low power. Could it be the LEDs? I see people LED Tales all the time!
    #13 2 years ago
    Bad fuse on f5! Man, I feel dumb. Thanks, guys! It works perfect now
    #14 2 years ago
    Okay, now I am getting closer! F5 fuse keeps blowing upon boot up. Anyone have the schematics handy and could tell me which larger driver (PPB) it could be? Thanks!
    #15 2 years ago
    I can’t see which coil is holding because the fuse blows immediately. I disconnected that broken VUK coil and I am still getting the issue. Anyone know what fuses run off of F5? Thanks! I need to find the bad coil, replace it, and the drivers/pre drivers but I am just not sure which ones go to F5
    #16 2 years ago
    Quoted from Pinball-DOOD:
    Check the big transistor on your board, it is likely bad.
    #17 2 years ago
    Quoted from LTG:
    Sounds good! How would I check one of those? Black lead on ground and red on Transistor? Thanks!
    #18 2 years ago
    I have been putting a 1 amp fuse in place of the 5 amp fuse, is this a problem? I am not over-amping it but maybe this is why it keeps blowing?
    #19 2 years ago
    Check manual - if it's supposed to be 5 amps, yes 1 amp would blow fast.
    Youtube has lots of short videos to help you.
    #20 2 years ago
    Quoted from LTG:
    Okay, thanks! I will meter the big drivers!
    #21 2 years ago
    None of the drivers are bad. Maybe a bad bridge rectifier? BR1?
    #22 2 years ago
    It’s not BR1. Hmmm.
    #23 2 years ago
    When I put a 5 amp in it, it started working! So I will let you all know. Nothing is holding
    #24 2 years ago
    5 amp blew again! Any ideas?
    #25 2 years ago
    So found out that disabling the auto-plunge coil stops the fuse from blowing. Should I replace this coil?
    #26 2 years ago
    The auto plunge reads 11 in diode test!
    #27 2 years ago
    Is your auto-plunge coil shorting out? Check and make sure that metal from the auto-plunge coil is not touching anything else that is metal near it. I had a similar problem with my TZ auto-plunge coil which was touching nearby metal and once I adjusted the coil bracket so that it was not touching any nearby metal the problem was resolved.
    Gord
    #28 2 years ago
    Quoted from GRB1959:
    Gord
    Thanks! So the back VUK coil is a mess. The plastic where the lugs are are all broken and rigged and I think that is what is blowing the fuse. I just ordered the new coil and fuses. I’ll let you all know. Thanks!
    #29 2 years ago
    Disassembling the VUK to replace the coil without damaging any parts is very difficult. As I mentioned about, VUK rebuild kits are available from multiple sources. With the kit, disassembly is much faster. Just cut the cup off that holds the ball with wire cutters and it all comes apart. Your pic above appears to show the original parts. I would not recommend trying to disassemble and reassemble those old parts.
    #30 2 years ago
    Are there any diodes on your coil. Maybe one is blown or loose. Also check that the plunger moves in and out of the coil freely. Any restrictions could blow a fuse.
    #31 2 years ago
    Quoted from Da-Shaker:
    It moves freely! But because the plastic part of the coil is broken, the diode is loose. So I think we are on to something!
    #32 2 years ago
    Make sure the diode doesn’t have a broken leg and that both ends are attached. If it’s just wobbly from the broken plastic it’ll still work, but if one leg isn’t attached it’ll pop your fuse.
    #33 2 years ago
    Very true! I just a bought a whole new coil just to be safe. It should be here this week.
    #34 2 years ago
    A lot of times a new coil doesn’t come with a diode and you have to purchase separately. It would be best to just order a diode and not the coil, because the coil is probably fine. You can also just test the diode that is currently on it.
    #35 2 years ago
    I ordered the coil and diode separately and they just came in
    #36 2 years ago
    Installed the coil and everything was working and then when the ball was in the VUK, the coil started smoking. Any ideas?
    #37 2 years ago
    #38 2 years ago
    Transistor failed. New coil and diode wired right ?
    #39 2 years ago
    Quoted from LTG:
    Hmm. Yes! I put it the same way is it was installed before
    #40 2 years ago
    Could anyone confirm that it is supposed to be a 23-800 coil?
    #41 2 years ago
    Diode is on right. Couldn't tell from your picture if wires were in correct spots.
    That wouldn't cause the coil to fry. It likely is, or close enough.
    #42 2 years ago
    Had the wires arranged like this! Even with the new coil
    533876A5-6524-459C-95E8-1B8025E538C9 (resized).jpeg533876A5-6524-459C-95E8-1B8025E538C9 (resized).jpeg
    #43 2 years ago
    The fuses blew, also!
    #44 2 years ago
    This is the coil I bought. Did I get a wrong one?!
    #45 2 years ago
    Here's a pdf of the manual, it will help a lot with part #s
    https://www.ipdb.org/files/2493/Data_East_1993_Tales_from_the_Crypt_Manual.pdf
    #46 2 years ago
    I think I was right!
    #47 2 years ago
    I put the old coil back in and now it holds upon boot up. None of the drivers in the back test bad except for I get a beep on the VR1 driver on the power supply board. Is this supposed to be opened? For is this shorted?
    #48 2 years ago
    frunch Hope you don’t mind jumping in!
    #49 2 years ago
    Would this suffice for TIP36? Thanks!
    A5AED355-A43A-49FD-A344-C233E0851E3A (resized).pngA5AED355-A43A-49FD-A344-C233E0851E3A (resized).png
    #50 2 years ago
    Pinball-DOOD reached out to me for a bit of assistance with this, figured I'd post up here what I suggested. If I have anything wrong here, please correct me:
    I think the manual calls it the "Top VUK". Based on that, here would be the transistors to check:
    PPB board: Q2 TIP36
    CPU board: Q40 TIP 122 or TIP102 (both are suitable replacements)
    Also on CPU board: Q32 2N4401
    It's recommended in cases like this to replace all 3 of the transistors in the circuit (1 on PPB and 2 on CPU) even if they don't all test bad. Make sure to orient all the parts correctly on the board when replacing them! Make sure to wire up coil correctly too.
    The TIP36C you posted from jameco should be correct. Get at least an extra or 2 as backups...
    This page was printed from https://pinside.com/pinball/forum/topic/help-with-tales-from-the-crypt and we tried optimising it for printing. Some page elements may have been deliberately hidden.
