(Topic ID: 236667)
Help with stripped screw hole in playfield...
By MoSeS_1592
5 years ago
    #1 5 years ago
    I have a Bally Special Force and a Williams Black Knight, on each machine a few of the screw posts that screw directly into the playfield have stripped screw holes and therefore cannot be tightened. What is the proper way to repair this? I attached a picture of the type of screw post I'm referring to.
    #2 5 years ago
    I break off a wooden match into the whole then screw the screw in.
    #3 5 years ago
    Stick a short piece of toothpick or wooden skewer and some Elmer's glue in the hole, then screw in the post
    #4 5 years ago
    Or if the backside is clear you can get a post that goes through the playfield and has a nut on the back.
    If you plug the hole with wood be sure to glue it in. Screws like that are a common occurrence at my work and if they are not glued in they will not hold long.
    #5 5 years ago
    Piece of wood of your choice + glue of your choice + break/cut off + screw in
    #6 5 years ago
    What they said ^.
    #7 5 years ago
    Thanks for the advice!
    #8 5 years ago
    Tooth picks... glue... and what they said...
    #9 5 years ago
    I recently had a pop bumper mounting hole stripped on my Monte Carlo EM. I considered Travish 's recommendation but the nut would have interfered with the pop's center mechanism. I wood-filled the hole, drilled a new pilot hole, and was good to go.
    Quoted from Travish:
    -Rob
    -visit http://www.kahr.us to get my daughterboard that helps fix WPC pinball resets or my Williams system 3-7 sound board potentiometer solutions
    #10 5 years ago
    Quoted from rkahr:
    I recently had a pop bumper mounting hole stripped on my Monte Carlo EM. I considered travish 's recommendation but the nut would have interfered with the pop's center mechanism. I wood-filled the hole, drilled a new pilot hole, and was good to go.
    -Rob
    Great suggestion - also make sure to use a heavy duty epoxy (like the wood stick stuff) for the filler if it’s a post that gets a lot of hits from the ball.
    #11 5 years ago
    Chop stick works great also.
    #12 5 years ago
    Quoted from Cash_Riprock:
    That's what we use at work. Lady always looks at me funny everytime I go and get 4 or 5 sets of chopsticks then eat with a fork.
    #13 5 years ago
    I found that leaving the glue set-up overnight worked best.
    This page was printed from https://pinside.com/pinball/forum/topic/help-with-stripped-screw-hole-in-playfield and we tried optimising it for printing. Some page elements may have been deliberately hidden.
