(Topic ID: 24644)
Help with Sorcerer connector identification
By PittPin
11 years ago
#1 11 years ago
I have a badly burnt connector at 3P3/3J3 to the power board on my Sorcerer. The one lead had been cut and then soldered directly to the board. I want to replace both connectors. I need some help identifying what connectors to purchase and where to get them. What's the trick to removing the pins from the existing connector (or do I just snip the wires at the connector)? Will I need a couple pins and a crimping tool also? I took one picture of the power board and attached it to this post. Thanks.
#2 11 years ago
Just cut them off of the existing connector.
You will need a crimper.
You will need pins to go inside the housing.
You can buy everything you need here:
http://greatplainselectronics.com/Category-94.asp
#3 11 years ago
The header on the board looks a little krispy, too.
I think you're on the right track, though, replace both halves of the connector and the pins.
The PCB header is 15-31-1026
The male connector on the wiring is 19-09-1026
The pins are 02-09-1104
All can be purchased from Great Plains Electronics at http://www.greatplainselectronics.com
All the parts will run about 2 bucks
#4 11 years ago
I had never done this until two weeks ago, you can totally do it, not as hard as you think.
In addition to what Johnwartjr (who was a huge help with my last repair) said to get you will also need a soldering tool, and desoldering tool.
#5 11 years ago
I ordered the parts and a crimp tool. Is $25+ the going rate for a crimp tool for these types of connectors? I already have the soldering equipment. Thanks for helping me figure out which connectors to buy.
#6 11 years ago
Quoted from PittPin:
sounds about right. I got the cheap one from great plains, worked fine.
$ 22.50
$ 27.95
Watertown, MA
$ 749.00
$ 36.95
This page was printed from https://pinside.com/pinball/forum/topic/help-with-sorcerer-connector-identification and we tried optimising it for printing. Some page elements may have been deliberately hidden.
