New to here so Hi to everyone..
I am currently restoring a SF2 pinball and have managed so far to get a few parts working that were not, but I am struggling with the Bottom Right Upkicker (Sol.4).
I have been using the very helpful repair guide by the legend that is Marvin3m (thank you), but I am completely stumped with getting this coil to fire when the ball lands in it.
I have done the following and everything checks out:
1 - Coil gets voltage at both side of the lugs
2 - Coil gives ohms reading
3 - Momentarily ground non-banded coil lug and coil fires
4 - Replaced the MosFET for this coil (just in case) was giving a dodgy reading
5 - Momentarily touch Ground to the relevant MosFET (Q5) and Coil fires
6 - Checked switch that connects to coil so machine knows ball is there - Working
Everything looks like it is getting the correct power etc but when the game is playing and the ball drops in to the hole you hear the game acknowledge it knows the ball is there but does not fire it out.
The left side works fine and is on the same fuse so completely lost?? Can anyone help??
Please note that I am fairly new to this and have limited knowledge of electronics but have had some experience with these machines and so far not electrocuted myself...
