So I used the freezespray method to remove the mylar. Lifted no art so was pleased there however the glue is damn near impossible to clean up. I have tried the flour method. Covered an area with flour, sprayed with 91% rubbing alcohol, let sit a few minutes, added more flower and started to rub. I am making a gray paste that may be taking the glue up but I have to rub an area the size of a quarter for 3 minutes. I have to be doing something wrong here. Does anyone have a good video on this? Or a different method?
Also the pf had the typical SBM wear BEFORE the mylar was put down so I have a few spots wore to the wood in the center. Pulled the mylar as they put it on dirty and there was dirt trapped between it and the field and it was bubbling horribly.
