i wanted to see if anyone can give me some advice on a new problem. I have a williams Indiana Jones. Today, with the pin powered off, i removed a #47 bulb and plugged a small LED strip in that socket. When i restarted the machine, none of the optical switches are working on the pin. I get no response from any in the switch tests. I examined several of the visible optical switches (those that i did not have to remove any parts to get to) and did not notice any wires that had come unsoldered or such. Does anyone have any thoughts on this? Thank you!!
