I recently picked up a project Stern Big Game. The original bridge rectifier was toast, and I just got finished dropping in a replacement from Great Plains electronics (for reference, it is this one: https://www.greatplainselectronics.com/proddetail.asp?prod=135-105).
After wiring it up, repinning connectors, etc., I checked the voltages at each of the test points. Below are what the points *should* read, followed by what they actually read:
1. TP1 - 6.4; 1.6
2. TP2 - 195; 250
3. TP3 - 12; 12.83
4. TP4 - 7.3; 6.1
5. TP5 - 43; 45.9
TP1 and TP2 are well outside the normal range, TP4 is slightly lower than the acceptable range. I double checked all the wires and made sure there were good connections. The game boots fine, and I can start a game. However, none of the solenoids fire and the GI on the playfield appears rather dim. Other symptoms include super garbled sound, however I don't know if that is related.
Any help or advice on what to check would be most appreciated. Thanks!!!
