Two of these issues maybe burnt bulbs. If you take a jumper wire with one end connected to the ground braid and use the other end to briefly touch the metal tab of the TIP circuit that you want to test. The coil or lamps on the circuit will activate every time you touch the tab. Only do this on tip122 and tip102. So since solenoid #9 did nothing you can split the circuit in half by touching the metal tab of Q-17, there is one flasher bulb on the p/f that should light. If it doesn't light then replace the bulb and retest. If a new bulb doesn't light then there is a wiring issue and not a board issue. Try this same test for solenoid 15. Bear in mind that this circuit has 3 bulbs and are 24 volt bulbs #1251. if they are burnt out you can get these from the auto parts store.
