Recently picked up a Mousin and had to fix some things, but one last thing still plagues me. You shoot the 1-2-3 targets in the middle, they drop, hit the loop ramp a few times to light Kickback. After enough loop ramps the 1-2-3 targets rise up again. If you trigger kickback before you hit the loop ramp enough times to raise the 1-2-3 targets, the game works fine. However, if you light kickback AND raise the 1-2-3 targets, hitting the lower pop bumper will trigger kickback, essentially wasting it as the ball is in the pops.
All the pops seem to be wired correctly at quick glance, and again this only happens when kickback is lit AND the 1-2-3 targets are raised... if the 1-2-3 are down, this doesn't happen. Anyone have any ideas as to what's going on here? Thanks!
