I have a board from ebay bought several years ago. Minimal corrosion but is locked on. Tried all the pinwiki troubleshooting. Voltage at pin 40 U9 is 5.4, seems a little high, could this be my issue? Test point 1 shows a hair over 5V. With only U6,9 and 11 in the board, I verified clock signal is coming through and the LED is cycling. Replaced U9 with a brand new one. Also replaced U15 with a MC3459P. Double checked jumpers which are set for 2532. It appears that U16 was changed before me, someone installed a E320-35 which is a Baly part number that does match the parts list for U16. U6 is also new. Any suggestions are appreciated.
