Hey all. Any thoughts/advice appreciate with this issue!
I recently bought a 1981 Flash Gordon. Super happy. When I received it everything worked for the most part (I haven't gone through testing every inch yet). Yesterday, I needed to move the game into my basement. In order to do so, I had to chop the head off, bring it downstairs, and then wheel the cab down separately. Thankfully, I was able to move everything without causing any physical damage. I reassembled it today (I made sure to properly mark everything I disconnected, and took pictures before to compare to after) As far as I can tell, I put everything back together exactly as it was when I disassembled. Game boots fine, plays exactly as it did pre-disassembly, BUT two sets of lights don't work. 1) The "Flash Gordon" lights on the head (all the other board lights light properly) 2) none of the main playfield lights (like where the dial numbers are, or the top playfield lights. However, all of the side and ally lights seem to work (see pictures below). So I don't get it. I checked the fuses, none seem popped and are all seated. I triple checked that I put everything together correctly, so I can't figure it out. Please, and advice, suggestions, etc. is greatly appreciated. Thanks everyone!
