I need to fix one of the wires running to the coil that kicks the ball up into the shooter lane.
The wire installed at the factor is too short and keeps breaking off from the coil. I want to add an extension, what kind of wire should I use?
Quoted from Trekkie1978:I need to fix one of the wires running to the coil that kicks the ball up into the shooter lane.
18ga stranded should probably be fine. In general just get stranded (it handles vibration better) of a similar thickness
Quoted from zacaj:18ga stranded should probably be fine. In general just get stranded (it handles vibration better) of a similar thickness
Thank you!!!
Where do I buy it?
Quoted from Trekkie1978:Thank you!!!
Where do I buy it?
I usually buy bundles off ebay but you can probably find some in a home depot/etc. If you've got a local electronics store they'll have some
This page was printed from https://pinside.com/pinball/forum/topic/help-with-jurassic-park and we tried optimising it for printing. Some page elements may have been deliberately hidden.
