I would take one wire loop, solder the ends together and to a single wire, then stick the single wire in the Molex connector. Repeat four times.
With daisy chain situations, I cut the wire, strip both ends, intertwine them a bit, and unite them with a drop of solder on the tip of the iron. Once cooled, I place them in the .156 trifurcon pin and squeeze away with my crimper. On a couple of occasions I have added another drop of solder to further unite the two wires with the pin. Be careful to use a minimal amount of solder so that the pin/wire combo doesn't become too thick to fit easily in the Molex housing. HTH.
-Steve
Thanks to you both. I think I'll try to keep only one wire in the molex. I can do that easily enough with a little solder and cutting.
Maybe vid could do a how to thread for this.? I would love to see this explained step by step with pics.
Angus, Clay has put together a lot of good info on connectors at:
http://www.pinrepair.com/connect/
Wally
I prefer to double crimp as that is much quicker. I have crimp pins that are larger to fit two wires crimped at once. With the larger pins you can still make a good quality crimp.
This page was printed from https://pinside.com/pinball/forum/topic/help-with-idc-to-molex-method and we tried optimising it for printing. Some page elements may have been deliberately hidden.
