Hello all,
I have a 73 Hee Haw that i cant quite figure out. I got this game as a basket case and after many hours of work I have everything working except the 25c coin relay will not trigger the coin reel. That is unless you manually hold the relay longer than normal. When adding a coin the reset wheel cycles and the relay trips but the counter reel wont register. I added a video on my YouTube channel so you can see the issue.
I have checked and tested everything I can think of and had no luck. Please HELP!
