(Topic ID: 162622)
Help with Gottlieb Score Motor Switch part# (flipper clown)
By PinFixin
8 years ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 8 years ago by MikeO
#1 8 years ago
Hey folks,
I was still posting every once in a while on RGP and didn't know most have moved here.
I'm working on a Flipper Clown, and my score motor switch 1a that deals with resetting the score reels (most inside switch) has burned up. I have the 1968 parts catalog, and I'm having a hard time deciphering what part # I need.
Score motor 1a has 3 switches. The most inside switch is a make set of points, with large contacts. The 2nd switch is another make set of points with large contacts, and the 3rd switch is a break set of points with small contacts. I'm assuming part #B-8265 is the correct assembly for this, but wasn't exactly sure. The way the parts catalog calls this part number is: A(with circle above it denoting large contact)A(circle above it)B (no circle denoting small contact). A should be make, and B should be break, is this correct?
-Pat
parts_catalog_motor_switch_1a_(resized).jpgparts_catalog_motor_switch_1a_(resized).jpg
#2 8 years ago
dont have that pin, but can say Gottlieb's a language in itself...
If you call Steve at PBR, he can hook you up with blades, and contacts.
#3 8 years ago
You will end up having to make your own anyway, so just order a selection and keep a few spare parts around;
http://www.pbresource.com/pfswitch.htm#common
#4 8 years ago
Yeah, I was looking for the part number for Steve to make him happy. I'm also wondering if I can just grab a score motor and the 1a switch stack will be the same on it? There are a couple on ebay for $25 currently.
-Pat
#5 8 years ago
That would be one approach.
Cabinet Parts
Space Coast Pinball
