I am finishing up a Harlem Globetrotters On Tour playfield swap (my first), and tonight got it dropped into the cab and fired it up. Surprisingly, no major malfunction! However, the lamps are bugging. The GI strings look good. But the controlled lamps are rioting. Maybe someone out there has experienced something similar and can point me in the right direction.
The Lamp Driver board is a new Alltek, and the lamps are all new LED (lamp driver board installed properly). I went through and tested each bulb individually with a wall puck-modded-with-alligator clips, with one clip clamped onto the GI braid, and tapping through the ground lugs of each lamp. They all seem good and came on solidly.
When I fire up the game, here's what it looks like:
https://www.dropbox.com/s/3euucbw02h6gzd6/status-ready.mp4?dl=0
If I gently pound on the playfield a bit, or wiggle it with some vigor, sometimes the lights fall in line and look/blink perfectly normal. But usually it just stays like this.
When I fire up a game, here's what happens (you may want to turn your volume down to save yourself from the gate mech death rattle):
https://www.dropbox.com/s/k5i4fr8gkyby84c/status-game-on.mp4?dl=0
And when I put the ball in play, here's what that looks like:
https://www.dropbox.com/s/wfajev4v3ewce4f/status-action.mp4?dl=0
You can see how the GLOBE letters aren't really working, and when the bumpers activate lights blink all over the place.
So it seems like something is loose somewhere, or perhaps there is a short? I was pretty careful and the work is pretty clean, but I can post more pictures if that helps. Not sure where to start, but clearly something under the hood isn't right. Any advice is welcome. Thanks in advance!
