I am looking for some advice on the situation I am in with my first attempt at a playfield restoration. I have been using the advice from vid1900 Guide to Ultimate Playfield Restoration as well as other articles and videos. I have a Road Kings playfield with everything taken off front and back. The playfield was in good condition in terms of no spots worn though the paint, it has some chips, cracks in the paint, and terrible looking mylar covering half the playfield. I removed the mylar with no issues using the freeze can method. I then wiped the playfield down with naphtha. The glue from the mylar was still there so I started to remove it with the flour and isopropyl alcohol method. It was going very slow but it was working, the glue was thick. I ended up taking a break for a few hours to give my fingers a rest, when I came back I found the situation.
In all the white areas under where the plastics would be or rubbers, the paint was peeling and flaking off. This was not like that before when I was wiping the playfield down and removing glue. I was planning to use Frisket and air brush all the white areas anyway but I still need to finish getting the rest of the glue off and level the inserts. So I need to stop the flaking from getting worse while I finish getting the playfield ready for paint and then clear coating.
Any help or advice on how to handle this is appreciated!
