I purchased a Dialed In! topper from Tilt Topper.
I moved the display out of the way in the back box and I see a blue and blue/brown wire going into a 3 pin connector at the left side that looks like the standard 12 volt connectors I use to connect color DMDs and Toppers on Stern machines.
I plug in the topper and it does not work.
The manual states the F713 (p D-114) is 12 volt lights to Shaker motor, Redemption ticket motor, start button light, flash bulb light.
The start button lights. I assume that the connector I show in the photo below is the connector I should plug into to light up the topper. The LED on the board is on for the F713 so I assume it is working.
I plugged the topper into the 12 volt on my Avengers Hulk so I know the topper works.
Is there anything else I need to do? Thanks! Michael
