Installing an Eastview ceiling fan by Fanimation. Model # 0581596.
Last thing to do before I put the fan up into the bracket is cut the excess blue, black, white wire and strip insulation off the end of each wire.
Last wire to do is the white (neutral). I strip it and the wire pulls out of motor housing. Always something.
So I take the cover off the motor to see if it's obvious where to reattach the white wire.
Can't call for help till tomorrow. Searching the web for diagrams, schematics. Nothing.
Figured I'd post here in case it's obvious to anyone.
Would the white wire go anywhere else but with all the other white wires crimped together (see pic)? There are like 6 white wires all going into that one cap.
Thanks for any help.
