(Topic ID: 231090)
Help with board hacks
By topkat
1 year ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by topkat
#1 1 year ago
Can anyone post a photo of Dirty Harry connectors j121 and j120
I am trying to figure the magnet issue out and I want to be sure these hacks aren’t part of the problem
It looks like my j121 connector is missing a connector at pin 3 and. J120 missing 11
I don’t know how to go about fixing this since the wires are different colors than the manual. A photo would help
#2 1 year ago
according to manual, it must be something like this:
#3 1 year ago
Quoted from topkat:
If your wires are different than the manual, I would imagine a photo of someone else's game (which should be like the manual) will not help.
It's a little tedious but you can do it yourself for sure.
Disconnect the connector (i.e. J121)
Start at pin #1. Note the wire color.
Go to the manual, confirm the wire color is same or different (you should make some notes for the next owner).
Then in the manual find where that wire is supposed to go... validate the wire you see is indeed at that location.
Now disconnect the other connector.
Get out your DMM... use the continuity tester option to validate that you have that wire isolated.
Then move to the next pin.
I guarantee, after you do the first pin you will feel exhilarated for figuring this out yourself. You'll blast through the other pins in no time and you will learn a LOT about your game.
Good luck and don't give up.
faz
#4 1 year ago
I will go through and check Pin by pin
It looks like they used a bunch of different wires from the board that then goto wires with the manual color code (not soldered just connected)
The only one I don’t see at all is yellow on pin 3 j120. Will look to see if the. Yellow wire is somewhere under the playfield loose
Mike
KAHR.US Circuits
$ 11.00
Gweem's Mods
$ 199.99
PinballBulbs
$ 12.00
