Thanks guys. Mark, occasionally 1 or 2 would reset but not the third.
However, I have adjusted that stepper unit some more (took it apart again, re-tightened the set screws in the camshaft, cleaned and lubed the rivets again (third time), and tightened down the rotator plate with the shoes. The game seems to be working 99% correctly now in terms of baseball logic / scoring (fingers crossed).
We can revisit this one if it starts to act up again.
OK next two issues:
The two bulbs that light the “special when lit“ inserts, are extremely bright and keep burning out now and then. I am wondering if this has something to do with the two resistors that are in that path. I have never worked with resistors before and know nothing about them.
Also, when I get a drop target bank down, even though the special will light, I cannot get the knocker to go off. The knocker does work, because I’ve heard it go off for the score thresholds.
Second issue: This just seemEd to start happening as the day went on and I was playing it more and more and trying to troubleshoot that special issue above. I can be playing a game – does not matter which ball is in play — and seemingly randomly the game will just lose power to the flippers. Playfield lights stay on, but after the ball drains I have no flipper power and the game does NOT go to game over, nor does it go to tilt. It still shows the ball I was playing on the backglass.
I THINK it’s going out after sending five pulses to the hit unit. It definitely happens more frequently when I hit a drop target. But not always. Other things can cause it. Sometimes I can hit the drop targets and they are fine. Instead, maybe going over a homerun roll over up at the top of the playfield will cause it, etc.
The CRAZYest thing that I’ve experienced with this issue is sometimes in the middle of playing a game it will reset the score reels during the middle of a ball. Sometimes the game goes to Tilt and ends. Sometimes it does what I’ve described above.
Thoughts?
