(Topic ID: 234795)
HELP with bally dash 35 roms jumpers
By Fordiesel69
88 days ago
  • 10 posts
  • 4 Pinsiders participating
  • Latest reply 44 days ago by Joydivision
#1 88 days ago
This game is set up for a balley kiss and I want to change it to a Evel Knievel what is the best way to do this. See the photo for the jumpers and the roms that are currently installed
#2 88 days ago
Pictures is not clear but as long as your EK ROMs are the original masked ROMs and not EPROMs, you can just plug them into U2 & U6 and you are good to go!
#3 88 days ago
they have clear windows in them so there not masked
#4 88 days ago
Ok the you need to make the following jumpers:
1-5, 2-4, 7-8, 10-12, 11-29, 13a-14, 16a-18, 31-32 & 33-35
#5 87 days ago
Quoted from Fordiesel69:
Just a side note on these Twobit Dash 35 boards.
If you find you have any feature lamp flickering going on with standard incadescent globes installed for feature lamps (regardless of which game you use this "Dash 35" board in) you need to check U14 is a 4049UBE & not a 4049B.
Some or all of these Twobits "Dash 35" MPU's were shipped with a 4049B at U14 when it should have been a 4049UBE. All the Bally boards were shipped with a 4049UBE (even though the manuals state 4049B at U14). A 4049B at U14 will cause very noticeable flickering on some feature lamps.
I swapped mine out to fix this problem.
Probably a good idea to get rid of that Nicad battery too before it leaks.
#6 87 days ago
what type of roms are the ek? jumpers will depend on rom type. 2716 , 2532, 2732
1 month later
#7 45 days ago
Joy division..... Thank you for the tip, that is how I ended up with that board. Posted the topic on rgp yrs ago and nobody knew anything about it. I swapped some resistors, I swapped some other things to no avail. U14 is incorrect. I will change it out.
#8 45 days ago
No worries, yes, I found their was very little info about this. Definitely change the U14 to a 4049UBE & see, looks like yours is nice & easy as it's socketed - mine was soldered in.
#9 44 days ago
No dice. It does have the UBE chip at U14.. So that funny flicker I see in the incd feature lamps must be something else.
#10 44 days ago
Ah ok, even though it'a a 4049UBE present, I would probably change it for another different brand 4049UBE to rule out U14 in case the problem is with that chip or the brand of chip. They are cheap. I would check the socket is ok too. I used a CD4049UBE.
A post on a similar problem here & other possible solutions- may be of some help.
https://pinside.com/pinball/forum/topic/bally-controlled-lamps-flicker
$ 50.00
$ 86.95
2,400 (OBO)
Toronto, ON
3,000
Bellefonte, PA
€ 3.95
Multigame
Displays
PinballSolutions.eu
Third Coast Pinball
$ 149.00
$ 159.00
Pinball Pimp
$ 157.00
Third Coast Pinball
$ 21.00
$ 7.65
Cabinet Parts
Third Coast Pinball
$ 16.00
Yorktown Parts and Equip
Third Coast Pinball
$ 86.95
$ 99.99
Great pinball charity
Pinball Edu
