A color washer around the posts near the entrance to the outlanes. Red might look good.
https://www.etsy.com/listing/210912288/washer-toss-pitching-washers
Quoted from leckmeck:A color washer around the posts near the entrance to the outlanes. Red might look good.
Thanks Leckmeck, the principle would work, but just looked, those are at 2 1/2 inches and steel.
Maybe something smaller (plastic). Possibly put a rubber ring on it.
Anyone else?
Quoted from phil-lee:Thanks Leckmeck, the principle would work, but just looked, those are at 2 1/2 inches and steel.
Anyone else?
You could position a post same as the one at the back of the flippers to close the gap to the outlane as below.
Untitled-1 (resized).jpghttp://www.pbresource.com/hhouse/gtb-c17492.jpg
How bout something like this but only fastening with one stud?
You could play around with making your own wire form to mount around the post screw and below the plastic. Something like this:
Start with something soft like bailing wire and experiment with different shapes. Once you've found something you like you can make a more permanent wire form with piano or music wire available at PBR or Marco. Music wire is much harder to work with but has a nice shine and will hold its shape much better. Stainless steel wire is another option.
You might want to add a washer between the new wire form and the plastic above it to protect the plastic. You might also need a slightly longer screw. But, you get the idea...
/Mark
Quoted from oldpins:You could position a post same as the one at the back of the flippers to close the gap to the outlane as below.[quoted image]
Thanks Oldpins, that would be the most effective solution but even though this isn't a desirable pin I hate to put another hole in the playfield.
Quoted from Xtraball:http://www.pbresource.com/hhouse/gtb-c17492.jpg
Xtraball, going to do a little research on the "Double Wide post". Looks Kosher.
Mark, the wire would be the stealthiest but require a little finess (or artistic ability) to keep the ball from hanging.
Thanks everyone! The answer may lie somewhere in the midst of these suggestions. Right now I'm leaning towards the pregnant Post but please add any more you may have.
Is there any kind of rubber bumper that would mount on the wood rail? I'm just afraid the 2 post plastic with only one mount and the wire rig would get knocked silly as fast as these balls drain.
You have to FIGHT for every point on the Widow.
Quoted from phil-lee:I'm just afraid the 2 post plastic with only one mount and the wire rig would get knocked silly as fast as these balls drain.
Since you have two posts on the lower edge of the violin plastic, you could run a stiff wire between them with a profile that narrows the gap, yet is fixed at both ends. It would be sturdier than the single post mount.
Or maybe you could cut a piece of acrylic in that same shape that would mount on the posts just below the rubber. Since the posts are tapered, the rubber ring might hold it in place without any glue if you got the hole size just right. Or you could look for those two piece posts that are meant to have a clear plastic mounted at ball height and replace your existing posts with those.
This page was printed from https://pinside.com/pinball/forum/topic/help-with-an-outlane-hack and we tried optimising it for printing. Some page elements may have been deliberately hidden.
