Hey guys,
I've been bring an operation thunder back to life, and so far so good, except one drop target in a bank of 5 is not working. I cleaned all switches, put the game in test mode, and even manually closing the switch won't cause the game to recognize the switch closure. I tested the diode, visually inspected the wiring, and everything appears to be good. Is there anything else I can check that I might not be thinking of? It's just this one switch, as far as I can tell every other switch in the game works fine. Also, the game play is based around missions, and there is one mission that cannot be completed without the proper functioning of all drop targets. So basically every time this part of the game comes up, you will eventually lose your ball because the game won't recognize that you've completed it. please help!
