Put it in my basement a few years ago, and worked fine, but now when I plug it in, nothing happens. I tried the reset button underneath but no help.
Any suggestions?
Thanks from a nOOb.
Any suggestions?
Thanks from a nOOb.
Welcome and we will all be glad to help. It will help if you let us know your troubleshooting skill level so to speak. I assume you've check the fuses etc already as that's the first thing to start with.
Your machine ?
http://www.ipdb.org/machine.cgi?gid=1566
If so you have a very rare old EM on your hands.
yeh I would start from the outlet and work your way back - Im not a pin tech but like computers and other electronics - half the time its something basic - outlet reset, power supply, fuses
Sounds like Melody went to sleep on you - a few things that may wake her
- lift the playfield (remove ball) and set it back with the power off at first rotate score motor CC with finger
-now under power do the same rotate Counter Clockwise and it should show signs of life.
- put a credit on the window push 'start'
- if score motor wont shut off try pulling in reset bar of reset bank
(you dont want the score motor running forever)
-hope this helps
This page was printed from https://pinside.com/pinball/forum/topic/help-with-a-gottlieb-melody and we tried optimising it for printing. Some page elements may have been deliberately hidden.
