Need your thoughts on the following issues with my TAF machine....
- My coin door switch was gone. I bought a new coin door and switch. If i plug in the coin door switch, I get other switch problems within in a few games. Unplug it, all is good. Normal behavior for a missing diode. But I don't see anywhere online that shows the coin door switch on TAF had a diode.. Thoughts?
- Thing hand when coming out slightly scrapes the metal ball guide (it's actually the edge of the coil that hits). This doesn't seem right. I know the mechanism under the playfield can be adjusted/pivoted. I have done so, and still scrapes. I've used all the original screw holes...so it's not making sense. I could move it bit, but wanted to see if anyone else had this problem before I go that route.
Thanks.....
